Question about Samsung Dishwashers
I just got the code SE on my Samsung dishwasher. It has worked great for 6 years. Fix or replace??? Thanks for your opinions
4 Suggested Answers
SOURCE: i am recieving an SE
I'm getting the same message too. I turned it off for awhile and I had a technician come out and take a look. My drainage pipes are all clear (SE code can mean that drainage is not working properly). He suggested that I get a "Samsung" tech out to take a look at the circuit board/electrical issue. Want to know the crazy thing? This is my second dishwasher that Samsung replaced....all the same electrical issue.....and just last week someone called me to see if I wanted to buy an extended warranty on it. Hmmmm.....do they know that this a piece of junk? It was an expensive dishwasher too.....doesnt clean any better than my cheap model did and it sure has a lot more problems in this first year than the whole 5 years that I had my other dishwasher. Can you tell im disgruntled?
I would love to hear if there is a simple fix to this SE problem.
Posted on Oct 06, 2010
SOURCE: SE error code on Samsung dishwasher
5E code. If your dishwasher has been running fine for awhile then throws a 5E code chances are it could be the pump or a blocked hose or filter but chances are its not. 1. Does the code come on after it has gone through the wash cycle and released the soap dispenser? or 2. Does the code show afer 1 or 10 minutes of running without the wash cycle completing, soap dispenser still closed?
Number 1 is easy to check just diconnect the drain hose and run the hose into a bucket to see if the hose or filter is clogged or pump is working. These machines only use about 2 gallons of water and the pressure is very low its easy to do in a bucket. If number 2 occurs, its not a clogged hose or filter or pump issue the machine is not even cycling.
If number 1 checks out ok you have water flow but shuts down and number 2 has occured, its your Case Level Sensor its the electronic solid state float, DD94-01006A its either sticking due to water impurities or its bad.
Its actually pretty easy to trouble shoot or fix. You have two choices but the machine has to come out. The sensor is located behind a metal plate on the lower left side ofthe machine. You can;t miss it it looks like a float, has a black float inside a clear plastic housing and some wires going to it. You can pull it out and clean it (The float should go up and down with no sticking at all). Or just buy a new one $35.00ish and put in. Also check the inlet hose to the float make sure its clear and clean DD67-0057A.
There is one catch to this that can cause lots of grief if ANY water at all comes out of the float while changing it. If any water gets in the bottom of the catch basin underneath, the very very sentive probes will detct it and throw a LE code and the washer will not work. that is not a big deal just need to pull the basin off and dry it out. The smallest amount of water can cause the sensors to react since its a protection system.
Samsung dishwashers are very quite and wash extremely well but there technology and engineering sucks along with their warrenty and repair manuals there are no manuals for the home owner or much for the repair guy.
That float will have problems again and again and again either its dirty or broken and will cause another 5E code situation.
Side note; food grinders in a dishasher are stupid! All dishes places in a dishwasher should be rinsed! A domestic dishwasher should not be used as a disposal. It makes your house stink and tons of bad bacteriea will grow in places you do not want it to, not to mention they are not made to work like you would think.
Best dishwasher with the least trouble, easy to fix, easy to dignose, easy to work on, good manuals, few problems, good warrenty, best built, quite running, washes great, very well engineered is BOSCH.
Terry
Posted on Dec 21, 2012
Terry Corrow
  • 10875 Answers
SOURCE: how to fix samsung dishwasher code se
5e Drain problem Check drain hoses
Replace drain pump
Posted on Apr 21, 2015
How to fix samsung dishwasher code se
The code is 5E
If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose.
If the drain hose is kinked, there will be an excessive amount of water in the bottom of your dishwasher after a cycle has been completed.
In order to access the drain hose you need access to the back of the dishwasher. If your dishwasher was recently installed, contact the installer to move the dishwasher and inspect the drain hose.
If the drain hose is not kinked, but your dishwasher is still not draining, service is required.
