I'm looking for an inside diagram for my lid lock on my washing machine. Part #w10052930. Two metal tabs fell out and i don't know where the fit. Help please.
informatica
  • 1114 Answers
SOURCE: help please
You can download the manual from the link below: http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000062/xl513052325340ug01enesfr.pdf See page 19 on how to assemble the bobbin. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 29, 2007
e-Guru
  • 3917 Answers
SOURCE: Duet Washing machine... Sounds like metal loose
you will have to lvel the machine,cause when its not balanced it will do that,so under the machine there are 4 plastic that hold machine u can turn each one which way u need and make sure its leveled
Posted on Sep 13, 2009
  • 63 Answers
SOURCE: need diagram of installation of door handle
www.apwagner.com. You will need the model number. The diagram will give you a general idea of the assembly, but no directions. Good luck.
Posted on Sep 28, 2009
  • 713 Answers
SOURCE: 'LD' on display and lid closing won't get the washer started
Hi just read your posting.Now I know you supplied the model number in your posting but could you please supply the name of the machine which should be written on the control panel.Is it an ENDURO or an ESPRIT --etc--?Please reply with additional information and I can help you rectify this problem.Looking forward to your reply.
Posted on Jul 27, 2010
  • 83 Answers
SOURCE: I have a 5.5kg Simpson
yes the safty door latch switch is eather loose or going bad. somewhere on your door there is a small sensor or switch that tells the washer the door is closed and its ok to spin, these washers put out alot of force when spinning and thats why the sensor is there it would be dangerous without them. when the washer goes in spin cycle there is more vibration than any other cycle. and thats whats making the sensor or switch wiggle and its getting an intermedate signal. it probily needs replaced these can commonly go bad due to wear buy slamming the door on the washer.. i hope this helps
Posted on Sep 09, 2011
Gasket replacement problem, Hotpoint WMF540 washing machine
most I have ever seen have slots in the sheet metal that tabs fit into like slide loc tabs.. this requires sliding the face up or down on the sides.. that may help..these are locked by internal screws that you can take out from tne inside ..
Jan 12, 2014 | Washing Machines
Changed battery .A square piece of metal the size of match head fell out. No alarm or light, casio forester FT200
mcdevito75 here, Of couse without the watch and piece of metal that fell out it"s very hard to say. Most likely it was part of the lock-down tab to keep the battery in place, in any event don"t lose that piece of metal. If your casio is working ok don"t worry about it, just don"t lose that piece of metal that fell out.
Jul 05, 2010 | Casio Forester PAS400B-5V Wrist Watch
My maytag neptune washer model#FAV9800AWQ keeps giving diagnostic code 4 and won't start the wash cycle or if it does start to wash it stops and says the lid is unlocked. the lid can't be opened because it...
I’m an owner of the FAV6800A LED console display version. You have the LCD console.
This issue could be related to a failed Control Board a failed Motor Controller. It could be related to loss of signaling to and from the lid locks.
What is your skill set level can you use a DVM to measure D.C. voltages in the machine?
If not I would recommend a knowledgeable repair service to help resolve the issue and that may be a challenge. But read on and maybe we can get you to look at the Left Hand Lid Lock,
You can raise the washer lid from the base to remove your clothes from the wash basket with this process and the Service Manual . Don’t break the Left Hand Lid Lock latche if you do you will need to replace the Left Hand Lid Lock. The machine only needs that Lid Lock to operate as designed.
Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
Diag code 4 for both machines = The lid fails to lock. Look on page 25 for the error code description in then points you to this “”Go to "Will not unlock" Troubleshooting Section””. Confusing right?
I think you could have corrosion issues with the Left Hand lid lock. If you want to DIY this part of the machine see this post for Left Hand Lid Lock Troubleshooting.
Take a look and see what direction you want to go…..Rich
Dec 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
When I push the start button I get a beep and the message is: "od" and the washing machine doesn't start
The FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
The OD alarm means the FAV6800A/FAV9800A Control Board has not sensed a lid open condition for three completed wash cycles even though you opened the lid.
You have lost signaling from the Left Lid Lock back to the Control Board.
What I would do next is remove the Left Lid Lock and very carefully open it up. See page 34 for removal steps. Just remove the left lid lock don’t worry about the right. Once you have the Left Lid Lock in your hand you need to open up the case halves.
I found it is very easy to break off the enclosure locking tabs. I use a fine flat jewelers screw driver and X-acto blade and work around the locking tabs to open the case halves. I wedge small paper clip ends or tooth picks in the case halves as I work around the tabs. Once the case halves are open I believe you will find corrosion issues such as seen in my pic’s.
You can clean up the corrosion with WD-40 and finger nail
emery boards.
Hit the plug end with a couple of squrits if WD-40.
I believe you will find the black lead has broken loose from one end of the magnetic reed relay. It can be soldered back on. If you don’t want to deal with that you can order a replacement. Left Hand Lid Lock.
Let me know if you have questions…. Rich
Nov 28, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Balance spring fell off washing machine. Where
Check the Sears parts site for diagrams of all the major components. Replace the model number shown (11020802990) with your model number (found on cabinet when you open the lid)
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=11020802990
Look at the diagram for the machine base and you should see the springs and where they connect.
Sep 14, 2009 | Kenmore Washing Machines
LG WM0642H*
Remove the 4 dispenser area screws. Depress side dispenser tabs to drop dispenser assembly from the top lid .Insert an opener or flat item into top lid and front panel space to depress inward the metal lid top hold down clip.Do left side first then right.Raise the lid and look down behind lock mechanism.Or tilt washer and look underneath. It's an open area below?
Apr 28, 2008 | LG WM0642H Front Load
Lid locked no power
use a screwdriver in the crevice beneath the lid. Approx 4 inches from each side you will see a 1" silver piece of metal, push the tab towards the back of the machine. Once you get one side loose place something such as a screwdriver to keep it unlatched until you get the other side loose. The top should come open. And there is also a service book inside your washing machine, I fixed mine myself. Look at my other postings. Good luck!!
Nov 06, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
