FC on quietside
Indoor unit heads read FC on quietside mini split
  • 958 Answers
SOURCE: Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
Posted on Sep 13, 2008
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
  • 1902 Answers
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Posted on Jun 01, 2009
  • 81 Answers
SOURCE: How to remove cover on fujitsu split system head
The front cover can be dismantled (taken off as one Piece) by unscrewing the screws at the bottom of the air outlet (they are covered by screw cvers which will need to be taken off. Then just pull off the cover. PLEASE NOTE that the front panel (liftable to take out filters) will need to be removed lift up until 90 degrees and then pull off gentley and also take out filters before removing front cover
I take the time to answer you questions so please rate me
Posted on Aug 29, 2009
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
Posted on May 04, 2010
I need to order a universal quietside minisplit remote
Hello, Rebecca -
Are you thinking you can order the remote control you need through If so . . . you cannot. does not sell anything.
Are you asking where you can order the remote control you need? If so . . . the answer depends upon where you reside (what country.), a website intended for asking and answering questions about repairing _things_, receives questions from people located worldwide. Without knowing where you live, I cannot provide you with a list of businesses from which you can order the remote.
Instead, I suggest you conduct your own search, using your favorite search engine. I tend to use Google. Use this search strategy, with quotation marks as shown:
Quietside "mini-split" "remote control"
Most likely the website results listed near the top of the results will be sources through which you can order a replacement remote control.
Note: I hope I am correct in thinking you need a remote control for a Quietside (brand) mini-split heat pump, or, perhaps an air conditioner?
I am answering from the USA.
Best wishes.
Jan 18, 2018 | Universal Televison & Video
Error code E1 and E4
PDF]SERVICE Manual - Quietside
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more:
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
Qshx mini split heat pump leaking
You are going to have to give a lot more information. What is leaking, how fast, etc. If it were the refrigerant you would be out by now. Where is the leak coming from.
Apr 01, 2014 | Quietside QSHX-182 18000 BTU Mini Split...
I have a 24 ton mini split, that has never worked correct. It used to blow cold air, but only for a little while, then it set error codes including p4, and p8. The heat functioned used to work ok. Now it...
Code P8
Error detail Abnormality of pipe temperature.
Inspected unit Indoor. Due to non condensable gas/over charged/condenser dust blocked.
For non condensable gas, remove gas and flush out and then recharge gas./remove over charged gas/clean condenser coil
Aug 25, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Our Sanyo split air system does not take out the humidity. What is wrong?
Is it blowing cold air.? Depending on your temp. settings will really control the humidity also . try setting it for 64 and see if that helps
Aug 10, 2010 | Sanyo Split System Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
