Question about Pool & Spa
GARDEN LEISURE SPA TECHNICAL MANUAL FOR S/n; GL17628 tRYING TO FIGURE OUT THE FUSES AS THEY KEEP BLOWING, THEY ARE LABEL F1, F2 AND F3 BUT CANNOT LOCATE WHAT EACH FUSE IS FOR
    Top Expert:
  • Pool & Spa Master
  • 6,951 Answers
Possible heater element or pump bad
Posted on Sep 13, 2017
  • 2326 Answers
SOURCE: Fuse locations on Technics SA-DX930
This model It does not appear to have F2 anywhere, I've checked the service manual and could not find it nor is listed in the parts list.
Posted on May 14, 2008
  • 588 Answers
SOURCE: the fuse bloww try replacing it but keep
Has this air conditoner been running on these fuses for awhile, and is it just now starting to blow the fuses? If so then have a short in the air conditioner. If this is the first time you're trying to run this unit on these fuses, then you need to check the rating plate on the air conditioner for the full or rated load amps and see if your fuses or the outlet rating will carry the amps the unit is drawing.
Posted on Aug 10, 2009
  • 8404 Answers
SOURCE: Need manual for Leisure Bay spa
Go here http://www.spasbyleisurebay.com/ and click on Spa Manuals.
Posted on May 16, 2010
  • 7 Answers
SOURCE: 2002 Isuzu axiom cluster lights and tail lights out
With the help of kori105's tester and after 3 hours of chasing and removing every thing from the dash I found the problem to be the factory anti theft I moved the wires around an the buzzer came on and the test light went out. The anti theft is located in the dash next to the glove box its black with one wire harness with a bunch of wires going to it. Thanks for the tester idea it worked great
Posted on Mar 03, 2012
searcher1974
  • 229 Answers
SOURCE: Fuse for my turn signals on Yamaha yzf r6 keep blowing fuses can't figure out why
Judging by the rats nest of wires underneath your seat,...this may take some time to figure out. You have a direct short to ground on the power wire for the turn signals. Few questions......are you using led bulbs in the turn signals? Have you added a integrated taillight? Are you running anything else off of that circuit?..(neon lights,etc.) Have you checked the bulbs to make sure they are in correctly,and that the socket wires arent touching the inside of the socket?
Posted on Sep 28, 2012
I have got a service manual for you which will help you out.Please CLICK HERE
Goodluck..
May 14, 2008 | Technics SA-DX930 Receiver
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How do I get it to go into bios when pressing f2 doesn't work?
Per the internet site, it depends upon the model of laptop. Here are some examples:
Laptops - Access Bios Settings Key
Issue
The most common Access Bios key is the "DEL" button or "F2". This depends on the laptop model, however, and can be confusing if you do not know which key to press.
Solution
Here is a list of laptop models and brands with the keyboard commands / key for accessing the BIOS Setup:
Acer: F1, F2, CTRL+ALT+ESC
ARI: CTRL+ALT+ESC, CTRL+ALT+DEL
AST: CTRL+ALT+ESC, CTRL+ALT+DEL
Compaq 8700: F10
CompUSA: DEL
Cybermax: ESC
Dell Laptops:
Dell 400: F3, F1
Dell 4400: F12
Dell Dimension: F2 or DEL
Dell Inspiron: F2
Dell Latitude: Fn+F1 (while booted)
Dell Latitude: F2 (on boot)
Dell Optiplex: DEL
Dell Optiplex: F2
Dell Precision: F2
eMachine: F2
Gateway 2000 1440: F1
Gateway 2000 Solo: F2
HP (Hewlett-Packard): F1, F2 (Laptop, ESC)
IBM: F1
E-pro Laptop: F2
IBM PS/2: CTRL+ALT+INS after CTRL+ALT+DEL
IBM Thinkpad (newer) Windows: Programs-Thinkpad CFG.
Micron: F1, F2, or DEL
Packard Bell: F1, F2, Del
Seanix: DEL
Sony VAIO: F2
Sony VAIO: F3
Tiger: DEL
Toshiba 335 CDS: ESC
Toshiba Protege: ESC
Toshiba Satellite 205 CDS: F1
Toshiba Tecra: ESC then F1 or F2
Toshiba Notebook [Newer models]:
  • Turn on the computer by holding down the power button while pressing the ESC key
    • The machine will beep, then display:
    • Check System, then press [F1] key.
  • Release the ESC key
  • Press the F1 key
Laptops Access Bios Settings Key
Apr 03, 2015 | Computers & Internet
IZE FUSES GO INTO A BALLY STRIKES AND SPARES PINBALL MACHINE
There are several fuses. All are 3AG size. On the Rectifier board you need:
F1=10 Amp 32V
F2=3/4 AMP, 250V SLO-BLOW
F3=4 Amp, 32V
F4=5 Amp, 32V
F5=20 Amp, 32V
F6=3 Amp, 32V SLO-BLOW
On the solenoid driver board you need:
F1=3/16 Amp
Nov 01, 2014 | Video Game Consoles & Games
Garden leisure spa
check to make sure you are getting 220 to it if not the check breacker
Sep 07, 2013 | Pool & Spa
The remote keeps needing to be reset
I would say the f1,f2,f3,f4, is speeds on the fan motor.If you turn the unit on to cool then I would say you need to keep the fan running all the time.But need to run it med-high or high speed to give good cooling.
Apr 07, 2009 | Heating & Cooling
Buttons
F1, F2, and F3 are the strength of the fan blowing the air conditioner. F1 circulates the least amount of air, F3 the most. I generally find that if the air conditioner isn't getting the job done on F1, F2 will do it. I typically only use F3 if I just want to circulate air fast in my place for awhile. As far as what is "better" with closed vent or open, that depends on what you want to do. If you are using air conditioning on a hot day, then vent closed is better because it will cool only air circulating in your place. Vent open will allow fresh air in from outside, and if it's a really hot day, the air conditioner might have a harder time cooling off the fresh air than the circulating air inside your place (as it's continually being cooled repeatedly by your air conditioner).
Jun 10, 2008 | Goldstar M1003R Air Conditioner
Pool & Spa Logo
69 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
