Printing a user card - Office Equipment & Supplies
Password advanced user diagnostic print tool datacard sp75
The advanced user password for the SP75 Plus diagnostics is 926918
Jul 09, 2012 | Datacard SP75 Plus Card Printer
I have a HPC7280 all in one. it is asking to insert a memory card for copies. why? how do i get around that.
It sounds to me like you have selected an option to print directly from a memory card at one time. Here are excerpts from the user manual for your machine to change printer settings:
Change the print settings
You can customize the print settings of the HP All-in-One to handle nearly any print
task.
Windows users
Before you change print settings, you should decide if you want to change the settings
for the current print job only, or if you want to make the settings the defaults for all
future print jobs. How you display print settings depends on whether or not you want
to apply the change to all future print jobs or just to the current print job.
To change the print settings for all future jobs
1. In the HP Director, click Settings, point to Print Settings, and then click Printer
Settings.
2. Make changes to the print settings, and click OK.
To change the print settings for the current job
1. On the File menu in your software application, click Print.
2. Make sure the HP All-in-One is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
4. Make changes to the print settings, and click OK.
5. Click Print or OK in the Print dialog box to print the job.
I believe that this should help you get around your issue. Here is a link to the entire user manual for future reference.
http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf
Dec 22, 2010 | HP PSC 1610 All-In-One InkJet Printer
We have installed the printer in a PC that is on the network so that different users can log on and print from it. However there is one user that when she logs on she cannot print. she opens up the...
Hi Good day!! Your network seems to be very busy that's why the user can't connect to your server which your printer is installed. OK i will give you step to connect the user which cannot print.
Server
1. In your Server right click your "My Computer" and then click "Manage". you should be in computer management box.
2. Click "Shared folder" in the Computer management and then click "session" after opening it you should see the user which is connected to your PC. delete some users.
User
1. Click "Start" - Setting - Printer and faxes, double click your printer, i think your printer status was unable to connect? try refreshing it while the server is deleting some user which is not using the printer.
when refreshing, monitor the status of your printer when it says Ready your PC is now connected to the Server and now you can print.. Hope my solution helps you!!
REGARDS
JR
Oct 19, 2010 | Datacard Group SP35 Card Printer
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
My business cards will not print from Printmaster Gold to HP 2410 Printer. Everything else prints except business cards. I get a box that indicates the are printer but nothing prints.
your cards are too thick .the printer wont actually move the card down to yhe printing heads. try placing just one sheet into the printer or/and go to setup and see if you can set the printer for thicker paper try user defined setting. no promises.
Apr 19, 2009 | Broderbund PrintMaster Gold 16 for PC
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    Custom print size help Kodak 5500
    if you are running windows vista there is a built in roadblock to being able to add any custom size pages. You have to turn off user account control by going into control panel, users, user accounts and then turn on/off user account control. After you do this you can add any size you want then if you want the added safety go back and turn on the user account control. Hope this helps and happy printing!
    Dec 06, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
    Printing greeting cards
    try printing from ms publisher or photoshop. it sud work
    Nov 14, 2008 | Epson Stylus CX8300 Printer
    Software users guide fro Brother MFC 5840cn
    You can download the manual in pdf here:
    http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/colormfc/mfc5840cn_all.html?reg=us&c=us&lang=en&prod=mfc5840cn_all
    install memory card. press scanner button. choose scan:card and select quality and type. there are somemore infos given withi the software manual (which can be downloaded, too).
    Dec 13, 2007 | Brother MFC-5840CN All-In-One InkJet...
    27 people viewed this question
    k24674
    jasbo
    jasbo
