Question about Decker Drills
Which is the positive and which the negative prong on a new Black and Decker 18v charger which has 4 prongs?
  • 44 Answers
You need to use a volt meter
Posted on Sep 15, 2017
jsrock516
  • 5911 Answers
SOURCE: REPLACING DRYER 4 PRONG PLUG
This is common issue. Due to some building codes the 3-prong configuration is no longer used in homes. The wiring is similiar with one exception. The 4-wire plug uses an additonal (WHITE) NEUTRAL wire.
Here's a brief explanation of how the plugs are configured:
Dryer 3 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
Dryer 4 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
WHITE - NEUTRAL
BOTH plugs provide the SAME source voltages to your appliance:
220 VAC - provided across the RED and BLACK leads are what drives your heating circuitry.
120 VAC - usually tapped of the BLACK wire is used to run the drive motor and timer on MOST dryers.
The wire terminal block in the back of the dryer should have a black, white, and red wire running to it from the dryer wiring harness. With the 4 prong plug, simply attach the BLACK, WHITE and RED wires at the terminal block ensuring that you match the RED and BLACK wires as they are configured and attach the WHITE wire at the remaining terminal lug. Make sure you screw them all down securely. Attach the remaining GREEN wire to chassis (dryer frame) ground. I hope ths helps you.
Posted on Feb 14, 2008
  • 71 Answers
SOURCE: how to change a 3 prong to a four prong on a mde4000 Maytag Neptu
the red wire to red black wire to black white wire to white and disconect the ground wire to the white lug and conect the green wire to the screw that is on the other end of the ground strap you disconected from the white lug
Posted on Dec 24, 2008
SOURCE: I have a black and decker electric weed wacker,
replace the entire plug end
Posted on Sep 03, 2009
canbruce75
  • 1776 Answers
SOURCE: I have a new 4 prong plug to replace a old 3 prong on dryer
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom/right.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Posted on Sep 15, 2009
  • 5 Answers
SOURCE: How can I bypass the parking brake wire?
The parking brake wire has to connect to ground when the switch is in one position and connect to nothing when the switch is in the other position. I think if you disconnect the positive wire from your switch that might do it. If not, leave the positive wire off and try the remaining two wires, ground wire and parking brake wire, on different prongs of the switch.
Posted on Apr 18, 2010
What is the polarity of a 12v Black & Decker Drill?
centre pin on plug socket is usually positive...
think I would **** it and see ....if the replacement charger has a charge light it will probably not light if you have reversed polarity. Had the same problem with VHF portables ...I just cut the wire on new charger and tried both options ..reconnected and a bit of tape...voila.
There is little danger to your drill from getting it wrong as long as a the timing is relatively short.
May 29, 2012 | Black & Decker Drills
Looking for a black and decker firestorm 18v charger
go to dewaltservicenet.co and they have a locator section that you might find one locally.
Oct 25, 2010 | Black & Decker Black and Decker FIRESTORM...
You have to connect the ground wire and the parking brake to get pictures
Apr 16, 2010 | Pioneer Car DVD AVH-P6600DVD Car Video...
Battery charger burn out.
If you have one of those little testers that has red and black wires with prongs on you can test by touching the metal areas on your battery. The red is positive and black the ground.
Nov 21, 2009 | Craftsman Drills
Have a Fire Storm place battery in charger green light comes meaning full charge but place in drill there is no charge. Is it a new battery, or new charger, or new drill required
if you have one check the battery and charger with a meter. if there both fine check the prong's on the battery and the power tool. if charger is'nt charging check the fuss in the charger.. good luck let me know.
Oct 16, 2009 | Black & Decker 18 Volt Cordless Drill...
Describe your Black & Decker
Take the casing apart and I bet one of the wires for the cord pulled out. I bought a brand new ryobi sawsall,used it ten minutes and it quit. Was going to throw it away but decided to open the casing and the black wire pulled out of the terminal,it was a five minute fix swear to God!
Aug 10, 2009 | Black & Decker 14" Grass Hog Xp...
Grass Hog Battery #243215 (12 VDC SLA) and Charger #371415-11
Open the unit up (six cross-head screws). Inside you'll find a 12V 5.0AH rechargeable battery, like the kind used in many home alarm systems.
You can get a replacement at most battery stores (they'll even pre-charge it for you). Somewhere around $20, I guess.
May 22, 2008 | Black & Decker String Trimmer Cordless 12"...
Drills Logo
227 people viewed this question
Top Decker Drills Experts
J.D. Browning
J.D. Browning
Are you a Decker Drill Expert? Answer questions, earn points and help others
