Question about iLO Televison & Video
Ilo tv. Picture rolling back on itself at top. Can't find a vertical adjustment.
  • 308 Answers
SOURCE: vertical rolling of picture
If the picture rolls while both on cable as well as when you playback a tape or DVD, it could be caused by a bad filter capacitor in the power supply or vertical deflection circuits. If it only rolls while trying to view a picture from a cable/satellite box, then that component is likely at fault.
Posted on Aug 20, 2007
SOURCE: westinghouse 27" lcd hdtv
I don't know if this will work for everyone, but we were having much the same problem with our Westinghouse LCD TV (which is what led me to this site in the first place.) After a great deal of experimentation we have found that if we keep the backlight setting at 3 or lower we do not have the problem. If we try to view it on the level 4, 5 or 6 setting the picture goes crazy after 5-15 minutes and does not clear up until the set has been turned off for about 30 minutes. Good luck! I hope this works for you too.
Posted on Mar 17, 2008
SOURCE: ilo lcd tv..picture too large??
I had the same problem and tried everything with the tv to get it back to normal. I would look for what was suggested by tvtek, but also look on your cable remote or box for an "aspect" button. That fixed my problem. If your problem occurs with DVDs as well then you may have another issue, but if it is with cable only, try this. When I called our cable company the tech said alot of people this button without even knowing it.
Posted on Mar 22, 2008
  • 375 Answers
SOURCE: picture keeps rolling
do you have cable to the set or are you on rabbit ears if on ears adjust antenna for the strongest signal.
Posted on Mar 27, 2008
  • 236 Answers
SOURCE: vertical hold on tv
no control over the remote..but impossible not to have vertical hold control in the TV itself. it should have one maybe at the back.
Posted on Apr 07, 2008
Picture is rolling
In the old days there was a control at the back of every tv labelled "vertical hold" that needed adjustment when the picture rolled. As tv sets became better that control was at first moved inside the cabinet and then finally deleted.
The vertical hold controlled the amount of synchronising signal (that is extracted from the signal received from the antenna) reached the frame oscillator. Today's electronics are so stable the vertical and horizontal synchronisation is automatic so while sometimes a rolling picture can be caused by a bad signal it almost invariably caused by an internal electronic fault needing the attention of an engineer.
Oct 19, 2017 | Televison & Video
Sony trinitron KV-32HS510 has vertical hold problem
It could just be a resistor or two ,
check for Vert Oscillator Circuit & AGC
Jul 27, 2012 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Cs2047s with vertical fluctuating wave; part of picture streched rolling from bottom to top of screen.
it sounds like adjustments need to be made inside the tv itself.Or it could mean that the tube is about to go out good luck!!
Nov 23, 2010 | Mitsubishi Televison & Video
Lines across my tv where the picture is reversed
You have bad capacitors in the vertical deflection. And you will have to resolder the vertical IC as well. Replace the caps in the area of the vertical IC. Find a TV tech or hobbiest to do this!
Apr 14, 2010 | iLO IWT3206 TV
The picture on my TS-4573 rear projection tv has started to roll vertically at a fast rate. How can I make this stop. On old tv's there was a vertical hold adjustment on the back that you could play with...
this fault is caused by defective electrolytic capacitors in the vertical deflection circuits, they need to be changed out, do this before it causes more problems, there are no adjustments for this anymore.
Jan 30, 2010 | Televison & Video
Video tapes played through VCR experience vertical 'rolling'
unfortunatly no. the vert hold is set by black bars at the top/bottom of the video signal (outside of the viewable area). it sounds like your VCR or tape is damaged.
Dec 04, 2008 | Sony KDF-42WE655 Television
Elongated picture on Sylvania 27" Model # SRT2232S
there is a vertical adjustment on the picture tube it's the yoke as it's called but you can adjust it so much..but it does sound like the tube is on it's way out
Aug 28, 2008 | Sylvania 6427TE 27" TV
Elongated picture
There is a bad capacitor in the vertical circuit. If you feel comfortable working inside a set and can solder, update this and I'll try to get the specifics for you.
Vertical hold on tv
Apr 07, 2008 | Audiovox AVT-1475 13" TV
Horizontal line in my TV.
"Guest" obviously has no idea what he is talking about. There is no such thing as "frame section" and if the vertical IC, ramp generator or vertical hold circuits were bad, you would have no vertical at all. If you mean that there are thin white lines at the top 3 inches of the picture, and the top of the picture seems folded back on itself, it means that the pump-up capacitor is going bad in the vertical output circuit. This is a very easy thing to correct but should be done by a qualified tech.
Sep 01, 2007 | Televison & Video
Televison & Video Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
