Question about Intex Pool & Spa
I have an intex pool 12x24 the siderails are boeing in while filing ,will they get straight when the pool is full?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Yes
Posted on Jul 04, 2017
mattofilms
  • 110 Answers
SOURCE: Air in pool
you need to look at all intake pipes and seal ('O' ring) around pump skimmer box.
Use a bucket of water to tip over pipe work (while pumping) see if you can see where leak is.
Go to your pool shop and get some multipurpose pool lubricant used on o-rings and gaskets - put on all seals.
http://www.poolcenter.com/service_repair_supplies_sealants_lubricants.htm
Posted on Jul 07, 2009
  • 22 Answers
SOURCE: crooked ''legs'' intex pool
Should be ok, it really depends on the angle, mine are prolly a few inchs off on some, but im not worried with mine. im pretty sure you will be ok.
Posted on Jun 17, 2010
  • 8404 Answers
SOURCE: I have a 8500 gallon
First thing to do with a new set up is remove the metal. The green is very likely copper in the water. Use a sequestering agent to remove the metal. Follow the directions on the bottle.
Second, establish the alkalinity at any number between 80 and 120 with 100 being the goal. Use Bicarb of Soda to increase or Muratic Acid to reduce.
When you have alkalinity of 100, try to get the pH at any number between 7.2 and 7.8 with 7.4 being the goal. Carb of soda to increase the pH and use Muratic acid to reduce. Move slow.
When the Alkalinity is at 100 and the pH is at 7.4 introduce Chlorine. The goal should be between 4 ppm and 10 ppm, since you are not an inspected pool. You should introduce Cyanuric Adic (AKA stabilizer) to a number between 50 and 80 ppm. Stabilizer will protect your chlorine, the chlorine you will be making from the salt in the water.
Next establish the salt level ata the point required by your system. I dont know what Intex requires in fact. I think it is a number between 2600 and 3400 - olease refer to your manufacturers instruction for this. Introduce the salt through a skimmer for best results. BTW, the water has to be hotter than 55 degrees F for your salt cell to make salt.
The Green could be algae - treat by super chlorinating your pool with liquid or powdered chlorine of your choice. I suggest at least 20 ppm.
Cloudiness is undisolved solids. Best way to clear this is by running the filter. The longer you run the filter, the cleaner will be the water. You can use a product called Super Blue which will aid in clearing the solids from the water. If you are impatient, you can use a flocking agent in the filter. I dont think you relly need it, however.
Tell me more about your pool is it rectangular at 12 X 24 (how deep) or is it 12 feet round 24 inches deep. I was trying to calculate the actual gallons. Provide the info and I will get the gallons though you claimit is 8500.
Thanks for your question @ FixYa.com ... please come again any time. Please remember to evaluate the response.
Posted on Jul 28, 2011
  • 8404 Answers
SOURCE: I have a 12x24 rectangular
I am not an expert on your particular Intex model ...
I believe your pressure readings are with in normal parameters. Is your water clean?
Is it balanced? Your goals should be Alkalinity of 100 (no less than 80 and no more than 120, pH should be 7.4 (but no less than 7.0 and no more than 7.8) and your chlorine should be 5 ppm. I recommend a DPD test kit Cyanuric Acid should be about 50 but no less than 40 and no more than 80. Cyanuric Acid is also called stabilizer. Its function is to protect the chlorine you are making in your cell. Refer to your owners manual for how much salt you should have in your pool. 3200 ppm salt is a window to shoot for. You can get a test kit for salt. Salt, like calcium, is persistent in the water. The only way salt and calcium get out of the pool is through back washing, splash out and what you carry off with your swimming attire. Chlorine is affected by the sun and materials introduced into the water by the swimmers as well as what jumps, falls or hops into the pool. pH is not necessarily affected by the sun but the other factors do come into play. A properly balanced pool (alkalinity-wise) will not have pH "bounce". If your pH is bouncing, that is an indicator that your alkalinity is out of whack.
If your pool is 4 feet deep, you have about 8,640. Your goal should be for a 8 hour turn over rate (your pump should be pumping no fewer than 1,120 gallons per hour). BTW, studies show that if you run your pump 24/7 with a 8 hour turn over rate, it still takes up to 5 days for every drop of water in your pool to actually pass through the sand.
You could install a flow meter in your return line. It is simple to do - drill a hole in the return line and attach the meter. Rule of thumb - a 1.5 hp motor (probably bigger than yours) will move about 50 to 70 gallons per minute through a 1/5 or 2.0 pipe. A 2 HP motor will move between 60 and 80 gallons per minute through a 2 inch pipe (and filter, of course). Get a flow meter at your full service pool supplier. It will come with full particulars.
With a clean filter (note the pressure) you should back wash when the pressure increases by about 10 PSIG (Pounts Per Square Inch on the Gage) from the pressure when clean.
I hope this information helps you ...
Posted on Aug 04, 2011
  • 49170 Answers
SOURCE: 12x24 above ground Intex pool
if the motor is humming , it could be a seized pump or failed start/run capacitor for the pump
go for the capacitor first
Posted on Jun 01, 2016
Jun 01, 2016 | Plumbing
I forgot to put one leg in the thick band of an intex pool, it is now full is this going to be a problem
They're designed to use all components shipped with the pool!
You make the decision, but I would say...
Put the other leg in!
Dec 28, 2014 | Intex "" Metal Frame Pool Set (56998e)...
I have a 12x24 rectangular intex pool that came with a sand and pump filter system model # 15110.My Q is; when pump is runnimg what psi should be on the sand filter gage.We read about 8 to 10 psi now,look...
Aug 01, 2011 | Intex Automatic Salt Water System for ...
How much salt to I add to an intex saltwater pool that is 18x48?
all depends on what kind of intex 18x48 straight wall blow up ring and so on
Here is a link to the manuals look up pumps I think it is the top choice even if it is not your filter open it and go to pg 17 and look up your pool it is 135 to 160 pounds depending on your pool
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
Jun 19, 2010 | Intex Automatic Salt Water System for ...
Crooked ''legs'' intex pool
Jun 12, 2010 | Intex Krystal Clear Model 635 Pool Filter...
My sister lost the manual. where can i get another?
The full range of manuals is available on the Intex site, see http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2010&source=intexstore&gid=2&lid=12125 for salt water system manuals (and access to other manuals for Intex products, for example pools, filters, boats, etc.)
May 31, 2010 | Intex Automatic Salt Water System for ...
My intex saltwater system pump is beeping ''91'' meaning ''low salt level''. Do I need to just add salt again?
Yes, and be sure to keep up with your pH as it will want to rise slowly over time when using a salt water chlorine generator.
Dec 06, 2009 | Intex Automatic Salt Water System for ...
Air in pool
May 21, 2009 | Pentair Challenger High Flow Pool Pump 2...
Pool & Spa Logo
161 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
