Question about The Computers & Internet
How can I go to place and come back the same way
Where does the spacer go that fell out from behind air filter back plate when I removed bolts
If the spacer is like a small tube and the bolt will slide into it, it will probably need to be placed between the the back plate and the place that the bolt threads into. If you look at the back plate you may be able to see the outline of where it was. Sometimes reassembly is easier if you can put the bolt and spacer in place in the back plate and then put it into place.
Mar 06, 2015 | Cars & Trucks
Tip
How to Change Lid Switch on Roper RAS6233KQ Top Load Washer
<span>Disconnect both hot and cold water line from the water inlet valve. Mark the hot and cold so you don't get them mixed up. There are 2 philips head screws at the back of the machine, holding down the console to the cabinet. One in each rear corner. Slide the console forward slightly and tilt back. There are 2 metal clips that hold the cabinet and top to the back panel. Use a screwdriver and pry both clips up. ( pay attention on how to put the clips back). Disconnect the harness to the lid switch. Now stand in front of the cabinet and tilt forward towards you while pulling forward. Cabinet should slide forward. Once the cabinet has been separated fro the back panel, lift the lid up. On the right side of the lid you will see 2 screws. remove screws. (theses are the screws that secure the lid switch to the top). Now go to the back of the cabinet at the opening and look in the corner where you just removed the 2 screws, You will see a green ground wire screwed to the cabinet. Should be a 5/16 screw. (not 100% sure). Remove screw. there are 2 small clips holding the tubing for the wire harness in place. Popping both clips out should release the lid switch. Now disconnect harness holder from the top of the cabinet by pressing in the plastic clips at the side. Pay attention to the direction of the plug. Put the new plug in the same direction as the one you removed. Once you have inserted the plug and it snaps back into place, thread the tubing back behind both metal clips and clip those back in place. Secure the ground wire back to the cabinet. Now mount the lid switch back to the cabinet. You can do this with the lid up. Secure both screws into the lid switch. Close and open the lid to test the lid switch. You should hear a clicking sound. Now its time to put the cabinet back on. <br />Standing in front of the cabinet, tilt it forward towards you and line it up with the base frame. Tuck the front bottom lip on the cabinet under the lip of the base. Make sure that the tabs sticking up from the base lines up with the bottom of the cabinet. Be patient, may take you awhile to get the cabinet back in position. <br />Slide the back panel forward back in place. make sure it tucks into the back of the cabinet. Once its in place, now you can reinstall the two metal clips that secure the back panel to the cabinet. reconnect the harness to the lid switch. Tilt the console back down into place inserting the tabs on the side into place on the cabinet. Once in place slide the console backwards into place. You can now put the 2 screws back that hold the console to the cabinet. <br />That should do it. Plug the washer back in and start using.</span>
on Mar 18, 2011 | Roper RAS6233KQ Top Load Washer
How to re-close the back plate on a Dakota time/date warch?
Some of these watches have a notch where the stem goes. If you don't have the back in place it will not snap back into place. Also some are a slight screw back and will snap off, but when putting them back you must kind of screw it back in place. Good luck.
Jan 28, 2015 | Dakota Watches
I have clippers model number HC95WV. I can not get blades back together
Ok place the small metal cutter on top of the large metal comb, place the white plastic piece into the top of the cutter with the protruding bit at the back, place the metal bracket with 4 holes on top first locating the front into the white plastic slot, then place the last metal bracket on top with the raised part to the front, then simply hold it all together and put the screws in form the back!
Hope I got the right blade style!!
Mar 18, 2014 | Conair Health & Beauty
O want to install a new key . What are the steps ,please
A key falling off of a keyboard might be an annoyance, but it is not a reason to buy a new keyboard. Regardless of which key falls off, it can be replaced fairly easily. Although the method of replacing typical letter keys is a little different than replacing the space bar, replacing either of these types of keys can be done in a few minutes.
