Question about Refrigerators
Refrig keeps running..sometimes as much as an hour..only three years old..help
3 Suggested Answers
  • 257 Answers
SOURCE: Sub Zero 550 16 years old is running alot more
not a expert just trying to help,, sound like you are have heat problems,, slid out the fridge and take panels of of the bottom and clean the dust out from under fridge if very dusty under there cause the fridge not to cool right ! hope this help you
Posted on Oct 07, 2009
  • 149 Answers
SOURCE: Kitchen Aid Washer (3 years old) does OK
timer bad/ easy fix
Posted on Jan 19, 2010
New refrig 1 year old and it runs constantly. what can I do to correct this problem
if the freg make more ice the problem is th thermostat but if the freg run without good cooling thats mean you micro-gas leakage
Feb 12, 2015 | Frigidaire 20.6 cu. ft. Top Freezer...
Sub-Zero 650 - Keeps turning itself off. The
HI,
Are you having any fault codes along with this issue? Does the fans and light stop working also? This is unusual, is this the G or O model? I need more information to assist you.
Please let me know.
Sep 08, 2013 | Sub-Zero 650 / O Bottom Freezer...
Works for an hour then blows warm. shut it off for two or three hours and it works for another hour or two. unit is two years old 18,000 btu unit
Clean the outdoor coil, slide it out of the case and use a garden hose to it, keeping water out of the rest of the unit, sounds like the coil is dirty, clean it good until the water runs clean every inch of the coils and you should be running again.
Jul 05, 2011 | LG Electronic Window Air Conditioner
Can I lay down an Emerson 4.6 cu ft refrigerator to fit in my car to transport
Even though it's not the preferred method of transport, it's OK to lay a refrig down for moving, even new R134a if you pay close attention to the refrigerant lines.
Determine where the suction line runs up into the freezer. This is the largest tube connected to the compressor, and is usually (though not always) visible running up the back of the cabinet.
As long as the refrig is laid down on whichever side allows this line to stay 'high', there'll be minimal oil migration, and when you arrive at your destination, just stand it upright for an hour or so and it'll be fine. Obviously, the shorter the trip, the better.
If the suction line runs up the door handle side, just duct-tape the doors securely closed before you lay it down to keep them from opening and getting damaged. It helps to lay a block of wood under the top end, just to keep it inclined a bit, too.
I've been moving refrig's for some 32 years now, and while moving them in an upright position IS best, sometimes you just can't. I work out of a van, and have often laid both refrig's and upright freezers down for transport with no ill effects.
May 12, 2011 | Emerson Microwave Ovens
Frigidare refrig. It seems like Freezer still working but not refrig. Temp is now 56 in refrig part. Refrig is not even 2 years old. Fan seemed to be working in refrig earlier but now not at all.
check the damper vent door between the two compartments to make sure its open to let the cold air in from the freezer then make sure the evaporator fan is operating to help push air thru this door,sometimes these doors freeze shut or if its a motor driven vent door the motor could be bad too
Jan 01, 2011 | Refrigerators
After emptying the ice bin on 2 year old side frigidaire, the freezer is OK, but the fresh food side has stopped cooling. Any ideas?
check that the fan in the freezer is running,it circulates the cold air,if it isclose freezer door,open refrig. door lookto the upper left you will see where the cold air enters the refrig compartment and should fill air coming thruough vent this is a motorized unit and they sometimes fail,also check the return air hole located at bottomof refrig.sometimes get blocked by plastic bags etc
Jan 18, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
GE PROFILE REFRIGERATOR-PSC25MSTA NOT WORKING
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
