Question about Garmin Forerunner 301
Garmin forerunner 301
The mode button has stopped working on my garmin forerunner 301. can it be repaired or is it just as cheep to buy a new one?
  • lmwongpan May 20, 2009
    I have the same problem. Mode stopped working until I pressed it in with a pen. I did that for about a month but today must have pressed it in too hard, the button is stuck so there is a continuous scroll threw the menus. Is there a way to open it up and fix this?
  • 22 Answers
Hi
the garmin gps often use a soft rubber in their contruction
either wait til the unit is out of the heat or use a bit more pressure to push the button doen firmly
the map60 range has the same issue with the power on/off buttons
there is no replacement parts as its built into the case
D
Posted on Nov 21, 2007
Forerunner 410 button issue
If the Forerunner 410 is less than a year old, it should still be covered under Garmin's warranty.
If not, then you could contact Garmin to find out the cost of repair.
Garmin Support: 1-800-800-1020
Jan 07, 2012 | Garmin Forerunner 410 with Heart Rate...
Forrunner 301 won't turn on or charge
You can try various resets to see if you can get it to respond.
Have you tried plugging the unit into the wall instead of the USB
port.Do you get the Battery Charging message at any time.You can
try a soft reset.Press mode and reset.Then try to power on while
plugged in.A hard reset will delete all your data and settings from
the Forerunner.Press the Power and the Mode button until the unit
comes on and asks if you want to erase all user data.Select Yes.
If the above won't work, try a hard reset that by-passes the
confirmation screen.Press Mode, Reset and Power.
Oct 29, 2009 | Garmin Forerunner 301
My forerunner will no longer turn on or even charge, can they be repaired or am I best to buy a new unit?
Garmin will repair it for about eighty bucks.
http://www8.garmin.com/support/outofwarranty.html
But first, try cleaning the electrical contacts on the forerunner and the cradle by rubbing them with a pencil eraser. The slight abrasive should remove any oxidation on the metal. A bad contact between the unit and the cradle could be your problem.
Jul 22, 2009 | Garmin Forerunner 205 GPS Receiver
Change battery on Garmin Forerunner 301
Hi - look at this solution for a forerunner 201, which has the same case design. I was just looking myself! R_nz Rank: Apprentice Rating: 96%, 8 votes I've made some progress here, I discovered that there is a small notch beneath the flat black pastic insert that holds the rubber button cover in. By gently prising this out, I can at least expose the pcb with the buttons on. I still can't figure out how to open the case though ****! Comments: Jan 29, 2008 - Well, I got there in the end! As above, I managed to prise the plastic insert cover off the rubber button cover, the peeeled this off as well. Underneath is a mylar printed circuit with the silver domeos of the buttons moulded in. This is siliconed down, but you can peel it up with a fingernail. The top left end (above the on button) is aatached inside the case, so start at the other end. Jan 29, 2008 - .ctd.. Once you have lifted the mylar strip, you can get at the case seam underneath and prise it gently open with a flat blade. The case is glued together with a light silicon or something. My problem was unresponsive buttons and by detaching and then re-attaching the small connector by the big silver block where the mylar attaches to the main board and then re-attaching it, it seemed to fix it! :-) Oct 22, 2008 - As an end-note; I glued my 201 back together with a light Silicone sealer. It seems to be at least rain proof anyway. Forerunner 201 battery replacement (Expert level): Opening the 201 was not easy and could not be done 100% clean, but thanks to R_nz (above) I got it open. My problem was dead (almost) battery, after 6 years of superb operation. I found the battery to be glued (double sided tape) to the back cover. To remove, push it up slowely and pull out. Beware of the short wires. 1. It is a flat battery, wrapped in shrinkable tube. Made by MDTechnology, P/N 043048 3.7V, 500mAh see http://www.mydbattery.com/EN/products.asp?ID=12 2. On the cover, the battery is soldered to the underside of a small PCB, hard to get to (by expert!). If you find a battery, suggest to cut the wires and solder wire-to-wire. Hope that helps
Jul 08, 2009 | Garmin Forerunner 301
My garmin 305
Press and hold the mode and lap buttons for 10 seconds, then release. Most of the time, that will fix it. Garmin has a sort of sleep mode programmed in for certain situations. If that doesn't work, I have had wonderful success with Garmin tech support.
May 16, 2009 | Heartbeat Garmin Forerunner 305 Gps...
Garmin Forerunner 205 Battery won't charge. A few
Hey everyone. Just called Garmin and got it fixed. Sometimes the forerunner goes into power saver mode and needs to be reset
1. Hook up the usb cable and docking station to the computer.
2. Next, hook up your forerunner to the Docking station - It should pop up saying battery charging in progress
3. Leave it all hooked up and Hold the Mode and Lap/Reset Button together for 15 seconds - screen should go blank.
4. Let both go - should pop back up saying battery charging in progress.
5. Let Charge 20 minutes and it should be good to go.
Hope this helps!!!
Kenny
Feb 20, 2009 | Garmin Forerunner 205 GPS Receiver
Garmin Foreruner 305 will not turn on or charge
I had the exact same problem and thought my beloved forerunner 305 had finally died. Try pressing the lap and mode keys simultaneously, and then power on. That may do a "soft reset." Worked for me.
Jan 05, 2009 | Garmin Forerunner 301
oops, i meant i know its NOT the oxidation problem
Jun 29, 2008 | Garmin Forerunner 301
Garmin 301
try syncing again or try replacing the battery of the HR belt
Mar 02, 2008 | Garmin Forerunner 301
Garmin Forerunner 301 Logo
293 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
