Question about Samsung Rugby SGH-a837 Cell Phone
How do you disable the PTT button on the Samsung Rugby? I do not
I'm desperate. If there isn't a conventional answer how about some super glue on the PTT button?
1) Pry the PTT button out with an exacto knife.
2) Cut the center post off the back with the exacto knife.
3) Reinstall.....very easy fix takes 30 seconds. PTT will never work again.
Posted on Jan 16, 2010
Testimonial: "Perfect solution! Completely solves my problem with a very simple, very quick and totally effective solution. Thank you!!"
  • mcchips Oct 30, 2010
    Went to ATT
  • pokerfacej23 Feb 22, 2011
    i have a question..ptt is not activated by at
How do you remove super glue from a keyboard?
Short answer: You can't.
Long answer: Super glue is designed to glue things together permanently, but it can be dissolved with the right chemicals. I am not sure that those won't dissolve the keyboard itself though.
Sep 07, 2014 | Dell Computers & Internet
Where is the "do not disturb" setting on a Samsung Rugby?
This is related to the Push to Talk function:
PTT Settings
1. In Idle mode, press Menu -> PTT and press the Select soft
key or the key.
2. Select PTT Settings and press the Select soft key or the
key. Choose from the following options:
• My Availability: this option allows you to change your Availability
status. Use the Up or Down Navigation key, to highlight Do Not
Disturb or Available and press the Select soft key or the key.
You can find the manual here:
http://images.comparecellular.com/phones/1362/samsung-rugby-ii-user-guide.pdf
Oct 21, 2013 | Samsung Rugby SGH-a837 Cell Phone
I read the comment about removing 4 small screws on the faceplate of the samsung rugby, but there were two rubber covers over the top screws. Not so with the bottom screws. How do I get to them?
If the rubber covers are over the screws, you will need to remove them to get to the screws. This isn't very difficult. The easiest way is to jut try to peel them off with your fingers, but if that doesn't work, try to wedge a small flat-head screwdriver under it to peel it off. There should be enough adhesive after you do this that they should stick right back on, but if there isn't, you may have to glue them on.
May 06, 2011 | Samsung Rugby SGH-a837 Cell Phone
How to disable ptt button
easy just get a safty pen and a drop of superglue and run it in the crack of the ptt button let it get hard then u have solveld the problen id and my samsung rugby 2 works fine i don't have to worry about every time i go to open my phone that dam ptt message
Jan 13, 2011 | Samsung Rugby SGH-a837 Cell Phone
From what I have read, there is no setting to disable the PTT
If you don't plan on using your PTT in the future.
Look for the PTT button on the left side of the phone.
Take a pin slide it under the button and pop it off.
On the back of the button, there is a little tab.
Take a nail clipper and shorten the tab just a bit.
Snap the button back on the phone.
With the tab shortend, the PTT will not activate when pushing or hitting the button.
Aug 24, 2010 | Samsung Rugby SGH-a837 Cell Phone
How do you disable the PTT button on the Samsung Rugby? I do not use Push to Talk, but I keep getting the "Would you like to initialize PTT service?" question every time I accidentally hit the PTT button....
Stick your fingernail or a thin blade between the button cover toward the front side of phone. Pry it out just like would the charge port cover. Cut off the protruded part of the button cover (this is the pusher stick that activates the real button), and then press the button back in place.
Now the button is no more but looks functional, the only caveat is that if you suddenly decided you want PTT to work, your button is dead unless you can aquire a new button cover somehow.
Jun 22, 2009 | Samsung Rugby SGH-a837 Cell Phone
Samsung Rugby SGH-a837 Cell Phone Logo
4,675 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
