Question about Saws
Looking for metal yoke Magna Shopsmith Jigsaw 502275
Is there a repair manual for this planer?
iFixit: The Free Repair Manual
iFixitiFixit is a global community of people helping each other repair things. Let's fix the world, one device ... We stopped by the European Parliament in Brussels to show some folks there how to fix their phones. The repair-focused ... Fix the Planet.
Shopsmith Repair Manual Planer -
Shopsmith Repair Manual Planer. Shopsmith jointer manual - free eBooks download. Shopsmith jointer manual download on free books and ...
Dec 02, 2015 | Tools & Hardware - Others
I have a Parkside precision pendulum-action jigsaw, model number PPHSS 730. It has three blades... two for wood, one for metal.... but how can I tell which is for metal?
The one for metal will almost certainly have the smallest teeth. Sometimes the metal one will a wavy tooth set - that is, if you viewed the blade from the front, there is a sine-wave shape to the tooth set pattern. (Tooth set means the tips of the teeth are bent a little bit to the left or right to make the cut just a little wider than the rest of the blade so that it doesn't get stuck in the cut.)
Good luck.
Feb 10, 2013 | Makita Jigsaw Blade
How to remove sensor from magna trac 102
The only way to remove the sensor tube, is to pull on the ribbon cable until it comes out of the metal tube. It wrecks the sensor tube. Only do it, if you have a new sensor tube to put back in.
Jan 12, 2013 | Berger Instruments Magna-Trak 102 Metal...
My bosch jigsaw keeps saing sideways!!!
could be the yoke inside that is loose, unplug the tool and lock the blade in and see if you can turn the blade by hand. also make sure that you are using the right shank blades and lastly is the locking mechanism fully engaging the blade. Let me know the model number if none of these help and I will look at an explosion for you.
Mar 18, 2010 | Bosch T-Shank High Speed Steel Jigsaw...
I have my indoor ice dispenser set for cube and it only dispenses crushed. How can I get it to reset back to cubed ice?
Easy fix.
Pull the ice bin out a couple inches.Look underneath the ice bin at the back wall of the freezer. You will see a hole in the back wall with a yoke device in it. The underside of the ice bin has a metal arm attached. The metal arm must go inside the yoke in the back wall.
Push the ice bin in until it seats in the locking tabs and the arm is inside the yoke.
Nov 20, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
I am trying to locate a 20 year old Total Shop 5 in 1 Tool Manual
Are you looking for a Shopsmith Owner's Manual? I have from 15 years ago.
Apr 28, 2009 | Saws
I need a free manual for a shopsmith mark v
I found something on amazon. Take a look: Amazon com shopsmith mark manual I hope I have helped. Cheers
Apr 16, 2009 | Saws
Refrigerator Maytag MSD2454GRQ - Ice Dispenser Yoke
I think this manual should be relevant to your fridge. Page 61 I think will give what you are looking for much better than I may be able to describe, let me know if it is still being a problem as I suspect the pressure that keeps the yoke on is what you are having problems with.
Nov 06, 2008 | Maytag MSD2454G Side by Side Refrigerator
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
