Question about Garden
Need the hand wand you pump up sprayer 3 gal Groundworks
SOURCE: I have a 2 gal
I guess a company called the Fountainhead Group makes a lot of different sprayers other companies. They have repair parts available on their site. I replaced the nozzle and installed fresh gaskets with a kit from Lowes and with info from this site; http://www.creativeworksforchildren.com/how-to-repair-ortho-roundup-garden-pump-sprayer.htm
Posted on Aug 20, 2010
  • 127 Answers
SOURCE: I have a 3 gal. back sprayer. When you try to
Hi there
There are many possible reasons for your sprayer not pressurizing. If the pump lever is moving freely and does not seem to be building pressure while pumping it is possible that the O-ring at the valve is damaged, the seal in the pressure regulator is leaking, the piston or the collar is worn. Any of these problems will require disassembly of the unit and inspection of each part. If you do feel resistance building as you pump but quickly loose pressure you likely have leaks in the diaphram, it's seal, the pressure cylinder or the tank itself.
If you are comfortable disassembling the unit and inspecting the parts for wear or damage most of the individual replacement parts are fairly easy to replace and readily available online from Solo or at many retail outlets and supply companies. Solo has done a great job with how-to videos and instructions for each procedure on their web site www.solousa.com
If you are not comfortable disassembling and repairing your sprayer yourself you can try contacting a mower/equipment repair shop in the Redding area as is seems the nearest Authorized Solo sprayer repair center is Cloverdale Saw in Cloverdale CA, 707-894-2273
Posted on Dec 31, 2010
  • 4088 Answers
Sounds like the fluid pick-up tube inside the tank has broken off or is missing. Good luck!
Posted on Jan 31, 2011
  • 961 Answers
SOURCE: I have the follwoing R.L.Flowmaster products: R.L.
They sell the sprayers and parts at Home Depot, Walmart and other places. I am providing a link for you to look at:
http://www.rlflomaster.com/wherebuy.htm
You can click on the store logos and pick out what you want and, they have an 800 number to check stock.
Posted on Jun 12, 2011
  • 111 Answers
SOURCE: My sprayer is new, but
Check under the lid/cover for a rubber gasket. This may have gotten unseated when putting the sprayer top on. It must form a tight seal around the lip of the sprayer top in order to keep the pressure. Alternative: Put water in the sprayer leaving some air on top to build pressure. Put a few drops of dish soap inside and gently stir. Put the cover on, and tilt the sprayer to coat all areas at the top. Start pumping and see where the bubbles come out---there is your leak. If it is near where the sprayer hose enters, and it is a permanent mount, you may have a bad seal. If the sprayer hose unscrews, you may need a new rubber washer inside. If bubbles come out of the wand, or other plastic seams, you may have a crack in the plastic. Depending on the location, you could epoxy over the crack to seal it permanently. Good luck.
Posted on Sep 27, 2011
Sprayer parts
need the hand wand were you pump up 3gal
Apr 14, 2014 | GroundWork® Pump Sprayer, Brass Wand, 3...
My sprayer is new, but does not keep the pressure, any idea's? It's a 2 gal, pump up type sprayer.
Aug 11, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
I e-mailed a question on a Chapin Hand Sprayer #1949 5 days ago and have not heard from anyone. Don
Welcome to FixYa!
"I have a Chapin Hand sprayer #1949 3 1/2 gal. I need to know how to get the pump apart to install a Industrial repair Kit #6-4627."
TO UNLOCK PUMP:
Turn handle counterclockwise until 3-prong clamp is loose.
Then rotate clamp counterclockwise to stop and lift out.
Thank you for using FixYa.
Keep me posted.
Jas247
Mar 23, 2011 | Chapin Garden
We have a 457 model hand sprayer. It wont pump to pressure , we think the end has come off the plunger. How do we pull the pump apart?
I recently ordered just the plug on the bottom of the shaft and it solved the problem. the company was really good about sending the plug right out for free at that. it worked and im back in business. just replaced it. no taking the pump apart.
The Pool Tech
Aug 07, 2010 | Solo 457 225 GAL DELUXE SPRAYER EA...
Need replacement part for 16-gal sprayer. It's the part that connects the hose to the gun -- hose end is broken off. What is this called and where can I get one?
The spray wand has a short plastic tube that the rubber hose slides over. Here's what it should look like, if it's not broken: 4bc420c.jpg
A 'band clamp' goes over the rubber hose to tighten it onto that little tube. If the band clamp is missing, you can get one at a hardware store - just find the size that fits over the rubber hose. If the rubber hose end is torn or cracked, just make a new clean cut with a knife.
But if the plastic tube has broken off the wand, you need to get a new wand. Good news - it's not expensive. This one's only 8 bucks.
Hope that helps you, if so please rate my solution, thanks and good luck!
Jun 02, 2010 | Northstar Garden
Pump is presurized but no spray
Most weed killers and fertilisers either crystalise or turn to gel when left unused. Pull sprayer wand to pieces and run hot water through the hose and wand, they especially clog up at the spray tip and at the on'off control.
May 14, 2010 | H.D. Hudson 1 Gal Poly Deck Sprayer
Moultrie 25 gal spot sprayer for water sealer treatment
Yes, I've used pumpup hand sprayers to apply sealers. Is the sealer water-based? If not, cleaning up the sprayer afterwards could be a chore!
Mar 01, 2010 | Moultrie 25 Gal. Spot Sprayer
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
