Question about Filter Vacuums
My check filter light was on and would only allow me to dry my clothes on the normal setting. After vacuuming the light went off. still can't use another setting other than normal. How do I fix it?
Dc4 has low suction
HI, it's Jim from Crucial Vacuum!
Low suction from your Dyson DC07 can be directly related to basic vacuum upkeep and maintenance. Here's some simple things you can do for your vacuum to help ensure optimal performance and to keep your vacuum running for a long time with great suction.
After every use, make sure to empty your Dyson's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged.
Wash and clean your unit's filter screen weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours. Be sure to allow it to FULLY dry.
Foam and cloth filters should also be washed and dried weekly, by following the same steps from cleaning the filter screen. Do not use any soap, dishwasher, dryer or washing machine to do so. Allow your filters to air dry for 24 hours before re-installing them in your Dyson.
Last, make sure to clear your brush roll of any hair strands or debris monthly and to replace at least every year. When examining your brush roll take note of the condition of the bristles. Are they loose? If so this would be a good time to change your brush roll.
While checking the brush roll you might as well examine your Dyson's belt. With use the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. So if your belt feels loose as well replace that.
All of the previous general maintenance tips will help improve your vacuums suction and overall performance.
You can purchase your replacement parts for your Dyson DC07 direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=DC07&order=relevance&dir=desc&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Dec 29, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Tip
Fed up having to buy new filters for your vacuum?
Over the years I've lost count of how many companies stop selling replacement filters for their long deceased production vacuum models or that filter replacements are becoming increasingly difficult to source. There are usually universal "microfilter" replacements which are easy enough to find and cut to size, but if you can't be bothered to do that, there are ways around to renew your existing filter even if the manufacturer or the user manual states that the filter cannot be washed.
You see, any filter can actually be washed - if it is a single cloth filter - as opposed to a micro pleated section of many layers sewn together. If you have such a filter, a single cloth filter which the user manual says cannot be washed, this is a blatant lie. Remove the motor filter as normal (usually found at the bottom where the paper bag goes) if it is embedded with dirt and wash under a hot tap of water with either household washing up liquid or soap. Once the filter has been completely cleaned, place the filter into a pillow case and chuck into an electric dryer on a low heat. Instead of waiting 24 hours normally for a filter to dry to room temperature, you'll cut your waiting time by a day simply by allowing the gentle heat from the electric dryer to circulate around the pillow case which holds your vacuum cleaner filter. Once the filter is completely dry to the touch and does not feel damp in any way, install back into the vacuum cleaner.
I have also done this with HEPA paper filters which apparently are not washable according to the manual, and to stop the plastic cartridges from bouncing off the walls of your electric clothing dryer/tumble dryer put an extra towel or cloth into the pillow case to minimise damage. What is then revealed is a new, dry and clean filter which can be used again instead of spending lots of money trying to source a new one.
At the same time, if your vacuum cleaner has a soft bag, take it off and put it into the washing machine to give it a clean lease of life - but you won't need to put it into a pillow case to dry in the electric dryer - simply chuck the bag in to ensure it gets dried properly before putting it back onto your vacuum cleaner.
on Nov 16, 2007 | Sebo Automatic X1 Bagged Upright Vacuum
Not picking up seems blocked
check intake at the bottom and the hose definitely a blockage
Oct 31, 2014 | Vacuums
If the filter is clogged would it quit working
Hi there! If the filter is clogged this will cause the vacuum to lose suction and possibly shut-off. Below are instructions to checking and cleaning your filters.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Primary Filter
Exhaust Foam Filter
Hope this helps!
Jun 12, 2014 | Hoover Nano Cyclonic Compact Bagless...
Resetting
Hello! The vacuum will reset itself, you only need to allow it time to cool off.This can take up to an hour. Overheating is usually caused by a clog or a filter that needs to be cleaned or replaced. Below are simple instructions for checking your vacuum for clogs.
7. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the main hose.
8. Remove the bottom plate and the brushes as instructed in the owner's manual. Use a wooden spoon or something similar to gently break up and remove any clogs from the lower hose.
Hope this was helpful!
Primary Filter
Exhaust Foam Filter
Mar 23, 2014 | Hoover Nano Cyclonic Compact Bagless...
My Dyson Animal vacuum smells horribly of dog. It's worse than my dog has ever smelled - even at his worst. How do I take apart the Animal to clean it properly? Can I use a weak water/Chlorox solution...
hi Donna.
Complete removal of pet hair from the home is a quandary many pet owners face. The Dyson Animal series vacuums use centrifugal force to remove animal hair from carpets, floors, curtains and upholstery. The high-powered vacuum is bagless, allowing you to extract pet hair from surfaces without worrying about running out of vacuum bags. As your Dyson Animal vacuum is exposed to pet hair and dander, a smell can develop. Similar to other small appliances, a vacuum needs periodic cleaning to keep it looking and smelling clean. When you use basic cleaning and deodorizing techniques, you can get the smell out of your Dyson Animal vacuum.
