My quietside mini split indoor unit code reads FC on both heads
  • 400 Answers
SOURCE: GE mini-Split Error code
Replace the indoor pc board and thermistor.
Posted on Mar 20, 2009
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Posted on Jun 01, 2009
  • 81 Answers
SOURCE: How to remove cover on fujitsu split system head
The front cover can be dismantled (taken off as one Piece) by unscrewing the screws at the bottom of the air outlet (they are covered by screw cvers which will need to be taken off. Then just pull off the cover. PLEASE NOTE that the front panel (liftable to take out filters) will need to be removed lift up until 90 degrees and then pull off gentley and also take out filters before removing front cover
I take the time to answer you questions so please rate me
Thankyou
Mat
Posted on Aug 29, 2009
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
Posted on May 04, 2010
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
What is a code c1 on a samsung mini split?
Error code = C1 or CH1
Fault = Indoor temperature sensor open or closed circuit.
Jul 26, 2014 | Samsung AQV12VBCN Vivace Mirror Finish...
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more: http://dgoma.es/multisplit_lg/lg-multi-split-units-error-code/#ixzz34dr3Cu00
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
My mini split system had an E2 code...replaced indoor pipe sensor...indoor unit works but outside unit does not...no other error codes, just motor not working outside
Check the outdoor unit to ensure power is available to it, and the contactor is closing on a call for cool 24-28 volt is present at the contactor coil to activate it.
Aug 24, 2013 | Continental Electric CE-AC7581 Ductless...
I have a 24 ton mini split, that has never worked correct. It used to blow cold air, but only for a little while, then it set error codes including p4, and p8. The heat functioned used to work ok. Now it...
Code P8
Error detail Abnormality of pipe temperature.
Inspected unit Indoor. Due to non condensable gas/over charged/condenser dust blocked.
For non condensable gas, remove gas and flush out and then recharge gas./remove over charged gas/clean condenser coil
Aug 25, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Our Sanyo split air system does not take out the humidity. What is wrong?
Is it blowing cold air.? Depending on your temp. settings will really control the humidity also . try setting it for 64 and see if that helps
Aug 10, 2010 | Sanyo Split System Air Conditioner
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
