I HAVE A 2010 MODEL # W10280516 TOP LOAD WASHER NEVER USED BEFORE IT IS NOT FILLING AND CYCLING
the dr
  • 447 Answers
SOURCE: Kennmore Top load washer Model 110 20432990
Lid switch is broken
Posted on Sep 28, 2007
SOURCE: my washer won't stop filling
I have a Maytag that had that problem. Mine has a plastic tube inside of the machine that connects to a sensor. As the water level rises, some of it goes into this tube creating air pressure on a sensor that signals the machine that the water is at the selected level. The bottom of the tube had come loose and just needed to be put back onto the fitting. I accessed this tube by lifting the top of the machine, and it is in the back. Very easy to get at. I hope this works for you.
Posted on Sep 22, 2008
SOURCE: Maytag Top load FAV6800AWW won't stop filling with water
I had the same problem. The laundry room was flooded. After running the diagnostic check on in the machine it could not find the problem. Although I went to the http://www.servicematters.com/maytag_library/html/index.html website and went through the troubleshooting table and turned the cold water valve on and off, numerous time. The valve leaked intermittently which is why some people couldn't reporduce the problem. This is a $5 solenoid that was sticking and it caused me to flood my home. I'm not impressed with Maytag's (Whirlpool) engineering. The sould have a safety shutoff valve independent to the water valve that is tripped closed when the level switch is activated. This unit was manufactured in Florence. The damn Italians must have build this cold water valve after a wine break!
Pete
Posted on Nov 05, 2008
RescueTech
  • 145 Answers
SOURCE: when washer is filling it makes a load screeching noise
Hi, welcome...
Your water pump is going bad most likely. This is easy to diagnose and also easy to repair. Under the control panel on top is a "tech sheet" that explains how to put the washer in "test mode". Set the machine in test mode and run the water pump independently and you will probably hear this same "schreeching" sound. The water pump runs at the begining of the wash cycle to recirculate the water and mix the detergent with the incoming fresh water. You also can "check" this by using the "PERMA PRESS" cycle. The perma-press does not use the recirculation feature, so the schreeching noise will be delayed to the first rinse cycle if the pump is bad.
The part number is 420325P and you can get them from http://www.fisherpaykelparts.net
Posted on Feb 01, 2009
  • 5 Answers
SOURCE: GE front load washer model #WBVH6240FWW leaks when
Check the big rubber seal around the door for any holes or tears. Had the same problem, my husband had a screw in his pocket that torn a hole in the gasket.
Posted on Sep 27, 2009
Kitchenaid top loading washer makes noise when filling
Did you check the hot and cold shut off valves if they have calcium build up it might make a noise. Try replacing them.
Jun 20, 2012 | KitchenAid KAWS750L Top Load Washer
When washing machine not being used the water drips into the washer tub, it is top loader about 12 yrs old
if the washer is filling up on it's own the water valve is bad,sediment gets inside it doesn't close all the way allowing water to leak through. they show two different valves,when you talk to your parts guy bive him the full model number off of the washer and they are asking for a series number either 83 or 87 so you get the correct valve
Mar 08, 2011 | Maytag Neptune MAH5500B Front Load Washer
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Water leaks when filling
Use a putty knife at the top front corners to release the spring catches. Lift up the top. Examine the plastic thing that delivers the water to the tub, it may be cracked or out of place.
Apr 05, 2009 | Maytag LAT3600A Top Load Washer
My etw4300tq0 washer will fill up with water, then stops.
etw4300tq0
Same problem... any help out there I see this post is over a yr old... it is now dec 29, 2010 and I have the same problem.
Mar 23, 2009 | Estate ETW4400VQ Top Load Washer
Washer won't stop filling and go to next cycle automatically
if not running over ck to be sure drain is proper height and end of washer drain hose is not too tight in standpipe sound like siphoning after 1st wash and not filling to advance to rinse also be sure washer dring hose is not more than 6-8 in into standpipe
Aug 15, 2008 | Kenmore 24032\24036 Top Load Washer
Leaking waher
water can leak from the other valve while filling up if you dont have the hose on it,if you blank the valve off with a nut and tail with a coin and rubber washer in it that will fix your problem.hope this helps.
Mar 09, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
