Question about In Office Equipment & Supplies
How to rectify error code C94 in photocopier machine studio 212
SOURCE: konica photocopier 7115 with error code (cof32)
Check out this post
http://smarka.com/members/boards/content/CTmessages/46344.htm
Posted on Mar 12, 2008
  • 158 Answers
SOURCE: error code C0202
this is a tray 1 lift up failure code pull the paper tray out and check to see if some torn paper is blocking the lift sensor look around where the paper is fed into the feed plates if not it could be a failed lift motor or sensor and they will need to be replaced
Posted on Dec 02, 2009
SOURCE: How do I clear machine error code E04-01 on a
How do I clear machine error code E04-01 on a Panasonic DP-3030 photocopier?
Posted on Sep 20, 2010
SOURCE: how to reset error code f14 in the photocopy
guys please help me how reset error code F14 for Toshiba copier model no. 167
Posted on Oct 01, 2010
  • 19 Answers
SOURCE: Hello, I turn on my Toshiba E-Studio 166 Photocopy
Poor contact of the fuser drawer connector may cause the following
error codes: C41~C46, C4A, CD5, E01, E03. To correct this issue, a
spacer (see SPL p25 item 1 attached) has been added between the
fuser connector and the frame; also the springs (see SPL p24 item 8
attached) have been changed to provide more tension.
This change has been applied since January 2003 production:
e-Studio 550 TA314824
e-Studio 650 WA312627
e-Studio 810 XA311627
Model P-I Before Change After Change
e-ST550 25-1 --- 6LA14365000
e-ST650 SPACER-DRW-CNCT
e-ST810 24-8 6LA08946000 6LA14468000
SPC067-070-140 SPC068-080-160
Posted on Jan 26, 2011
When i switch on ma toshiba e studio 212 its showing me error c26. how can i fix it
it is cis unit error check connection between cis unit and main board otherwise replace cis unit ribbon OR cis unit OR main board
Feb 06, 2014 | Compatible Toshiba T1810 For E Studio 181,...
Toshiba e studio 212 photocopier machine change the toner but massage low toner
The toshiba machine e studio 212 is zerox actual image on in side tray but we are select out side try the image is shifted on output paper.
Aug 16, 2012 | Compatible Toshiba T1810 For E Studio 181,...
Dear sir, i have toshiba e studio 212 photocopier machine I change new toner but give the massage toner low
on out side tray the actual image is garbage left side 1 inch but in side tray select the image is actual printout
How to reset error code f14 in the photocopy machine toshiba e-studio 160
Jul 29, 2010 | Toshiba E-Studio 160 All-In-One Laser...
I have a Toshiba e-studio 150 copier. L-1 error code flashing
hi there is problem L-1 means that u have problem CCD MCU Harness Disconnect
May 12, 2010 | Toshiba E-Studio 161 Copier
''toshiba e-studio 720 error code c473
This is an overvoltage error....Really need a tech to fix this...could be bad wall voltage....or the thermostat in the IH unit...or the fuse in the IH unit...or the logic board....
Oct 31, 2009 | Toshiba E-STUDIO 720 Copier
Toshiba e-studio 45call for service 254292
Press "clear/stop" and "8". While holding this combination of keys down, an error code will be displayed....what code are you getting?
Sep 15, 2009 | Toshiba e-Studio 45 Black and White Copier
46 people viewed this question
Top In Office Equipment & Supplies Experts
Jason
rugby prop
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
