Question about GE Washing Machines
WOULD LIKE TO KNOW WHY MY PUMP WILL NOT DRAIN ON A GE FRONT LOAD WASHER
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Pre filter full, possibly of coins. When water comes out, it goes thru the pre-filter so it wont damage the pump. Remove front and look for a small bag. Squeeze it. If it feels full, empty it. Be careful that that is all you pull because of the way it's attached to the back.
Posted on Apr 26, 2017
GE Washer will wash but won't drain?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 24, 2011 | GE Washing Machines
Howdo you get to drain pump filter on Ge wbvh5200
you'd better ask for after sales service people to help you.It's difficulat and not safe to get to the electrical component.
Mar 14, 2010 | General Electric WBVH5200J Front Load...
GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Feb 07, 2010 | GE WBVH6240F Front Load Washer
The front load washing machine will not drain
Look in the rear for a small door that holds the pump filter.
Drain the washer with the small tube 1st.
Nov 17, 2009 | GE WSXH208A Front Load Washer
GE front load washer- error msg "door locked"
have you checked for any foreign objects in the drain pump itself this if the most likely problem.or the drain pump has completly stop.make sure you pull the drain hoses from the pump and check for foreign objects if there is still water in the unit use a shop vac and connect it to the drain hose to remove all the water before disconnecting the drain hoses. after the water is drain this may unlock the door as well
Sep 16, 2009 | GE WSXH208A Front Load Washer
Locating the filter
based on info provided your ge would be a frigidaire made machine, only filter is at drain pump. to access remove lower front access panel (screws on bottom) pump sits in middle of machine, locate large rubber hose connecting to tub, loosen clamp and pull off. inside is plastic strainer cup, empty and replace. make sure nothing went past to pump, reassemble.
Jul 19, 2009 | GE WSXH208A Front Load Washer
GE WJSR2050T2WW Washer fills up,Spins but won't drain out?
The most common reason for no pump out is a blockage in the pump. Best to drain as much water as possible. (even laying the drain hose down to allow as much of the water to drain out as possible) Un-plug washer. Next, open the front of the washer by using a putty knife to push in and release the clips about two inches in from each side at the seam where the front panel meets the washer top. Pull the front panel forward and lift it off the bottom pegs. Remove spring clamps from inlet and outlet of pump with a plier. Remove two pump mounting screws to allow pump removal after unplugging electrical leads. Remove obstruction from pump. Most pump bodies can be separated if necessary. Reassemble, plug back in and test.
Jan 15, 2009 | GE WDSR2080D Top Load Washer
remove bottom cover ..remove as much water as possible from inside tub remove cleaning port on front of pump by turning counter clockwise..rmove all money lint screws nails be sure to ck into pump itself
May 28, 2008 | GE WBVH6240F Front Load Washer
GE Front Load washer problem
replace the water inlet valve it is seeping water through the valve even though the cycle has finished
Apr 28, 2008 | GE WSXH208A Front Load Washer
Ge front load washer won't spin
replace the drain pump.and 2 remove the control panel u need 2 remove the 3 screws from top cover from the back
Oct 31, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
27 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
