Question about Uniden Lands Phones
I need to remove block all private numbers on my Uniden home phone, please.
5 Suggested Answers
  • 351 Answers
SOURCE: Barring Withheld and Private numbers.
Dear ,
Go to this website and register your number. I did my several years ago and I don't get unwanted calls.
https://www.donotcall.gov/default.aspx...
Or.... contact the place from where you bought the phone and ask them to block the number.
regards
Posted on Apr 28, 2008
ARTGIRTNY575
  • 96 Answers
SOURCE: Remove block from phone
Hi, I am happy to serve you with this. I have sprint myself. Before you make a call dial *82, area code, and the humber. This will make your number visible. Example:
718-599-5555 you would dial *8217185995555
Go ahead and try. Also ask sprint that you don't need a private number. It seems like they categorized your number as private.
When you do want you number to be private, you dial with *67. The same way as above. This dialing rule applies to phone lines as well.
Take Care.
Artgirlny
Posted on Jul 17, 2008
SOURCE: How to Remove Call Block from Uniden phone
#82 to remove the block from AT&T phone lines. This has to be done before every call if your account is set to block caller ID. Refer to the front section of the white pages if your service is not from AT&T. Beware, some phone companies charge as much as .50 each time you remove the block.
Posted on May 16, 2009
adrienneseri
  • 93 Answers
SOURCE: I pushed the button that said block all private calls on my uniden home phone now every time some one rings from a private number it does not come thru, how do I cancell this, please help me.
I am sending a link to the owners manual. You just need to delete the entry. On pages 30 and 31 it tells you how to navigate to call blocking under the menu. Hope this helps.
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/XDECT_5135_1_OM.pdf
I’m happy to help further over the phone at https://www.6ya.com/expert/adrienne_b03fb46fc6334991
Posted on Apr 23, 2017
Apr 23, 2017 | Uniden Lands Phones
How block phone numbers that I do not want?
Block an Incoming Call
  • Wait until your phone rings and displays the caller ID information
  • Press the "Block" button on your handset.
  • Press "Menu/Select" or "Block" to confirm your decision.
Block in Standby Mode
  • Press the "MENU" button on your phone's handset.
  • Press the down arrow button to select "Call Blocking." Choose "Create New," "Private Number" (block private calls) or "Unknown Number" (block unknown numbers) from the list.
  • Enter the 10-digit phone number, if creating a new entry. Otherwise, press the "Menu/Select" button to confirm your choice.
How Do Block Calls on Uniden DECT 6 0 eHow
May 26, 2016 | Uniden DECT 6.0 Cordless Telephone...
WIFE`S CELL PHONE # IS BLOCKED, BUT IS NOT IN BLOCKED #S
Have her dial *82 before she dials the home number. If that works she has the cell phone set to block her number. *82 should unblock it for just that one call.
Aug 25, 2014 | Asavings Panasonic KX-TGEA20S Dect 6.0 1...
How to block private call to my cellphone
you wouldnt be able to block private calls .... sorry!!!!
Dec 21, 2013 | Uniden TRU8866 Cordless Phone
How do i block incoming phone call from a uniden cordless phone
  1. Block an Incoming Call
    • 1 Wait until your phone rings and displays the caller ID information 2 Press the "Block" button on your handset.3 Press "Menu/Select" or "Block" to confirm your decision.Block in Standby Mode
    • 2 Press the down arrow button to select "Call Blocking." Choose "Create New," "Private Number" (block private calls) or "Unknown Number" (block unknown numbers) from the list.
    • 3 Enter the 10-digit phone number, if creating a new entry. Otherwise, press the "Menu/Select" button to confirm your choice
Oct 14, 2011 | Uniden Cordless Phone
No manual and am receiving unwanted calls at night just became threatening how do i block them
Using Call Block
If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.)
Blocking incoming calls
  1. When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
  2. If you want to block the call and add this number to the call block list, press Block.
  3. When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
  1. With the phone in standby, open the menu and select Call Blocking.
  2. Choose one of these options:
  • Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
  • Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
  • Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
Call block entry options
  1. With the phone in standby, open the call block list and find the entry you want.
  2. Press Menu/select to open the individual entry menu. Choose one of these options:
  • Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
  • Delete - Erase this entry from the list & allow calls from this number.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 20, 2011 | Uniden DECT21883 Trio Cordless Phone
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Apr 30, 2009 | Uniden TRU8866 Cordless Phone
Can't retrieve messages from home answering machine when away
Indeed... YES Wrinkles3,
I can help you a couple of ways...!!
First and FOREMOST...
Go in NOW and edit your PERSONAL & PRIVATE
INFORMATION...
Right now every WACKO on the internet
Knows your NUMBER & INTERNET identity...
(and probably your DEFAULT "pin" code)
You just gave everything ELSE needed))
With very MUCH ease I could enter your home phone...
MONITOR your rooms... Take your messages... (etc.).
Find your Name, address & track family members))
You are seconds away from some
SERIOUS IDENTITY theft issues...
Never post personal information on the internet
>> (seriously).
Generally ...
You need to clear off that INFORMATION
and get paranoid... EDIT it off NOW...!!
On to your question: Your Owners Manual
(please ... oh please HAVE a REAL pin number).
Your page 31: tells you (& the WORLD)... How to
operate YOUR PHONE:
Uniden EXS 9950 Owner Manual Remote Access Away From Home
ELSE
call UnidenDirect at 1-800-297-1023 (your page 36)
7:00 am to 7:00 pm CST
Uniden EXS 9950 Owner Manual Specifications Base Unit
Pretty please... a little caution would go a long way..!!
Carnac the Magnificent
Aug 09, 2017 | Uniden Lands Phones
Take Care.
Artgirlny
Jul 17, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Lands Phones Logo
59 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