Apr 21, 2015 | Samsung Dishwashers
How do i fix an SE error code on my Samsung dishwasher
The SE or 5E error code means "Draining Error", which coincides with what you observed. First check the drain hose for an obstruction, especially where it goes into the garbage disposer (and check the garbage disposer port to make sure it is clear too). If that's okay, then you will have to pull the dishwasher out to check the drain pump. Chances are, some foreigh object has gotten into the drain pump, and is blocking or partially blocking the water flow. If everything is OK, then you probably have a bad ECS sensor, and will have to replace it. If most of this is beyond what you want to do, at least check the hose at the garbage disposal end before you call a repairman.
Feb 10, 2015 | Samsung DMT800RHS Dishwasher
I would never in my life buy a Samsung dishwasher again. only three years old and PE error code comes back after having service tech out 6 times to replace parts weve been without a dishwasher for 6 m
We have had constant problems also...even went as far as taking the dishwasher apart. Did somewhat fix one problem by removing a piece of plastic that had gotten into the water pump. It still wasn't "right" so we talked with Lowe's about our problems and they finally agreed to sell us another dishwasher at a greatly discounted price and offered free installation. It was installed yesterday. It's a GE, not as "pretty" as the Samsung but hopefully it will actually wash the dishes.
Jun 28, 2014 | Samsung DMR78AHS Builtin Dishwasher
What is an se errer code on a samsung dishwasher
SE (or 5E) means "Drain Error" or "water not draining". Check the drain pump and drain hose for any obstruction, of course, If okay, replace the ECS sensor.
May 19, 2014 | Samsung Dishwashers
What does samsung dishwasher error code se
SE (or 5E) on a Samsung DishWasher means Drain Error - Water not draining. Check the drain pump and drain hose for an obstruction; If that's okay, you will probably need to replace the ECS sensor.
Apr 21, 2014 | Samsung 24 in. DB5710DT Stainless Steel...
Error code PE on Samsung dishwasher DMR78AHS
I too have the same problem with my dishwasher. Didn't know about the circuit breaker trick. Will give a try. My husband is ready to throw all our Samsung appliances in the trash. We don't recommend them at all. Re-modeled our kitchen 4 years ago and had all new Samsung appliances installed. What a mistake. In the 1st year we had 2 service calls on the dishwasher, 2 on the stove and 1 on the refrigerator. Have had many problems with the dishwasher. Have been in touch with the company but their approach is you bought it your stuck with it. Thanks for the trick to fix PE error code. I'm NOT getting it fixed. I'll use it till I can't use it anymore then go buy something else.
Aug 24, 2012 | Samsung DMR78AHS Builtin Dishwasher
I have a newer Samsung dishwasher and a Code SE is flashing what does this mean
I have a Samsung dmr77 dishwasher and the code SE is coming on and it doesnt sound like there is water coming in the dishwasher. What does this code mean?
Feb 12, 2011 | Dishwashers
SE error code on Samsung dishwasher - ...any suggestions?
This means that the Dishwashers has detected a condition it needs to check. Press "Cancel" to clear the display and to stop the beeping sound, then try turning the Dishwashers off and on again.
If you still see the "
SE error code," turn off the power to your Dishwashers and wait five minutes before turning it on again. If you hear the beep or see the "SE error code" when you try to washing again, please call your authorized provider for service.
Hope this help?.
thanks for visit.
Dec 15, 2010 | Samsung 24 in. DB3710D Dishwasher
I am recieving an SE code on my samsung dishwasher. I tried to reset the dishwasher by switching off the power to the machine for 20 minutes. still SE message
Sep 25, 2010 | Samsung 24 in. DB5710DT Stainless Steel...
F8 / Convection portion of top oven doesn't work
F8 Oven door lock failure Check lock relay and door switches.
Apr 02, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Dishwashers Logo
Top Samsung Dishwashers Experts
Rod
Rod
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
