Question about RCA HD52W59 HDTV Projection Television
RCA 52" Convergence Problem
TV is basically in 3-D at this point; Picture is bent; Found Convergence on the TV Setup Menu; Autoconvergence did not work; Unable to move the crosses in any direction when I tried to do it manually.Please help :) I love my TVJeanette
  • RCA Master
  • 8,617 Answers
Replace the convergence power supply. You can get the ITC222A convergence power supply board at the following link under RCA circuit boards.
http://www.tvrepairworld.com/
Posted on Jul 25, 2009
52" rca hdtv has a shadow ghost when it plays. It
convergence issue. Press menu and then scroll down to the setup option enter setup and scroll to Autoconvergence and activate the auto convergence feature that will realign the convergence . If that doesnt correct the issue you will need a Convergence power board, If the auto convergence feature is missing from the setup menu then you need the convergence option missing repair kit. Both the board and the repair kit are available from www.tvrepairworld.com
Jun 18, 2011 | RCA D52W23 52" HDTV CRT TV
Convergence
IF in customer setup menu there is no convergence option then there is a possiblility that a special fuse that when blown makes think it s tube tv and then it removes convergence. I dont believe i have seen this problem on this set however. Otherwise it might be one of three different boards. there is one other possiblity that i see. the autoconvergence feature has been turn off in the service menu.
Dec 20, 2007 | RCA HD52W56 52" Rear Projection HDTV
How do I access the menu to get to the auto convergence setting. My screen has lost its autoconvergence.
Than this RCA DLP tv have convergence fuses.Convergence fuse is dead.U have a soldering iron, desoldering pump or desoldering braid and can u do basic soldering? Replaced convergence fuse FL231 that near the right FBT.The one in the Middle out of the three useally dead.Try Ebay.com to buy the FL231 convergence fuse.
Jan 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA r52wm24 projection hdtv. Colors of tv not aligning images look like they are in 3d without glasses.
this is called convergence.the first step in diagnoseing this set is to go into customer menu under the setup option. DO you have the donvergence listed in this menu. if you dont read this http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in. if you do then try using autoconvergence and manual options in this menu. if it doesnt work then more than likely you will have some faulty components in the convergence cuircit. let me know and ill seel if i can help more
Oct 30, 2010 | RCA R52WM24 52" HDTV Projection Television
How do I get the double vision out of my tv
double vision? is this multicolored. red green blue? is the picture bowed. Have you tried going to setup in customer menu and adjusting convergence, Both manual and autoconvergence.
Oct 22, 2010 | RCA HD52W56 52" Rear Projection HDTV
I am getting a red tint around other red items on the screen especially on espn. I also see a green verticle streak.
Try adjusting the convergence. Go to the TV menu and select SETUP then CONVERGENCE. Select AUTOCONVERGENCE
Dec 29, 2009 | RCA HD52W56 52" Rear Projection HDTV
Green auto convergence
The master convergence settings have to be close for the Autoconvergence to work. If they are not you need a technician to go into the service menu and adjust them.This is a long job and you can't do it yourself.
Mar 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
3 color lines at top of screen no picture
If you do not see convergence in menu when you go to setup then you have a open fuse FL231 Next to flyback transfomer on right side there is 3 in a roll small brown rectanigler looking caps they are fuses the one in the middle is bad replace it .
Feb 11, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA Rear projection had a 3-d like picture. one red one blue and
Go to menu then setup if you do not see convergence on menu then FL231 is open replace it then do auto convergence.
Jan 02, 2009 | RCA D52W23 52" HDTV CRT TV
RCA 52
ok go into setup menu.... go to convergence.. try to adjust convergence .. does the crosshair move up and down side to side... if not then you might hqve q poblem with convergence power supply if they move then u might have s setup issue
Mar 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 HDTV Projection Television Logo
507 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
