My machine would not fill and cycle - Washing Machines
My wtw57esvw does not fill on any cycle. Any way
I don't know this model but the answer to your question is no unless it is a top loader.
Does the machine make a humming noise when it is on the fill cycle? If so then it is a problem with the fill hose knined or the filter where the hose is fixed to the machine. If it is a cold fill only and there is no noise on the fill cycle then the fill valve may need replacing. If it is a hot & cold fill, then it is unlikely that both valves have gone.
Oct 01, 2014 | Washing Machines
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
WDSR2120J washer will not fill in rinse cycle
possible 3 solutions for this problem 1 could be the cold fill solenoid 2 could be brushes in motor 3 could be main pcb
Feb 20, 2013 | Washing Machines
My Maytag Neptune will not go into the spin cycle, instead the letters "nf " come on the display. What can I do to prevent this and to have the cycle completed?
NF = No Fill the control board receives signaling for the washer during the water fill cycle. With most cycles the depth of water is around 3.5 inches in the wash basket. I know a Bulky Wash cycle selection will fill the wash tub to a high fill which is about 7.5 inches of water in the wash basket.
Is the washer filling the machine with any water? Do you hear water entering the machine? If you are doing a cold water fill and there is no or very little water in the wash basket with the NF error code. Try a Warm or Hot fill and see if the machine will fill and start the wash cycle.
Assuming you are doing cold water wash loads. You could have a water line block at the inlet screen or a failed cold water inlet valve which will not open. Try the above and let me know the results..........Rich
Sep 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Sometimes my new machine will not fill with water
make sure that your drain hose is coming up ( 90 degrees ) from the base of the machine. and then drains near or close to the height of the machine. the drain hose at least needs to be at a 45 degree angle to fill properly otherwise it will continuosly drain. hope this helps.
Oct 18, 2009 | Washing Machines
Water filling oo last cycle
if only leaking on rinse cycles would suggest checking door seal for small tear as water level is higher on rinse.
Oct 23, 2008 | Fisher and Paykel Washing Machines
Washer fills slow only in the rinse cycle
ck and clean screens first both sides be sure hoses are not reversed timer has no affect on fill rate if screens are clean replace valve
Sep 19, 2008 | Kenmore 24032\24036 Top Load Washer
Water only fills the machine in certain parts of cycle
a 90* wash will fill mainly with hot water / a 40* wash will fill mainly with cold water, this is normal action, rinses fill up with cold water only
is this what you are describing, if so thats normal, especially if its doing the job correctly
Oct 14, 2007 | Frigidaire GLTF530DS Front Load Washer
Washing machine does not stop filling
Does the machine start working normally after turning the wash cycle manually ?
Feb 15, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
