Question about Baby Gear
My two metal pins fell out of my lock and i don't know where they fit. Part #w10052930
3 Suggested Answers
njvinod
  • 1462 Answers
SOURCE: my phone is locked i don,t know the pin sonnyericson w705
PIN CODE is SIM dependenet and not phone dependent
PUK code in PIN UNLOCKING CODE, which is required when you give PIN number wrongly for 3 times,
This code is OPERATOR specific and not phone specific and you have to call you operator and get PUK if PIN is blocked...
if you provide PUK code wrongly for 7 time, you sim may become useless, then you have to buy new SIM
NOTE: You should ask your service provider,get the PUK, give the PIN 3 times wrongly and it asks for PUk,provide the PUK and set the new PIN..
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Sep 30, 2009
SOURCE: How do I pull up the spool pin?
from the questions I read, this has happened to alot of people.
normally the spool pin should be easy to pull up with 2 fingers, if it's not then most likely there could be something wrong, you can try to use a pair of pliers to pull the spool pin up,, but if it's come loose or broke then it will have to be replaced. and some sewing machine are not mint to be opened by anyone except a factory trained technican.
Posted on May 30, 2012
Le Crueset 1.8-Qt. Enamel on steel whistling teakettle u-shaped metal piece fell out
There are two parts to the whistle - the hinged whistle bit and the black base that is attached to the spout. They are joined by a pin that passes through the base and through a bracket that is fixed above the spout, and through the bottom of the arm on the hinged whistle. Remove the pin - it is a push fit - so you need a rod of the same diameter. It will then all come to pieces. The U shaped metal spring sits in the bracket on the spout - the open end and the slope on the spring to the top. Then put the bits back together and replace the pin! This is tricky but do-able as all the holes have to line up. You need to have plenty of light to see what is going on. Once aligned the pin goes back in okay but don't try to force it. If it doesn't go in your alignment isn't right.
Mar 22, 2013 | Le Creuset 1.8-qt. Enamel on Steel...
My mom gave me a Kenmore 10. I don't know how to get the bobbin to stay in because the metal pin inside the casing is gone.
contact these sites and call them or email them about the
bobbin won't stay in because of the metal pin
sewvacdoctor.com
a1sewingmachines.com
Jan 07, 2013 | Sewing Machines
May 29, 2012 | Brother Sewing Machines
WE TOOK OF THE DOOR TO GET THE LOCK THAT FELL IN, A PIECE CAME OFF, NOT SURE WHERE IT GOES
Is it a rectangular C-clip? The clip that holds the lock in place, by being wedged between the lock and the inner sheet metal of the door. Other than that, I don't know, a rod for the door handles?
Apr 08, 2012 | 2004 Chevrolet Aveo
Wanted to know what a pin less motherboard is
Actually there are Pin less processors .which fit in the motherboards .
Pin less processors don't have pins . we can fit in motherboard easily.
But, the processors which have pins . takes a bit concentration .because the pins can bend.
All Amd Processors are with pin . and all new Intel Processors are Pin less
May 09, 2011 | Computers & Internet
Changed battery .A square piece of metal the size of match head fell out. No alarm or light, casio forester FT200
mcdevito75 here, Of couse without the watch and piece of metal that fell out it"s very hard to say. Most likely it was part of the lock-down tab to keep the battery in place, in any event don"t lose that piece of metal. If your casio is working ok don"t worry about it, just don"t lose that piece of metal that fell out.
Jul 05, 2010 | Casio Forester PAS400B-5V Wrist Watch
Can't raise the saw assembly in ordr to cut wood
Search the rear of the saw for a locking latch or pin...
Feb 20, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Rekeying kwikset locks
Sure. You need to install the key in the cylinder and keep it turned so the pins are on top. Then you install the pins one at a time in each hole until all the pins fit level with the top of the cylinder, You will probably have to re-arrange the pins once or twice to get the correct length in the correct hole but once all the pins are level you're home free.
Sep 30, 2008 | Locks & Locksmithing
Wrist band adjustment
In addition to the Pin there is also a small inner "locking" collar about 2mm long that fits into the center section of each link.
I did not notice this collar at first and it fell to the ground when I removed the first link. Without this piece the Pin's will just slide through the links with no locking mechanism.
It fits neatly into the inner portion of the link directly opposite the arrow that shows the direction of removal on the band.
Jul 01, 2008 | Casio G-Shock G7000D-8V Wrist Watch
Wire diagram for installation and where can i get the plastic inserts for the buttons
i just got the wiring for the sony xe-mk90II eq, heres a picture :
top right is the ground , bottom right is constant power, blue is the remote turn on. if you have a old wire harness around you can pull out the blue ,yellow, and black wires with the metal clip on and make than fit right where the wires should go. but make sure u rap the metal clips with electrical tape so the wires dont touch or you will fry it.
Feb 22, 2008 | Sony XE-90MKII 9-Band Car Equalizer
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
