Question about Tablets & eReaders
Kindle paperwite will not turn on even when on power
2 Suggested Answers
  • 3289 Answers
SOURCE: My kindle paperwite will not charge
USB chargeable devices can suffer fwhen using improper or unauthorized (as the case for many cell phones) chargers. Many times, its due to a low current or wattage rating. They all provide proper polarity a voltage of 5 Volts DC, but the amps or milliamps (expressed as "A" or "mA") may be so low that it takes 2, 3 or more times longer than it would with the original charger. Some produce only .3 Amps (300 milliamps) of output current (or 1.5 watts) or less while many original chargers that ship with devices have 3 or more times that output (up to 2.1 Amps or 2100 mA or 11 watts). Watts is simply the product of Volts x Amps. You can use USB chargers that provide more current (amps) than required - but using chargers with lower current or wattage ratings will take noticeably longer to charge devices. Furthermore, use of a low current / wattage charger may not even be able to charge the device - if you're using it at the same time.
Posted on Feb 27, 2015
Deregister kindle
Login to amazon.com, go to My Account, scroll to Digital Content, then click on Your Apps and Devices. Click on Your Devices under the Manage menu, then unregister the Kindle.
Oct 03, 2016 | Amazon Kindle
How do I get out of Safe Mode?
Hi Claudia. I found this.
I found Please remove leather case on your kindle before performing the steps below.
Please press and hold down the power button for 25-30 seconds until the Kindle restarts or Shutdown. If it prompts for Shutdown then please shut down the device and power it back on.
That should fix the problem.
If the answer to your question was informative and helpful, please show your appreciation for my efforts by clicking the green Accept Answer button right below my first response.
Thank you for choosing Experthelp.
Safe mode turns on when you shut down the kindle while the volume button is being pressed down. Solution-Restart your kindle by holding the power button until the screen shuts off. Make sure that the volume button is not being pressed while you restart your kindle. Then keep pressing the volume button, about 10 times to unstick them then turn on the kindle. Safe mode should turn offand how you go into it.
and I found this
Jan 17, 2016 | Amazon Kindle Fire HD
Kindle will not turn on even tho its bee charging 5 hours
Soft Reset:
Hold the power switch for twenty seconds. You will need to slide the power switch along and hold it for twenty seconds before releasing it. ...
Your reboot screen should appear when you release the power switch.
Give your device time to reboot for a minute or two.
Turn the Kindle Fire HD back on.
Jan 01, 2016 | Amazon Kindle Fire HD
Kindle fire will not charge-got a new charger and it still will not charge- does it need anew battery and how do I do that?
The Kindle touch and the Kindle FIre are great devices for your reading needs. However, there are times when it becomes unresponsive and freezes on you. Amazon says it is because the battery isn't charged properly or does not have enough power on it. It is advisable to charge your battery first before trying to reset the Kindle touch/Fire. If theKindle still has issues, then try the steps below on how to reset your Kindle touch/fire. Please note that you may lose your data during the reset process, make sure you have made a backup of your files before proceding.
  • Hard and soft reset
    Make sure the Kindle is turned ON.
  • Press the Power button for 20-30 seconds until it turns OFF.
  • Wait for it to reboot, if it doesn't press the power button to turn it ON.
  • Your kindle should be back to a responsive state.
  • this might help you.
Dec 22, 2014 | Amazon Kindle Fire HD
`kindle fire
Sounds like your power cord is dead and that it's not charging. If it's new bring it back to the store you bought it from and get a new one.
May 15, 2012 | Amazon Kindle Fire
Kindle light is orange when I charge but even after of hours of charging continuous efforts to turn on Kindle, it won't turn on.
Try to slide and hold the on switch until after the power light blinks three times (should happen after a little more than 5 seconds). Release the switch after the blinks and the Kindle should start up.
This is only necessary if the Kindle was switched off by the same method before, or if the battery was completely drained. A short nudge of the power switch merely puts it in and out of a power-saving sleep mode, the prolonged hold really cuts / reinstates power.
Jul 16, 2011 | Amazon Kindle Wireless Reading Device
My kindle dont work
If all attempts trying to unfreeze it fail, you may have a logic board issue. Are you sure the Kindle powers up? It may show something on the sreen, even if it is not turned on (e-ink screen does not need a powersupply to show an image). Try to power up your Kindle with a different battery. If that fails, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
Jun 07, 2010 | Amazon Kindle Wireless Reading Device
My kindle is stuck on a page. It won't change
May 22, 2010 | Amazon Kindle 2
My Kindle froze, how do I reboot it?
there's a little pinhole at the bottom. insert a paper clip to do a hard reset. Or remove the battery and re-insert it to the same effect.
Apr 14, 2010 | Amazon Kindle 2
Tablets & eReaders Logo
43 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