Step 1
Remove the bagless receptacle for pet hair according to the directions provided for your Dyson Animal vacuum. Hold the receptacle upside down inside a trash bag and tap the bottom to remove pet hair and dirt.
Step 2
Mix 1/2 tsp. of dishwashing detergent with 1/2 gallon of warm water in a bucket. Dip a clean cloth into the soap solution and wring it out.
Step 3
Wash the inside and outside of the receptacle with the cloth to remove dirt and dander that cause odor. Rinse the receptacle with a cloth dampened with water. Dry it thoroughly with another cloth.
Step 4
Remove the HEPA filter from your Dyson Animal vacuum. Pick visible clumps of pet hair off the filter and discard them. Flush the filter with cool water to wash out dirt and hair. Rinse the filter until the water runs clean. Gently squeeze the filter and allow it to air-dry for up to 12 hours to ensure it dries completely.
Step 5
Moisten a cloth with undiluted vinegar. Wipe off the exterior of the vacuum with the vinegar. Deodorize the receptacle and interior areas, where the bagless receptacle and filter go, by wiping them with the vinegar-moistened cloth. Dry the vacuum with a clean cloth.
Step 6
Place two drops of vanilla extract on a cotton ball. Drop the cotton ball into the receptacle before securing it to the vacuum to prevent odor from building up. Vanilla extract is an effective natural odor absorber.
hope this helps you out.
Nov 28, 2017 | Dyson DC17 Animal Bagless Upright Cyclonic...
My vaccume has little suction
Hello :
1: Check that the Dyson's brushbar knob is turned to the "Carpets" setting for vacuuming non-delicate and raised pile carpet. Vacuuming carpet on the "Bare floor" setting usually leaves a telltale single wheel mark on the pile, and pickup is severely limited.
2:Locate the removable filter on the side of the vacuum. It will be marked with a raised circular representation.
3:Press down on the release button with your thumb as you lift filter housing up and out
4:Examine the filter for debris. Wash the blue foam and yellow framed filter in cold water. (See Tips section.) Let dry for 12 hours. Do not wash the outer filter housing that snaps into the vacuum; simply wipe clean with a dry or slightly damp cloth. Replace the filter when completely dry.
5:Locate the airway inspection valve on the opposite side of the vacuum. Press the release button as you lift the valve up and away from the machine.
6:Remove any debris or clogs you find inside.
7:Use a soft cloth to clean up lighter debris and completely clear the airway valve.
8:Tip the Dyson vacuum over to find the U-bend at the back of the unit. Press the release button as you pull the U-bend down and away from the machine.
9:Inspect the U-bend and remove debris. Be sure to line up the release button as you snap the U-bend back into place.
10:Check all removable pieces to be sure they are attached properly and snapped correctly into place. The soleplate should be flush with the cleanerhead.
What you need for this :
  • Large slotted screwdriver
  • Scissors
  • Washcloth
  • Soft cleaning cloths
  • Household surface cleaner, safe for plastics
  • Crochet hook or similar long-handled tool
Warning :
Unplug the vacuum before doing any troubleshooting. Follow all manufacturer's instructions and warnings. The yellow encased filter and blue foam filter pad can be submerged and rinsed in cold water only. Do not use detergent. Do not wash or dry in dish or laundry machines. Do not dry in the oven or microwave.
PLEASE RATE !
Apr 23, 2010 | Bissell 3576 CleanView II Bagless Upright...
There is no suction to our Dyson animal (purple-approx 8 yrs old)
Hello bnsbryan :
  • Scissors
  • Washcloth
Warning :
PLEASE RATE !
Apr 22, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuuming up water with Shop Vac model 84M200
when picking up dry materials use the foam sleeve that slips on and the blue cloth (assuming there all blue) over it, there should be a ring that slides over blue cloth to hold it in place over the foam sleeve, for wet pick up u can use the foam sleeve minus the blue cloth but let it dry out before picking up dry stuff, you can pick up both wet and dry with a cartrige filter that looks simular to a car air filter and it slips over the foam sleeve, but let it dry out after picking up water before picking up dry cause itll just clog it up
Oct 25, 2009 | Shop Vac 84M200 Wet/Dry Vacuum
Set up the shop vac to pick up water
I figured I had nothing to lose so I just started vacuuming. I thought I had to turn the end of the hose that connects to the shop-vac around (which I did so that it brought the water down to the 'bucket'. Other than that, I even went to Yahoo Answers and asked for input. The answers were - just vacuum, they didnt think there was anything to do with the vacuum to set it up for wet vac. I had removed the cloth filter used for dry vacuuming so I was ok with that. I also saw a YouTube video that said basically to remove the cloth filter. Ok .... that was not so difficult. Thank goodness too.
Jul 26, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Vacuums Logo
Top Filter Vacuums Experts
gbob59
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Filter Vacuum Expert? Answer questions, earn points and help others
