Question about Sony Televison & Video
Sony bravia kdl 40v4100 whats the fix to my screen issue? Is also there on the menu screen.
  • 4234 Answers
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Posted on Jan 05, 2009
  • 197 Answers
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
Posted on Jun 09, 2009
  • 4 Answers
SOURCE: tv bravia kdl 40v3000 problem turning on
To wayne: The balancer board is in fact available by itself. You can get it at many different parts depots here on the web. I just suffered from a similar problem, on the same tv and it solved my problem perfectly (Stupid 13 blink, blink code...)
The searchable part number is SSB400WA20. Its referred to as a voltage inverter (for the backlight of the lcd panel.)
Good luck!!!
Posted on Jul 08, 2009
falter
  • 245 Answers
SOURCE: Sony Bravia KDL-46V4000 tuned to digital mode has
YOU LIVE IN A BAD RECEPTION AREA WHERE DIGITAL IS NOT WORKING WELL......
LOOKS LIKE U HAVE TO SWITCH TO ANALOG.....
UNTIL THIS PROBLEM IS SOLVED IN UR AREA.....
Posted on Nov 20, 2009
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
Looking at a negative screen
Sony Bravia KDL-40V4100 models have a problem with the screen going blank, faded or washed out ( negative ghosting) . It is caused by a bad chip on the T-con board. A replacement chip is available from shopjimmy.com (Sony 55.40T02.C08 T-Con Board Component Repair Kit) for $14.95- If your not an excellent solderer, send your board to them for a repair $69.95.
Feb 11, 2014 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Tip
Sony Bravia KDL-40V4100 LCD TV user manual
Looking for free copy of owners/ user manual for Sony Bravia KDL-40V4100, click that link to download PDF file of required owners/ user manual.
PDF file can be seen on computer by adobe reader software that is freeware and can be downloaded from adobe.com for free.
Please make sure that your computer has adobe reader installed before to download user manual copy. Once user manual appears in browser window, you can save it in your computer to consult it any time or get its print out through printer.
User manual has all operational details about product and will help you to understand all functions, button location on unit, its function details.
Lamp replacement procedure is also written in user manual.
Owner manual gives you info about hooking it to other gears like DVD Recorder, and Computer etc. User manual also suggest some steps of user level troubleshooting before sending it in service center.
You will see many features of unit described in user manual with details with supporting images for easy understanding, menu content list with icons is also helpful for user.
Hope this tip will helps you so hit Yes button as it wont cost you anything :)
on Sep 21, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Sony bravia 40 brightness control not working
Try to reset the tv first from set up menu. then check the brightness control working properly.
Oct 14, 2013 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
KDL-40V4100 service menu
well known information but do you have some problem?
Apr 01, 2012 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Black screen w/ my sony bravia KDL-40V4100 and it will turn on, but there is no picture or sound. I was told it could be a possible issue w/ the kdl 40s4100 board, but I'm not entirely sure. I've...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 10, 2017 | Sony Bravia KDL-40S4100 40 in. LCD TV
I have sony kdl-46sl140.picture is blinking a nd channels and volume is disabled.
It could be something like an ETC-inverter board, or the power board. I have the same TV with a cracked screen. Are you interested in selling yours?
May 12, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
I have a Sony KDL-40V4100, constantly hearing clicking noises
Could be the power board or main board defective, but I suggest you do firmware update first. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 download the software.
May 08, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Sony bravia KDL-40V4100 audio and picture cycling on and off
I'd say about the blinking to a black screen would be your cable provider. As for the stripes that means that your board panels can be going bad, you can try updating the firmware of the TV to help but if that doesn't work you're getting very close to full failure on the TV.
Dec 14, 2009 | Dell E153FP 15" LCD Monitor
Clicking sounds when turning off Sony bravia kld-40v4100
ACTUALLY WITHOUT SEEING YOUR PROBLEM PHYSICALLY I CANN'T SAY ANY THINK, BUT FOR YOUR KNOWLEDGE LET ME TELL YOU NO TV MAKES ANY KIND OF SOUND DURING SHUT OFF. & you are saying for more than 30sec, i think you should call the SONY TECHNICIAN for visit.
Dec 20, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
