Question about Plumbing
Why does my faucet leak from the handle - Plumbing
    Top Expert:
  • 12,813 Answers
Seal or seat worn or loose
Posted on Apr 23, 2017
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Tip
    How to repair disc-type faucets
    DISC-TYPE FAUCETS
    • Disc faucets may have one or two handles. The water is controlled by openings in the two discs. When the discs are rotated to align, the water flows; when the discs are misaligned, the water shuts off. If the discs wear, the worn discs cause the faucet to leak. Simply turning the handles harder will not stop the leak.
    • To repair a leak in a two-handle disc faucet, turn off the water and remove the handle on the side that's leaking.
    • Use pliers to pull the disc assembly out of the faucet.
    • Beneath the disc unit is the seat assembly, or seal. Replacing this special O-ring may stop the leak.
    • You may need to install a whole new disc assembly for faucets that have been used over a long period of time. In this case, all moving parts of the faucet will have been replaced and should last as long as the original discs did. The parts of some disc units snap apart into a separate bonnet assembly and bottom cap.
    • To repair a leaking single-handle disc, turn off both the hot and cold water and remove the handle to expose the disc assembly. Take out the screws to lift the assembly out of the faucet.
    • You'll notice that beneath the disc unit are three O-ring seals. Though unlikely, water could be leaking between the unit and one of these seals. In this case, you may be able to stop the leak by cleaning the disc assembly and faucet body and installing a new set of seals. If that doesn't work, the entire disc unit must be replaced. This will renew all moving parts.
    • Replacing the unit is fairly simple. Place the three O-rings into their recesses in the bottom of the disc unit. Then install the unit and tighten the screws. Finally, replace the handle–and you're done!
    on Jan 16, 2010 | Plumbing
    Leaking faucet
    Secure your water
    Determine the cause of the leak
    Change the Seal on that side (Double Handle)
    Change Cartridge on Single Handle
    Nov 20, 2012 | Delta Faucet 2100LF Classic - Double...
    Leaky faucet
    Need more info. Is it leaking in between the faucet and hose or the end of the faucet or around the handle of the faucet? If leaking between hose and faucet a little rubber washer will do the trick. If its the faucet it could be inside the faucet. You can buy a new one, or take it apart and take your parts to the local hardware store whom can assist you there. If its around the handle simply tighten screw ontop of handle.
    Nov 11, 2012 | Washing Machines
    How to fix a leaky Moen faucet that leaks at the spout ,which is separate from the handle?
    These faucets can leak in three different places:
    1. Internally at the valve seat
      You'll see water dripping from the spout. This means the rubber washer is worn or damaged. To replace the washer, remove the decorative cap from the handle. Remove the retaining screw and pull off the handle. Remove the decorative cover, called an escutcheon, if there is one. Unscrew the packing nut counterclockwise. Unscrew the valve stem and remove it. Remove the screw that holds the rubber washer in place. Because these washers come in many shapes and sizes, you'll want to take the old one to the hardware store and buy an exact replacement. Be sure to buy two washers so you'll have one for the other valve. Replace the washer and reassemble the faucet.
    2. Around the handle
      If you see water coming from below the handle, the packing nut is leaking. Older faucets have a string-like graphite packing material wrapped around the stem. Newer faucets use an O-ring. First try tightening the packing nut clockwise... about one-half turn. If this doesn't stop the leak, remove the packing nut and replace the packing or O-ring; then reassemble the faucet. If the valve is using the graphite packing material, it might be a clue that you should shop for a new faucet.
    3. Between a pivoting spout and the body
      The spout might be held in place with a packing nut, similar to the faucet stem, or it might have a nut at the top of the spout. In either case, remove the spout and replace the packing material or the O-ring seal. Then reassemble the faucet.
    Single lever faucets also are known as "washerless" faucets. They are easier to repair than compression faucets after you determine what type of faucet you have. There are three types of washerless faucets: ball, ceramic disk and cartridge.
    Leaks are evident in two places... dripping from the spout and seeping from around the spout where it joins the body of the faucet.
    Leaks from the spout indicate that the ball, disk or cartridge is leaking. To repair, turn off the water to the faucet, then remove the handle. The handles on ball-type faucets are held in place with a setscrew that requires an Allen wrench to loosen. Ceramic disk and cartridge-type handles usually are held in place by a screw hidden beneath a cap.
    On ball and ceramic disk-type faucets, remove the ball or disk and replace the seals. You can buy replacement kits for these faucets at the hardware store or home center.
    On cartridge-type faucets, remove the spout and pull out the retainer clip that holds the cartridge in place. To remove the cartridge, pull on the cartridge stem with a twisting motion. If it resists, install the handle so you can a better grip on the cartridge to pull it out. Take the cartridge to the hardware store or home center and purchase an exact replacement kit.
    Reassemble the faucet according to directions.
    Leaks at the spout-to-body joint indicate an O-ring failure. Disassemble the faucet as described above. Remove the spout sleeve and replace the O-rings. It's a good idea to replace these seals if you have the faucet disassembled for repair of the ball, disk or cartridge.
    Sep 10, 2011 | Moen Plumbing
    The main faucet is leaking-when I use the sep. handle the faucet still leaks. Is a problem with a seal in the faucet or could it be a problem with the handle to shut it off?
    if it leaking around the base of the spout...it would be spout o-rings....if it is dripping from the aerator then it is the seat and springs in the handle.
    Oct 17, 2009 | Delta Model 190: Waterfall Single Handle...
    Moen Single Handle Shower Faucet leak...
    the cartridge if defective,replace it and your leak will stop.
    Jul 22, 2009 | Moen & One Handle Tub & Shower Faucet
    Water comes out the shower head without the faucet lever being engaged
    the whole faucet is bad it has an internal leak replace the whole thing
    Jul 03, 2009 | Home
    Repair leaky handle
    Try removing cap of knob and tighten screw it could be loose. If that is not it it may need a new seal ring.
    Apr 21, 2009 | Plumbing
    How to take handle off of Grohe Lady Lux Cafe-took screw out-handle is stuck
    I soaked the connection between the handle and the valve body in a penetrating oil for several hours and eventually used more force than I hoped to use to remove the handle. Once the handle and end cap (part 09 209) were removed, I could see that the valve assembly (part 46 048) was loose which caused water to leak from the seals (part 46 209) between the valve assembly and faucet body. So I tighted the screws that hold the valve assembly to the faucet body and the leaked stopped.
    Oct 11, 2008 | Plumbing
    Plumbing Logo
    Top Plumbing Experts
    Paul Carew
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
