Question about Toro Garden
I need a cap for my 14" toro trimmer. I have the spool but no Cap. Is that all I need and where can I buy the cap? Thank you
SOURCE: changing spool on weed trimmer
useless
Posted on May 10, 2008
SOURCE: grasshogXP string trimmer GH1000-ca type 2 7.2 amps
You can order replacement parts from:
http://www.toolpartsdirect.com/cgi-bin/noframes.cgi/blackdecker/CST2000_TYPE_1
Posted on Jul 14, 2008
MNfisherman
  • 11896 Answers
SOURCE: I need part for a Craftsman Weedwacker
You can either go to sears, or craftsman website or even easier if you can get one off of ebay
Posted on Aug 18, 2009
radar001
  • 1051 Answers
SOURCE: How do you remove the line spool cap on a toro
There are 2 tabs, 1 on each side of the cap. You need to press these in at the same time to pull the cap off.
Posted on Apr 06, 2010
rycgl
  • 1545 Answers
SOURCE: I have a craftsman weedwacker model 257 799750 and
Spring, spool then cap....if that way doesn't let the line out correctly, then it is possible you have wound the line on the spool in the wrong direction. Try taking the line off and winding it on the other way.
Posted on Aug 07, 2010
Toro tb65ss upper string head removal
  1. Pull the spark plug wire from the top of the spark plug. Bend the wire to the side to prevent accidental starting.
  2. Place trimmer on its side with the trimmer spool head facing you. Press the two tabs on the side of the spool head with your fingers.
  1. Hold side of the head and slowly allow the head cover to push away from the inside of the spool head. There is a spring between the spool head housing and the spool that pushes out when releasing the cover.
  1. Pll the knob and spool out of the spool head. The spring should come out on the back of the spool.
    Electric Trimmer
  1. 1 --> Unplug the Toro trimmer power cord from the electrical outlet.
  2. 2 --> Lay the trimmer on its side. Hold the spool housing tight in one hand and twist the cap counterclockwise with your fingers. If necessary, use a pair of large slip joint pliers to start turning the cap. The cap is the center piece of the spool.
  3. 3 --> Pull the cap off the spool and remove the spool from the housing.
Apr 26, 2014 | Garden
Broken trimmer spool and bump
73-8490 is the spool assembly part number. If you need the cap as well that part number is 105-9422
Sep 08, 2012 | Toro 51347 11" Electric String Trimmer...
Gettin spool off to change string
1.Twist the cap off counterclockwise.
2. Remove the cap and spool.
Note: If the spring falls off, install it before installing the spool.
3. Thoroughly clean the cutting head and cap and inspect them for anydamaged or worn parts.
May 29, 2011 | Toro& Electric String Trimmer
Does Toro still make 88035 spool cap replacements? I cannot find them anywhere.
According to this large online parts distributor, that part has been discontinued.
http://www.partstree.com/parts/?pn=88035
I found this one on Ebay....it looks like the spool with the knob for a 10" electric trimmer. I tried!
http://cgi.ebay.com/TORO-PREWOUND-SPOOL-ELECTRIC-TRIMMERS-PART-88180-/280505426528?pt=LH_DefaultDomain_0&hash=item414f6d2260
May 14, 2011 | Toro Electric Trimmer
I have an electric 13"
you can try a smaller string size, this should help. Tim
Apr 24, 2011 | Toro& Electric String Trimmer
My Toro 12" Trimmer (Weed eater) needs a new screw down cap to hold the spool in place. Home Depot no longer carries them. That's wheree I got the last two Weedeaters.Please give me instructions as to...
Your Toro electric trimmer parts are readily available through www.partstree.com . However, to avoid having to pay $10 in shipping for a $5 part, you should try to find your local Toro dealer. They probably have the part in stock. Go to www.toro.com and search on the dealer/distributor locator to find your closest dealer.
You will need to know the model number (5 digit) and serial number for your trimmer. These can be located on a small sticker on the trimmer.
Oct 14, 2010 | Toro& Electric String Trimmer
How do you remove the line spool cap on a toro electric trimmer?
Apr 06, 2010 | Toro Electric Trimmer
I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I have an 11" Toro trimmer and was having trouble deciphering the symbols on the base. The key is having a method to gain some opposing force to unscrew the cap that holds the spool. I have an oil filter wrench called the round wrench. It is a steel bar with an attached length of rubber belt that can tighten around cylindrical objects. I used that to oppose the unlock direction on the trimmer and "voila", no tabs to push no trick with the button, you just need o_1089.jpg_1088.jpg_1087.jpgpposing force.
May 26, 2009 | Toro Electric Trimmer
Garden Logo
18 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
