Question about Garden
Where does the negative battery cable connect to the mower?
    An user who is expert in 3 categories / brands.
  • Garden Master
  • 924 Answers
The frame
Posted on Apr 23, 2017
Clean all connections before reattaching cables.
The negative post (shown as - on battery) should connect to the black battery cable or the cable going to ground. The other end should be bolted to a metal surface such as the frame.
The positive post (shown as + on battery) should connect to the red battery cable or the cable connected to the starter solenoid.
Dec 28, 2015 | Garden
How do I connect wires by color code for reinstallation of something?
images for mower How do I connect wires by color code
Is the Positive or Negative Cable Attached First in a Lawn ... > ... > Real Estate Rental & Lease Basics
Attach the positive cable first when working on a lawn mower battery. Nearly all ridingmowers and many walk-behind mowers are equipped with a battery for ...
free wiring color codes Riding Mowers & Garden Tractors ...
Ask your free wiring color codes riding mower and garden tractor questions. ... ENDSDO NOT MATCH FEMALE ENDS ON COLOR CODE CONNECTIONS ...
Nov 26, 2015 | Garden
Can i jumpstart my motorcycle from my riding mower
Sure, if they are both the same voltage and the capacity of the boost battery is sufficient AND you connect them correctly. DO NOT connect the cables backwards. Connect the cables Positive to Positive and Negative to Negative. The grounding cable is best connected to the frame ground or something other than the bike battery post. If the boosting electrical system engine is running and charging while boosting the weak battery the boosting system will be assisted in providing necessary current from the running charging system. Do not boost a wet type battery if it is dry or very low on water. It will be somewhat low if it is discharged, but should not be dry or very low. If it is an AGM type battery rather than a wet type this will not apply. If you have to replace the battery an AGM type will be the better choice for many reasons.
Aug 22, 2014 | Motorcycles
Grasshopper 616 mower will not hold charge has to be jump started
Check to make sure no accessories are left on. To check if there is current draw in the off position use a volt meter or a 12 volt circuit test light available at most auto parts stores under $10. Disconnect the negative - battery cable then connect the test light from the negative battery cable and the negative post of the battery. The light should not illuminate at all. If it does, start removing fuses until you find the circuit that is causing the test lamp to light.
Also have the battery tested. It is possible the battery doesn't have the capacity to power the starter.
I hope this helps to sort out the problem.
Apr 26, 2014 | Garden
Ground connection
I'm not clear on what you are referring to. This is on a lawn tractor- correct? And there is a poor ground connection on the negative battery cable to the frame? Also, I'm not clear what you mean by " to make any noise". DO you mean to start the tractor? If this is the case- make sure the battery cables and the battery posts are clean- very clean. Clean the frame where the negative cable attaches, and clean the cable end. All connections need to be clean - no rust or corrosion. The negative cable can be attached to the frame at any point, so the cable can be moved by drilling a new hole in the frame, but usually this is not necessary if the original hole is cleaned of rust. If you need further help let me know.
Apr 03, 2014 | Garden
Engine cut out when it was turning over and now when i try starting it i have nothing when i turn the key i put jump leads on the battery from my car but still nothing
I would disconnect the positive lead terminal from the battery on the mower, then follow the positive lead to the starter solenoid. Check the connection there for security (is it clean and tight?). Then the connections on the starter... disconnect, clean and tighten them. remove the terminal from the negative battery pole, and remove the ground cable from the frame of the machine, clean the terminal and the point where the negative cable contacts the frame of the machine... do the same for each battery terminal and cable terminal. Connect the negative battery terminal last. Your problems should be solved.
Sep 02, 2012 | Northstar Garden
Can I jump start a john deere 445
Yes, you can jump start it with any 12 volt battery on any vehicle. Just do not have the donor vehicle running. Connect the positive cable from the donor battery to the positive post on the battery on the mower. Then connect the negative cable from the donor battery to the engine block or other ground source on the mower. Do not connect it to the negative post on the battery. Make sure you have a good connection on bare metal for the negative cable. Disconnect the negative cable the instant the mower starts.
Aug 13, 2011 | John Deere 420,1020,2010,2020,2510,2520...
The starter does not seem to get enough power to start mower, sometimes it turns motor over and sometimes it turns real slow and wont fire. I have charged bat. and cleaned all conections still no luck. any...
If the battery and cables are good, then it's likely either the solenoid or starter motor is failing; doesn't matter which because you generally replace them together as an assembly. But before you shell out $80-$100 for a new starter, be sure you've checked not just the connections at the battery end, but also the other end of the heavy cables going to the battery. The heavy red cable goes from battery to solenoid - make sure the nut is tight that holds the cable onto the solenoid. Be sure to disconnect the battery negative lead before you put a wrench on that solenoid terminal - shorting it to the chassis would cause a disaster. Also check the heavy black cable that goes from battery negative to the chassis - it is common for rust to occur at the chassis connection. If so, just take off the cable lug, clean the chassis and lug surfaces with a wire brush or sandpaper, and retighten the bolt. Good luck!
Aug 06, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
I need the battery wiring diagram for HomeLite UT13122. I took out the old batteries without documenting the wiring thinking it was in the manual.
Short blue cable goes between the negative and positive terminals on one side of the battery.
Thick white from cable that goes to the switch and thick wire that comes from negative terminal of motor go together with the small black wire from the hood - connect all 3 wires to the negative terminal on other side.
Thick green wire from cable that goes to the switch goes with the thin red wire from the hood - connect both wires to the remaining (unused) positive terminal.
Jun 10, 2010 | Electric Garden
Want start
The batteries sold (and supplied with) for mowers are marginal at best. If you are fairly sure the battery is OK, tighten all the connections between it and the starter; at the battery (remove and clean if crusty), at the point at which the negative is attached to the chassis, at the in- and output terminals of the solenoid (follow the positive cable, you'll find it) and finally at the starter itself.
It is safest (for you and the battery) to DEtach the negative battery cable before you start with the other connections and reattach it last. A slipped wrench can cause a shower of sparks that won't do the wrench or the battery any good,
May 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
