Heater pugs are not heating through the ignition key.What's the problem
Where does the key ignition pug into on the engine
The only wires that go from the ignition to the engine are the two that go to the starter solenoid the rest go to the ecm and fusebox then the engine
Jun 22, 2016 | Cars & Trucks
Turn key and motor rotates but no ignition
Defective ignition control module
Feb 14, 2013 | Cars & Trucks
1985 3.7LX 4cl. blue wire to the oil press,resiter wire, coil to carb heat, both heat up.ignition on
Not sure what the question is ?
The heater for the choke and the coil draw alot of amps.
If either component has an internal short to ground, the wire will be very hot rather than just warm.
You could disconnect either component and see if the wire is still hot.
Jul 07, 2012 | Cars & Trucks
I have an Oreck quartz heater that doesn't seem to cycle via the thermostat. I would like to find an owners manual to assure i'm setting it properly
If what you have is an Oreck, Heat Wise Infrared Heater, here's a link to the owners Manual that you can download and print.
http://www.oreck.com/PUG/21085-01%20REV%20A%20Heatiwse%20%28sm%20manual%29.pdf
Hope this what you are looking for.
Mar 22, 2011 | Heating & Cooling
Grill will not ignite-glow pug is bright red
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter
http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Feb 14, 2010 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
No heat
Obviously everything does not work , otherwise you would have heat. You need to tell the story: is this a new installation? Is this the first time this happened and is it only one season old? Have you checked the gas valve to be open ? Is this unit have an electric connection or a pug-in transformer (like a charger unit ) or is there a battery in the ignition control? Or is it a spark starter like you see on barbaque grills and the spark is not ticking? Or does this unit have a pilot light that first must ignite from the contol unit?
Some pilots get clogged and won't light, therefore the sensor that feels the pilot flame will not tell the gas control valve to operate.Good Luck. Macgivor
Oct 11, 2009 | Heating & Cooling
IGNITION NOISE
if the screech occurs only on starting it could be a worn starter motor or flywheel ringear
Mar 27, 2009 | 1990 Peugeot 405
Heater is off and code says FL 2
The FL2 code indicates that the heater has tried and failed to ignite three times. This is not uncommon after it has sat for a while unused. Check that the gas shut off valve is open and the valve inside the heater is in the on position. While it is trying to fire check to see if the hot surface igniter glows, then you should hear an audible "clunk" that is the pilot valve opening. If the pilot valve is opening but the HSI is not glowing then the HSI will need to be replaced. This is not uncommon.
To clear the FL2 service code, turn off the heater by using the SELECT key to turn the heater to the 'OFF' position and then turn it back to either 'POOL' or 'SPA'. The heater will now go back to the normal operating mode. If there is a call for heat the heater will attempt ignition again. If the ignition fails
again, contact a qualified technician to check the heater.
Jan 27, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