Carefully pry the key from the keyboard next to the key that has fallen off. This key can easily be pried by sliding a flat-head screwdriver underneath it and popping the key out. Be careful to make sure the key retainer underneath the key stays in place, especially if the key retainer has also fallen off the key you are attempting to fix. Look closely at the key retainer underneath the key that was just removed. Notice there is a notch in each corner of the key designed to hold the key in place. Place the key retainer back into place if it has fallen off the key you are trying to fix. Make sure it is positioned exactly as the key retainer next to it is. Put the key on top of the key retainer. Use your index finger to firmly push straight down on the key to lock the key back into place. Do the same to the key that was taken off to view the other key retainer. b> Replacing the Space Bar b> Turn the space bar upside down and use a flat-head screwdriver to separate the retainer from the back of the space bar key. Place the retainer into its place on the keyboard. The retainer will hook into small hooks on the left and right sides. The small metal bar from the retainer should line the bottom of the area where the space bar will be placed. Put the space bar back into the place where it belongs. Spread the ring finger, middle finger and index finger across the space bar, and push firmly until the key snaps into place. Put the space bar key back in place and gently press on it with fingers until it snaps back in place.
b>
Jan 16, 2013 | Computers & Internet
How to change battery my one touch horizon glocumeter.
The OneTouch Ultra uses a three-volt lithium battery. When this battery requires replacement, you'll see a flashing message on the display screen. Changing the battery should take you less than five minutes.
  • 1
      Turn the OneTouch Ultra off, and then turn the unit over to view the back.
    • 2 Push the plastic tab on the battery cover upward. This unhooks it from the unit. Pull it off to view the battery.
    • 3 Lift the battery out of the OneTouch Ultra. Set the new battery in its place. Make sure the "Plus" sign faces upward.
    • 4 Place the battery cover back in place and push it to snap it back on.
  • Nov 27, 2011 | Exercise & Fitness
    Need to install memory on a veriton Z290G desktop but dont know how to open the computer
    1 Turn off your computer and all the peripherals connected to it before
    opening it. Then unplug all cables from the power outlets.
    2 Place your computer on a flat, steady surface. If your computer is in the
    vertical position, rotate the plastic stabilizers and lay your computer on its
    side.
    3 Turn the screws counterclockwise to release the cover.
    4 Hold the sides of the cover with both hands.
    5 Slide it back about an inch and then gently lift it upward to detach it.
    6 Remove the side panel.
    7 Locate the memory DIMM socket on the mainboard.
    8 Press the holding clips on both sides of the memory DIMM socket outward
    to release the memory DIMM (a). Gently pull the memory DIMM out of the
    socket (b).
    9 Align the memory DIMM with the socket. Press the memory DIMM into
    the socket until the clips lock onto the memory DIMM.
    The memory DIMM sockets are slotted to ensure proper
    installation. If you insert a memory DIMM but it does not fit easily
    into the socket, turn the memory DIMM around and try to insert it
    again.
    10 Align the cover's hinges to the housing frame; then gently push it in to
    slide it back into place.
    11 Secure the cover with the screws.
    Oct 03, 2011 | Acer Veriton Z290G 185 320GB
    HOW DO I CHANGE MY REAR BRAKE LIGHT?
    Open the Back and unscrew the tail light screws on the inside of the door jam. The whole tail light assembly will come out. Twist the bulb socket counter clockwise, pull the bulb out. Place new bulb in the sockett, place sockett back in tail light and turn clockwise till it stops. Place tail light back in hole, put screws back in to door jam to hold tail light in.
    Feb 26, 2011 | 2007 Suzuki XL-7
    Havde a bulova mens quartz with a snap on back. removed back and replaced battery. lined notch for stem but I can not get the back to snap back on no matter what I do. what do you suggest.
    Try this method:-
    place the watch on a flat surface (putting a cloth under it to avoidd scratching the face), place both thumbs on the back of the watch opposite the the notch.
    Lean on your thumbs and work them around the edge until you reach the notch point and then increase the force until the back clicks into place.
    Try this two or three times and if you still cannot get the back to click into place, then I suggest that you take it to a Boluva dealer (which I'm sure will cost you!) but it could be that a special press is needed to put it back on.
    Dec 06, 2010 | Watches
    How do i put a key back on?
    as long as none of the key has snapped off, just place the key back in it's correct place an press firmly and increase the pressure in the middle, it should just click back into place
    HPC
    Feb 25, 2009 | Dell Inspiron 3800 PC Notebook
    Computers & Internet Logo
    21 people viewed this question
    Top The Computers & Internet Experts
    Perry Ralston
    Level 1 Expert
    ashu k...........
    Level 1 Expert
    ted dux
    Are you a The Computer and Internet Expert? Answer questions, earn points and help others
