Question about Garden
Where is fuse for blades on f680z John deer - Garden
  • 18 Answers
SOURCE: blades will not ingage
is it electronic engage or manually?
Posted on Sep 03, 2008
SOURCE: replace blades on a john deere L120 mower deck
First make sure you have the tools, metric that is. The deck must be removed and turned over. To do this you must put the deck in the lowest position. Using a 15mm socket pull the belt tension spring pulley forward to detach from clutch. Next remove retaining pins located at the five deck brackets. This will allow the arms to slide off and the deck can be dragged out from under the mower. Turn deck over. Use a 18 inch 2x4 to block blades while removing the two 15mm bolts. The bolt heads will need to be cleaned so the socket can seat on bolt head. I use my torque wrench to get more leverage and i can use it to reset blade bolts to 64 ft lbs. While blades are of it is a god time to thoroughly clean underside of deck.
Posted on May 25, 2009
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
Posted on Oct 02, 2009
  • 197 Answers
SOURCE: how do we service the blade / brake clutch
No serviceable parts,you can only buy complete clutch.To replace you remove blade and blade adapter.Use a very large vise-grip to remove spring and then you can remove bolt holding clutch arm.Disconnect cable from top side of machine.Remove engine mounting bolts,have another person pull engine away from frame while you slide clutch off.Going back together you may have a tuff time getting large spring back on hook under deck.I've been working on these for some time and have yet found an easy way to get large spring back on.
Posted on Nov 15, 2009
  • 1627 Answers
SOURCE: john deere gt 235 electric blade engagment but
One of two possible causes;either the PTO switch is defective or the switch for the reverse peddle is out of adjustment .The only other thing i have seen cause the PTO to shut down is a lack of battery power due to the machine not charging.
Posted on Mar 21, 2010
LX176 John Deere lawn tractor doesn’t get power to the starter, I have replaced the ignition switch and still nothing. Can anyone help?
Oftentimes there are switches at the blade engagement lever and under the seat...for safety reasons. I can't start my mower if the blade drive is engaged and /or I'm not in the seat. That's a clue to check , however I'd check the starter solenoid first.
Oct 17, 2017 | John Deere Garden
Where is the fusible link in a John Deere LX 255 lawnmower?
First thing to check is make sure you blade switch is in off position, brake/clutch is down and locked. There is a 20amp fuse in a fuse holder by the battery in engine compartment. Is it not turning over or not starting?
May 08, 2015 | John Deere Garden
Why does my john deere g110 blows fuse when blades are engaged
unplug the clutch and see try it if the fuse doesn't blow then look at the wires going to the clutch make sure they didn't rub on something
Jun 09, 2012 | John Deere Garden
John Deere LX176 fuse blows when pull up button to engage blade.
look where the wires go threw the frame to the clutch and unplug the connector and try a new fuse if it still blows remove the clutch and inspect the wires they do rub on metal and short of the power
May 28, 2012 | John Deere Garden
I wish to know which direction do i turn the bolt to take the cutting blade of a john deere ride on/ clockwise or anticlockwise?
As you are looking at the blade and bolt from under the mower, if the blade is rotating counterclockwise, then the blade bolt is standard threaded and will turn counterclockwise to loosen. If the blade is turning clockwise, then the bolt is left hand threaded and will turn clockwise to loosen. John Deere produces mower decks with both setups.
Dec 30, 2010 | John Deere Garden
John Deer X475 lawn mower
Check fuses.Does the dash light for PTO come on?Right side screen by pedals sometimes comes in contact with wires and cuts them.This happens mainly on the older units.
Sep 19, 2009 | Garden
Have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Aug 10, 2009 | John Deere Mower Blade 5 each
I need a john deere X360 44" front blade
you can buy it on ebay right now!
here's the link:
May 10, 2009 | Garden
Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Apr 04, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
