Ariston ARWDF129 the door light keeps flashing when I take the machine off pause. The is also locked. I have tried resetting by unplugging but this did not work.
The problem started when i tried to open the door before the cycle had finished. I though I put it on pause then tried the door latch. Tried unplugging, flipping the breaker still flashing. I also tried to change the setting but still didn't change. I also drained the water from the drain at the bottom of the machine. The last two washes i noticed a bit of suds left on the door( not sure if this has anything to do with this) I managed to use the manual door mechanism to open the door so I was able to remove my cloths however I can't use the machine now. Any idea what this could be
SOURCE: can't open door of lg wd-1018c washing machine
Hi, I don't know if this is much help to you now as it has been a while since you posted your problem. I had the exact same problem and after a lot of swearing and 2 days and no help what so ever from LG I took matters into my own hands.
I took the top off the the machine and removed the small steel plate, you will know what I am talking about after you have done the same.
I had my hubby hold the tub back as far as possible and used a screw driver to release the latch which is at the front of the machine about half way down. You will see a small silver steel knobby looking thing. After the machine was finally opened I unscrewed the screws on the inside of the door and used a flat screw driver to prise the housing apart. Be careful not to drop the glass window as when the housings start coming apart the window is no longer secure.
I found that a small piece of plastic on the handle had perished and broken not allowing the correct function. A phone call to Sunstate spare parts got the new handle to me within a few days at a cost of $20.95.
My only problem now is putting the bloody thing back together. I have been at it for 3 days with no sucess. If you manage to work out how to put yours together please let me know. I hope this has helped and hasnt come too late.
Cherie.
Posted on Nov 20, 2008
  • 3 Answers
SOURCE: Bosch Dishwasher SHV4313GB/17 Wont switch off !
Introduction: This may work for your problem, but only if you're finding that you cannot get further water to flow into your machine. If your machine fills OK, then this ISN'T a solution to your problem. If your machine doesn't fill but your drain motor continues to hum for no apparent purpose, this may work.
I have a Bosch SHV. My sink drain backed up, and the water accumulating in the sink then migrated to the dishwasher, through the drain pipe, causing the dishwasher to fill up and, it turned out, overflow a little. When I turned on the dishwasher, the water drained, but no new, clean water came through the hot water pipe. The drain just kept running, but nothing else happened.
Here's what happened. Under the main chamber of the dishwasher, by three inches or more, is a white plastic tray. It sits almost at the floor, and it may not be obvious that it's a tray capable of holding water. The overflow water spilled into that tray, which in turn caused a float in the far left side of the tray to lift (the way a toilet float lifts when the water fills in a toilet tank) and shut off the water intake valve (like the toilet float shuts off the toilet water flow). So long as that valve is closed, your machine will not run.
STOP: disconnect power supply at this point for safety.
To see the white plastic tray and thereby fix the problem, you'll need to take off the BLACK TOE-KICK (attached on my unit by two star-head screws at its bottom) and, possibly , the OUTER PANEL OF THE DISHWASHER DOOR (in my case, a custom wood panel (attached by a few screws through the inner side of the door, two screws that are accessed by popping off little--smaller than a dime size--covers on the sides of the doors, and then the door panel lifts up and out). (I took the outer panel off, but I can't remember if I would have had to reach into the white tray without doing so.)
Once you do that, you can see the white plastic tray. It doesn't come out--at least not without removing the entire machine--so try this. You can take your fingers and feel over and into the tray. You'll probably feel the water--I did. Look at the far left of the tray with a flashlight. Back there you'll see a flat, round, 3-inch diameter piece of white plastic sitting at the bottom of the tray. To its center is a generally U-shaped lever looking device, which, at its far left end, is connected to a red stick pointing up into the machine. When water goes into the tray, the float rises, causing the U-shaped lever to rise, causing the red stick to raise, which (though I couldn't see it) causes an electrical signal to run to, and shut, the valve for your water intake.
I took paper towels, and then a narrowly cut sponge, to sop up the water in the tray. I then took my shop vac and, using it as a blower, blew what little water was left right out. You might be able to use a hair dryer, but first sop out what you can or it'll take forever. Once you've done that, put everything back together and plug your dishwasher back in. My buttons are at the top panel. To reset, hold down the two buttons marked for clear drain for three seconds and release. You should be able to start up then. It took 15 seconds before the water started to run, but it did and the machine works fine again.
Interesting note: The valve that stopped the water from flowing in automatically opened once I got the water out of the tray. You don't need to reset the valve.
Good luck.
Montpelier Man
Posted on May 09, 2009
mgprice
  • 744 Answers
SOURCE: My washer won't complete the final spin cycle. It
Hello, problem here is the spin control board is bad. Remove panel under the door and you can locate the spin control at the rear right of the machine screwed to the floor. Replace it and you will be all set. Mike
Posted on Nov 09, 2009
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
  • 3 Answers
SOURCE: hoover optima hnf6167 7kg washing
My washing machine completes its cycle but is leaking water from the left hand side on to the floor, Why is this???
Posted on Apr 25, 2010
Ariston arwdf 129 error f13 flashing what does its mean?
I've had a quick look through the instruction manual, but was unable to find anything.
http://www.aristonappliances.us/_pdf/manuals/ARWDF129.pdf
Perhaps contact the manufacturer for more information?
http://www.aristonappliances.us/raccontaci.asp
Nov 10, 2014 | Washing Machines
The error message "door" is displayed and the machine won't start. I can I reset it.
I have Blomberg WM87120 NBL00 Product code 717518110 and had flashing Lock in display. Bought and installed new lock and no change. Display still flashing lock. Used following procedure and every is working now.
Press pause button and hold down while turning off machine.Continue to hold pause button and turn power back on. If numbers come up on display make note of them for future reference. Release pause button and all lights on display will light up. Turn power off again and then turn back on. If machine was in a cycle it should end it and then return to normal operation. .Dont know if new lock made a difference. Try the reset procedure first.
Dec 08, 2012 | Blomberg Washing Machines
F-28 flashing. Door will not open
While the machine is on press "end of cycle" for 3 seconds, then wait for 2 minutes to try the door. Try this again if it does not open, this is the child lock program - to lock and unlock; it is the same procedure.
Check your washer plug to see if the connections are tightly screwed. You can also plug off for half an hour to reset.
How abt a nice rating for the free help? Thnks
May 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi 1000XC Washing Machine - Pause Light Flashing
The ECU is failed. unplug for 40 minutes to try to reset it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Washing Machines
Timer light keeps flashing
sounds a s if you have ablockage within oyour pump assy, remove th elower acess panel and undo the "button trap" your problaby clogged up, the drain pump is humming, causeit cant pump any water
Jan 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door locked, start pause light flashing
I also have the same problem. I have got it to work by unplugging for a day and night. When I plug it in the next day it works like new for a couple days and then back to the same old "door locked" problem when the door isn't locked........BIG HEADACHE!!!!
Jun 11, 2008 | GE WSXH208A Front Load Washer
Maytag front loader door will not open
try pause/cancel twice to open door open detergent disp look for a plastic string and pull it
Dec 31, 2007 | Ariston Technologies AW129NA 16 Lbs Front...
Paused. now stuck. cannot open, turn off, etc.
Unpluggin the machine is pretty much the only way to reset it.Leave it unplugged for a couple hours if that doesnt work its most like a control board issue
Mar 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
