Question about Exercise & Fitness
Hi, my V-fit tornado does not display the distance/speed ? Everything else is displayed. The batteries are 75% full ...
SOURCE: battery display on canon ixus 75
Its same for everyone. You can only see the battery when its about to run out. IN that case a red flashing icon appears on the upper right corner of the screen otherwise there is no indicator for ixus 75.
Posted on Jul 02, 2008
  • 10 Answers
SOURCE: my battery signal shows full and after sometime shows battery low
check if ur battery has swollen...this happens due to repetive over charging...d capacitors burn out...if tats d case...replace ur battery immediately..since d old 1 has chances of bursting...
if thats not d case thn try another battery,,,prob persists thn itz a s/w error goto a nokia care...they'll do it 4 free
Posted on Oct 28, 2009
Testimonial: "your information was little bit helpful "
chamboard
  • 557 Answers
SOURCE: need instruction sheet or manual for cory everson
http://www.sony.nl/product/paw-minidisc---net-md-walkman/mz-n510/tab/manual here you finnd manual in difrend lang
Posted on Oct 31, 2009
SOURCE: My response 75 since having ablip in power was
We found the problem was with the power. In our case, plugging the adaptor into the power outlet directly, bypassing an extension and checking the outlet was working with a lamp. The error lights you describe were the exact same that we were getting, caused by low battery levels.
Hope that helps someone.
Posted on Jul 15, 2010
dunnbiker
  • 8546 Answers
SOURCE: Cateye double wireless stopped showing time
Well, it IS wireless so it need ssome good juice and line of site from the sensor to the receiver to work.
Take the unit off the handlbar mount and hold it close to the transmitter while you move the wheel magnet past the sensor.
If it starts to work begin moving the computer farther away toward your handlebar mount and figure out where it dies and why. Some units have distance specs that must be adhered to.
Posted on Jan 04, 2011
How do I re-calibrate NordicTrack treadmill T9si when distance displayed is too low?
1) Please use electronic spray for electronic and LUBE the small POT in the electronic Board.
2) Adjust the Speed sensor, and test it, and see is ok or faulty, clean it and ajust 1mms near of magnet. otherwise replace it.
Blessing
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Eletric treadmill Speed Sensor Adjustment
Nov 19, 2017 | NordicTrack Exercise & Fitness
Reebok ZR8 display is completely blank. Belt working fine, speed and incline keys still responsive - just can't see speed, distance etc
Hi Adrian, All a treadmill is... is a motor, running belt and console display pad. You'll find the console display pad has malfunctioned.... This can happen when something heavy is placed on it OR something hits it and if yours is under warranty then get it fix as soon as possible mate, I had a problem with my console display pad and it cost me $100 just for the pad....... My treadmill is a different brand but I can tell you the motor and running belt will last and last and last.....I hope this helps.........CHEERS..
Apr 27, 2016 | Reebok Exercise & Fitness
Hi i have a 900 benelli tre 2004 only 3000 km on clock has service spanner on digital dash how do i reset it?
Hi, Anonymous here is how to reset/adjust Engine Service Interval (Wrench icon)
Upon selecting this item, there are two possibilities. If the Wrench icon is active, you will have the opportunity to clear it--proceed directly below. If the Wrench icon is not active, then skip over the next section to "CHANGE ENGINE SERVICE INTERVAL".RESET WRENCH ICON:
1. The display shows CLEAr and no.
2. Press and release SCROLL to alternate between no and yES.
3. Select yES if you wish to reset the wrench icon.
4. Press and hold SCROLL for 4 seconds.
5. WS appears in the display.
6. Release SCROLL.
If you selected no, you will not proceed to the next section; the display will revert to the Service Setup Menu.
CHANGE ENGINE SERVICE INTERVAL:
To get to this point, the Wrench icon must not be active or you just now reset it, as above.
1. The display now shows either CLK or km/h (or Mph).
2. The display now shows the number of hours between Wrench icon reminders. The factory setting is "0044".
3.The 2nd digit of the hours value will be blinking:
In addition, the display also shows the Oil Can icon above the word "OIL", and the "CLK" indicator is present. The presence of "CLK" indicates the interval occurs based on time (this can be altered for the Wrench icon, but not for the Oil Can icon).
For more information about your issue, please visit the websites below. Good luck and have a nice day2006 Benelli Tornado Tre 900
Benelli Tornado 900
http://dl.dropbox.com/u/35177464/Tornado/900%20Tornado/TORNADO%20User%20Guide.pdf
https://dl.dropboxusercontent.com/u/35177464/Tornado/900%20Tornado/Tornado%20workshop%20Manual.pdf
https://dl.dropboxusercontent.com/u/35177464/Benelli/TornadoWiringDiag.pdf
Oct 11, 2013 | 2005 Benelli Tornado Tre 900
Hi i have a benelli tre 900 2004 that has a spanner on digital screen bike only done 3000km how do i reset it?
Hi, Jeffery here is how to reset/adjust Engine Service Interval (Wrench icon)
6. Release SCROLL.
Benelli Tornado Tre 900 2004
https://dl.dropboxusercontent.com/u/35177464/Tornado/900%20Tornado/TORNADO%20User%20Guide.pdf
Oct 11, 2013 | Benelli 900 Sei Motorcycles
Proform L18 treadmill display doesn't work. Incline and speed switches work but no led display
f6627a04-b106-44a9-8b92-9f8216f7b081.gifsee the diagram attached. Clean it. Test for open or faulty. Tight the connector. God bless youecb0db45-4f21-4a62-9528-93bd2d358ee3.gif
Apr 03, 2013 | Startrac Fitness Products Star Trac 4500...
Display Doesnt turn on
1) change the batteries by news one
2) clean the contacts batteries very well
3) tight the ribbon cables from keypads from display board.
4) tight the wires connector from display board vs lower board
5) Adjust the reed switch see the diagram, clean it and tight the wire connector well.
6) After you fix it RUN the software calibration for diagnose , troubleshooting and fix it.
God bless you
Jul 12, 2012 | Proform ZT5 Treadmill
May 26, 2010 | British Telecom Response 75 Digital...
Battery display on canon ixus 75
Jun 12, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
