Question about Microsoft Xbox 360 Console
Hi have xbox 360 and 3 lights are flashing it was freezing up now havbe the lights the code is 0013
I am looking for adjusting instructions on a Falcon Index System. I know this is not a expensive kind but it skips or seems to slep when trying to apply pedal pressure in any gear.
Posted on Jul 24, 2009
Fix code 3141 3151 b200 0700 c000 0013 help me fix please .
Did you download the 12625 update from Microsoft and try it from USB? More info please, was the box modded in any way? The update you need is not the latest by far. Download update 2.0.12625.0 here
1 Plug your USB flash drive into a USB port on your computer.
2 Download the update file.
3 Click Save to save the console update .zip file on your computer.
4 Unzip the file. If you are using Microsoft Windows XP, Windows Vista or Windows 7 or 8, double-click the .zip file to unzip it.
5 Copy the contents of the .zip file to the root directory of your flash drive.
6 Unplug the USB flash drive from your computer.
7 Plug the flash drive into a USB port on your Xbox 360 console.
8 Restart the console.
When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
Hope this helps
http://download.digiex.net/Consoles/Xbox360/Dashboards/2.0.12625.0.zip
Jan 29, 2015 | Microsoft Xbox 360 Console
My xbox right as i tern it on 2 red rings apeare and the code is 0013 what do i do
Is your Xbox still under warranty? You might need to get them to fix it as it might be a hardware problem.
Jan 29, 2012 | Microsoft Xbox 360 Console
Error code 3151-351f-b800-0f00-c000-0013
According to the xbox 360 support site, that error comes up when there is a temporary connectivity issue, test your internet connection and try the update again.
Nov 04, 2011 | Microsoft Xbox 360 Console
3151-351F-B800-0F00-C000-0013
I've tried to update with both 13599 nd the latest update... m still getting the same 3151-351F-B800-0F00-C000-0013 error its not even booting my flash. Please help it all started when i tried to insert my Fifa 12 disk, it asked for update then hlaf way through it started showing the error...
Oct 17, 2011 | Microsoft Xbox 360 Console
Xbox 360 support status code 3151-335A-B800-0F00-C000-0013
The update was interrupted, the best way to clear that code you must update your system manually. got to xbox.com/support and download the latest update files. use a USB drive to finish the update loop.
thanks
www.1RepairStop.com
Sep 14, 2011 | Microsoft Xbox 360 Console
Xbox 360 error code: 3151 335A B800 0F00 C000 0013
Your xbox is getting interrupted while download your update through xbox live. try updating your console manually by going to www.xbox.com/support and download the latest update file, use a USB to finish the update.
Thanks
www.1RepairStop.com
Sep 09, 2011 | Microsoft Xbox 360 Console
This error code kept appearring 22FB-3080-B200-0700-C000-0013. it happens when i am starting on fighter incaged.Now when I reset, I keep getting the same message.
To solve this problem..here's the solution...........download the repair guide of xbox 360 and solve any problem of it... to download the repair guide
Dec 20, 2010 | Microsoft Xbox 360 Console
Red flashing light and having a code E73
When turning on the Xbox 360, a red light would be flashing at the fouth section of the Ring of Light. You should then recieve a ghost screen indicating an error E 73.
You recieve a screen error E 73 and section 4 of the RoL flashing red. This type of error was caused by a General Hardware Error relating to the Ethernet Port not functioning correctly or became faulty and unable to operate even with or without an Ethernet Cable connected to this port. The secondary code would be identified as 1021 for faulty ethernet port. I believe that there is no fix at the moment. If you encounter this error, I would suggest call 1-800-4MY-XBOX or visit www.xbox.com/support
The specific type of hardware error can be determined by these hidden codes:
0001, 0002, 0003, 0010, 0011, 0012, 0013, 0020, 0021,0022, 0023, 0030, 0031, 0032, 0033, 0100, 0101, 0102, 0103, 0110, 0200, 0203, 1000,1001, 1002, 1003, 1010, 1011, 1012, 1013, 1020, 1021, 1022, 1023, 1030, 1031,1032, 1033, 1100, 1444 and up
More information about these codes and errors, visit this webpage:
http://forums.xbox-scene.com/index.php?showtopic=484726
  • Note: There is known to be a temporary fix for this problem but is not recommended if the device still has available warranty on it. Doing so will avoid it's warranty, thus for you will pay $100 if sent for repair.
The Sticks Method:
  • Requirements: Xbox 360 (Power Cable and Composite/Component/HDMI Cable), two sticks (Like toothpicks, swabs)
1.) Turn off your Xbox 360 and unplug everthing.
2.) Get two sticks (Something like toothpicks or something that could fit in the back of the Xbox 360.
3.) Insert each stick to jam the two fans at the back of the Xbox 360 to prevent it from spinning.
4.) Plug back cables (Power and Cable connecting to TV; the RRoD will not appear unless the cable to the TV is connected).
5.) When RRoD appears (One Red Light), wait for about 10 to 15 minutes or maybe less for the Xbox 360 to overheat.
6.) At this point, you should get two red lights (Resembles Overheating Error) so remove the two sticks so that the fans will spin in an increased speed. After a few seconds, the Xbox 360 will turn off to cool down (RRoD will still appear).
7.) Unplug only the cable connected to the TV. You can unplug the power cord if you want to. Then let it cool for about 30 minutes or so (Feel the Xbox 360 if it's cool or still warm)
8.) Replug all wires and turn your Xbox 360 on.
The Xbox 360 should now be able to boot to your Xbox Dashboard. I don't know how this fix works but it's only temporary. Note that doing this continually would cause it to now work even if you try to redo this fix again and again. Doing so would make other hardware components to fail permanently such as the GPU for example.
If this first temporary fix did not work, do the second method: The Towel Trick. You can find the tutorials in Youtube. Again, this is not recommended if you have warranty left and never do this continually. Your Xbox 360 would completely and permanently fail after that. if it doesnt help after all this....I suggest sending it to Microsoft for repairs
Sep 06, 2010 | Microsoft Xbox 360 Pro System Console
2 rrod code 0013
put your x box 360 console on a pie cooling rack or in font of a small fan
Dec 07, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
