The two petal pieces fell out of my lid lock on my wasing machine part #w10052930. I don't know where they go back inside. Looking for help or a diagram of the inside lock
Noggin
  • 944 Answers
SOURCE: The lid will not lock and stay on during churning
Here is a link to the manual if you need it; http://www.cuisinart.com/share/man/423_man.pdf It sounds like somehow the little locking lugs on either the lid or the bit it locks to have broken off. if it is the lid, then you should be able to get a new one from cuisinart - check the manual for details, otherwise you probably have to either try and rebuild them by carving another piece of plastic the same and glueing it on. a new body piece may be available, check with cuisinart, but my guess is that you are stuck with tape - or my idea would be a large rubber/elastic band, so you can re-use it. Hope this helps :)
Posted on Mar 23, 2007
SOURCE: My door lock magnet fell out and I don't know whee to put it back on the dispensr mechanism tomake t lock
I found it! If you are looking at the drawer from the back the magnet sits in the pocket in the far left. The plastic extends out like a clip (to hold the magnet in place). You depress that when placing the magnet in.
hth.
Kate
Posted on Mar 29, 2008
SOURCE: need carb diagram
Go to either the murry site if still available or the briggs and stratton with all of your numbers and see what you can do with them. If you have the carb name and model # go to that site also. Hope this will help you. donnyb60
Posted on Mar 21, 2009
SOURCE: Door lock assembly fell inside door
The same thing happened to my 2006 Aveo. Once you do the above find the lock and the screw that holds it in (they will both be in the bottom of the door). Put the lock back in place, put blue Loctite on the screw and screw it back in place and this problem will not repeat itself.
Posted on Aug 24, 2009
SOURCE: how do i remove the
Two small screws at the back and one on either side (behind little covers)
There are two hinges at the back, so lift off from the front up.
Posted on Jan 24, 2011
Model ftw3011kwo washing machine won't work after breaking locking lid piece
Thank you for your inquiry, David Castro!
I understand that your Frigidaire washer is not working after the lid piece became broken. If the lid piece is not latching properly inside of the door latch then your washer is not registering the door is closed and will not start. You may need to have that piece replaced I would recommend having any electrical component replaced by an authorized technician. I hope this is helpful. -Matt
Dec 14, 2014 | Frigidaire Washing Machines
Where do i get a belt for my wasing machine
You can purchase a belt for it at your local Appliance Parts Dealer you will need to look them up in the phone book for your area once done you will need the model number which will be located inside the lid opening probably under the lid hinge area if not it will be located on the back of the washer around the back of dash hope this helps and thank you for using FixYa!
Jan 27, 2011 | Washing Machines
My machine lg top loader wf-t7050tp gives me a dE error what does that mean
this means door error there is a magnet in the lid that falls of and this is how the computer knows the lid is shut lg dont sell the magnet you have to replace the whole lid sorry.
Jan 11, 2011 | Washing Machines
'LD' on display and lid closing won't get the washer started
Hi just read your posting.Now I know you supplied the model number in your posting but could you please supply the name of the machine which should be written on the control panel.Is it an ENDURO or an ESPRIT --etc--?Please reply with additional information and I can help you rectify this problem.Looking forward to your reply.
Jul 27, 2010 | Fisher Paykel Eco IWL16
Changed battery .A square piece of metal the size of match head fell out. No alarm or light, casio forester FT200
mcdevito75 here, Of couse without the watch and piece of metal that fell out it"s very hard to say. Most likely it was part of the lock-down tab to keep the battery in place, in any event don"t lose that piece of metal. If your casio is working ok don"t worry about it, just don"t lose that piece of metal that fell out.
Jul 05, 2010 | Casio Forester PAS400B-5V Wrist Watch
Every load i put in small loads my machine stops with a UL error code
I’ll try to help I’m an owner like you.
From the FAV6800AW/FAV9800AW Service Manual;
UL = Latch Unlocked: Close lid tightly to enable locking.
That’s real helpful…. right?
Not sure how wash load size would cause the UL error to the display. From your post I believe you can’t complete a wash cycle at all is that correct?
Do the Lid Lock Latch’s look like they are projecting into the left and right side of the closed lid when you press the start button? If so you could try reseating the Left and Right Lid Lock Plugs a few times. There could be some corrosion issues preventing the Lid Lock signaling back to the Control Board. Those Lid Lock plugs can be difficult to unseat for the first time. The Left Lid Lock does suffer from corrosion issues with its proximity to the bleach dispenser. See page 34 of the SM. For the location of the Lid Lock The SM will show you how to rase the washer top from the base to access the Lid Locks.
Long response;
This may only help if you or someone you know has basic mechanical skills, you know how to use a Digital Volt Meter and you are a diehard DIY’er. A schematic diagram of the washer should be in the console of your machine.
From looking at the schematic and Service Manual “You can download the SM from that link” the lid is locked signaling is coming from the lid locks. I believe you are losing the Lid Is Locked signaling from the lid locks or a common wiring point in the machines wiring harness going back to the Control Board on connector P3-8. The issue is where, why and how to correct for that loss of signaling.
It looks like the Control Board wants to see +12VDC at connector P3-8 “Lid Lock Input” for the proper Lid Lock status signaling that the Lid Is Locked. I would take my DVM and trace for what I believe is the loss of signaling back to the Control Board input from the Left & Right Lid Locks. What is the possibility that both Lid Locks have failed with that status? I believe not much, from looking at the schematic it looks like the status inputs +12VDC and outputs from those Lid Locks run in parallel into the machines wiring harness to a common point in the washer wiring harness then to the Lid Is Locked input of the Control Board Connector P3-8.
The question for you is how deep do you want to get into troubleshooting if at all and how long can you tolerate the washer down time?
I’m a technical owner and I would dive right in for this repair. I also have spare parts. Depending on your skill sets and if you have a DVM you have to decide how to proceed. I hope a forum member with more hands on knowledge then I will chime in with their solution on troubleshooting this issue. I don’t simply what to say call in Repair Service without having a feel for your desire and skill sets to troubleshoot the issue.
If you call in a repair service run my response by them. I believe just changing out the lid locks or the control board will not solve the issue but I could be out in left field with my thoughts. I don’t recommend you do this….. but I would try to clear the UL error by taking an alligator clip lead and jumpering Pin P3-8 “Lid Lock Input” and Pin P3-3 or 4 +12VDC Out of the Control Board and see if this clears the UL error. If the error cleared that would rule out a Control Board issue. Rich
Aug 15, 2009 | Maytag Neptune FAV6800AW Top Load Washer
When checking out the lid switch on my roper washer as jsrock suggested in another post, i heard a screw drop from the inside of that area which caused the lid switch to become unmounted completely. also,...
Top lid pull up. Look in seam between top and front cover. On each side you will see where top clips to front cover. Put a screwdriver in there and lightly pry up till clip releases. Front cover will now pull up and be removed, so you could get what fell in.
Jul 26, 2009 | Roper RAS8445KQ Top Load Washer
Dec 12, 2006 | Cuisinart ICE-30BC 2 Quart Ice Cream Maker
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
