Myvizio vbr333 player powers up but only stays on a few seconds before power shuts off. Ive unplugged it and reconnected it several times with same results...
SOURCE: Mitsubishi WS-55809 55 won't power up
Where is the reset button?
Posted on Jan 12, 2008
  • 35 Answers
SOURCE: Tv won't stay on
i have seen this before and it may be the front power button being stuck and when your remote turns it on the stuck button turns it back off again. I have an older mitsubishi that will not boot up right sometimes and i have to unplug it and plug it back in fot it to come on. I used to pick up broken tv and fix the power buton and resell them
Posted on Mar 27, 2008
  • 3 Answers
SOURCE: beeps 2 times & a warbling noise when trying to boot up - unplugging power lead & pressing ON/Off button & reconnecting power lead starts up OK - but it can be OK for several days & then repeats the p
The Cause of Problem:
The Power Buttons electrical circle sometimes just braked it by one of sensors and the result is the 2 beeps and Power Supply is in protected mode error.
The whole computer is turn off but the power button is turn on and this is the nub of the matter. Because if you want turn on the computer you can't because already turn on but just the Power button and you can't do anything.
The solution:
You need just change the Power Supply and don't do anything just the power cable put into the Power Supply after turn off computer.
Finaly change back the Power Supply.
Posted on Apr 25, 2009
  • 460 Answers
SOURCE: Kenmore Elite QuietPak 2 powers up and shuts off within seconds
I need the serial #, to better assist you
Thank you
Posted on May 13, 2009
  • 8 Answers
SOURCE: Sanyo 24" flat DS24425 suddenly turned off, won't turn on
Solution to the won't turn on or turns on and turns off in 3 seconds my Ds24425 did.
First thing is very important...unplug the TV and let it set for 24 hours before you proceed.
The voltages inside a TV are EXTREMELY HIGH and proceed with caution!
Place the set face down on a towel on a table and remove the back cover....hex screws around the perimeter and 1 phillips screw near the inputs.
The main board will slide up and out. unplug the degausing coil "white plug with two wires" and the speakers connector. This will make it easier to turn the board and take a look.
What I found with mine was a bad electrolytic capacitor. You can identify I bad cap "capacitor" by examining the tops of each one for bulging or signs of overheating "melted or bubbled plastic covering." The cap in question was C626 with a value of 1000uf, 16volt. I replaced with a 1000uf, 35volt and it works perfectly. The cap is located about center of the board. Carefully unsolder the cap and remove, make sure to install the new cap with the proper polarity...the board is marked with a dot indicating the negative lead of the cap.
Be sure to reattach the white plug and speakers connector and slide the board back into the plastic grooves. Then replace the back cover and test. Good luck! ...Daddio
Posted on May 24, 2009
Control panel intex portable spa does not work
ive seen this happen a few times if letting it stay unpluged for like an hour or two and then reconnect power cord doesnt fix it , Im gonna bet it got water inside it by splashes and ruined it
Sep 30, 2014 | Pool & Spa
All lights on my HP309A are blinking
1. Remove the USB cable (or parallel cable) from the back of the printer
2. Remove any memory cards, USB sticks, or any other media from the printer
3. Remove the power cord from the back of the printer
4. Wait 15 seconds then reconnect the power cord
5. Wait for the printer to finish its power on cycle and then reconnect the USB (or parallel) cable
Oct 07, 2012 | HP Photosmart Premium C309A All-In-One...
Dell desktop won't stay shut down
Here's a resource on Dell that might be of use:
Apr 10, 2012 | Dell OptiPlex GX520 PC Desktop
My Philips 20PT633 has started shutting off mid program.
Consult your technician there is a semiconductor problem inside your tv. Probably lose connection, and need to resolder.
Jun 08, 2009 | Philips 20PT633R 20" TV
Thank you
May 12, 2009 | Kenmore Dryers
Akai tv
The power supply most likely failed on your LCD.
How old is your LCD?
Jul 26, 2008 | Akai LCT3201TD 32 in. LCD Television
Going back some time ago, I believe that in this model of set, if there is a power supply failure, the sleep timer will show as activated.
I suggest calling the JVC service rep to find out details for this. I believe the power supply will have to be changed. Also, the tech will check the set to find the cause and service it as necessary.
Jerry G.
Oct 31, 2007 | JVC AV-27D302 27" TV
Televison & Video Logo
Top Televison & Video Experts
