I need a needle for a Thomas Pacconi model MSE-825 suitcase phonograph
techman
  • 3130 Answers
SOURCE: Replacement stylus needles
look up on a search for phonogragh needles. I did and saw tons of stuff available. Just look and you shall find.
Posted on Sep 23, 2006
mighty thor
  • 51 Answers
SOURCE: Speed problem on Thomas Pacconi Turntable
probably need the rollers rebuilt
check out needledoctor.com
Posted on Dec 05, 2008
  • 5 Answers
SOURCE: WHEN I PLAY A 331/2 RPM LP IT SOUNDS A LITTLE
The needle itself will not induce drag on the record. Even worn needles play no role in the problem you describe. The belt, provided it has suffcient tension to turn the platter, is doing it's job. The most likely source of malfunction is the motor itself. Try sliding the speed switch back and forth while the turntable is turning. If you see no difference in the speed between the 33 1/3 rpm setting and the 45 rpm setting, you have most likely eliminated all sources of the malfunction other than the motor. They are very prone to failure. If a replacement can be found, the job of installing it is not particularly difficult but indeed should be left to someone skilled at soldering electronic parts.
Posted on Aug 13, 2010
  • 3 Answers
SOURCE: Thomas Pacconi Model TPC-MSE-800 turntable
Pjam,
Had the same problem & checked around on the net. Several people tried replacing the belt, but it had no effect. Spoke w/ several repair shops around the country and they concur with what I'd read on the net - bad motors. 3 or 4 repair/supply shops told me getting a motor would be impossible. Since I only listen to 33-1/3 LP's, I messed around w/ it a little and found a solution. Take the turntable out of the unit & you will find a small circuit board attached to the bottom. On that board is a small square blue fixture w/ a white circular "dial" in the middle (has grooves to accept a small straight blade or a phillips screw driver). This controls the voltage to the motor, which in turn controls the motor RPM's. If you set the selector switch to 78, you can experiment /w turning that white circular "dial" to slow the motor down. It isn't very hard to get the speed set properly. The down side is that you will only be able to play 33-1/3 LP's, but they are probably the most common anyways. I assume you could do the same to set the speed for a 45, rather than a 33-1/3. Down side is that you will only be able to play 1 size LP on the 78 speed setting, but it's an easy adjustment that can keep an otherwise in-op turntable functioning. Good luck!
Posted on Jan 21, 2011
  • 3 Answers
SOURCE: I have Thomas Pacconi turntable which is about 5
I have a Thomas Pacconi Model TPC-MSE-807 turntable. The Power/Volume Control has gone on it.
Look on the data plate to see if there is a voltage and current draw value on it. The switch should be rated at 120 Vac @ 10 A.
Feb 02, 2017 | Dual Audio Players & Recorders
I need an owners manual for The Thomas Pacconi Classic Model # TPCMSE 805 for my 82 year old father who has lost his and it needs a new phonograph needle and the cassette player is not working.
not sure about a users manual or other parts unit is belt driven
you can by the stylus
turntableneedles com
http://www.turntableneedles.com/THOMAS-PACCONI_c_50123.html
some thing easy diy if no sound while playing a cassette
try cleaning the head (silvery bit )
of the cassette player with cotton bud and metho
Jul 02, 2016 | Audio Players & Recorders
I need a needle for thomas pacconi phonograph model tpc-hd-12 can you help?
What you do is look at the cartridge it fits in, then note down the make and model number and enter that into Google. The stylus should then show up.
May 30, 2016 | Audio Players & Recorders
I have Thomas Pacconi 3-speed phonograph model TPC-7475 and wanted to attach external bookshelf speakers. Is there any way to hook speakers up to the line out jacks?
You need to buy the Jack's male plugs, Wal-Mart has them if memory serves, and splice your speaker wires onto them, preferably with a soldering gun and heat shrink insulation.
Jan 12, 2015 | Seth Thomas Pacconi Turntable
Thomas pacconi # tpc-mse-800-o (no power)why is there no power getting through hole unit?
Since you have no sound even on radio, it's not going to be a bad tt motor. There is no fuse except for a thermal fuse inside power transformer. I would start with a continuity check accross both of the blades on the plug. If it's open, you prob have a bad power transformer.
Sep 06, 2014 | Seth Thomas Pacconi Turntable
Thomas Pacconi TPC-MSE 800
could you include a picture of the under side of the turn table where the belt is fitted?
May 21, 2014 | Seth Thomas Pacconi Turntable
CD player will not work in my Thomas Pacconi TPC-MSE-800
I have the same unit. Where do you find the screws that hold the cd clamp cover?
May 15, 2012 | Audio Players & Recorders
Dec 22, 2009 | Seth Thomas Pacconi Turntable
46 people viewed this question
 Grubhead
Grubhead
