Question about Black Computers & Internet
Ii have a toshia satelite C660D laptop and when i turn it on i get a black screen with a flashing line. any help would be greatly appreciated. thank you
  • 48 Answers
SOURCE: Toshibsa Satelite P30 Laptop
That usually means that the polished silicon plates no longer make good contact with the LCD glass. It is rare you can fix this yourself. But you can remove the LCD by removing any small covers or rubber feet from screen side of the lid.Power off machine before going further. From there remove all the screws and remove them. Just remove the screen gently and look behind it and you will see printed barcodes with numbers. One of them is a part number. Ebay that number and find out how much you can get one for. Be sure the sell has a good rep and a return policy. Order one in and replace it yourself. Or take the parts you have and a repair shop may not charge much to replace the screen you have.
email me if you need any more assistance or reassembly.
Posted on Jan 07, 2008
Fix-4U
  • 293 Answers
SOURCE: Samsung 940 BW Monitor Not working (Black screen)
Hi...there,
That's indicated your backlight inverter are busted. Need to replaced a new one or repaired it. To repaired look for a bad capacitors with a bulged on top of each caps. Not sure, just replaced all the caps... Have a nice weekend!
Posted on Oct 11, 2008
  • 82 Answers
SOURCE: laptop screen constantly flickers and whites out
Your Bulb is DUE, you need to change it, Don't do it your self contains mercury. Your LCD is good IF you do not have bad PIXELS. This white and pink lines shows as pixel problem but it migth also short on LCD, if you placed something heavy on Laptop. You may remove and sent the LCD for repair or all laptop to tech.
You may also need to check inverter. I give service around the Country but it is up to you. My company name is JMC TECHS INC. Registered in Miami Florida. (Check SUNBIZ.com) jmctechinc@gmail if you like to contact me.
JMC
Posted on Aug 15, 2009
jaseel1
  • 556 Answers
SOURCE: Problem with Toshiba Qosmio F25-AV205:
f your laptop has no warranty than you open the laptop back cover where the ram is connected,please clear the ram slot & put it again it will be OK
Posted on Nov 13, 2010
puertobori
  • 7733 Answers
SOURCE: dell inspiron black screen error code 2000-0146
Error 0146 indicates a failed/failing hard drive or bad drive sector.
Basically, this means your hard drive will need to be replaced.
Posted on May 02, 2012
Testimonial: "many thanks x"
Vertical line down screen
This problem can be caused by a lose connection between LCD and motherboard, however you can check it by opening the LCD or hinge bezel to ensure if there isn't any lose connection.
Oct 28, 2013 | Dell Vostro Computers & Internet
Toshiba laptop c660d-152 showing black screen asking for password
check whwther you have set password while booting if so enter bios pw
Dec 09, 2012 | Toshiba Satellite L455-S5009 laptop
Toshiba c660d laptop stuck in safe mode? help!
When the Windows splash screen pops up, start hitting F8 until the menu comes up and select Start Windows Normally
Oct 21, 2012 | Toshiba Computers & Internet
Dell inspiron black screen error code 2000-0146
May 01, 2012 | Dell Inspiron Computers & Internet
Toshia A135-S4527 that goes blank after account login
Press Ctrl+Alt+Delete, the Task manager will appear. Click File, click New Task, type explorer, OK and it should start.
Jun 20, 2010 | Toshiba Satellite A135-S4527 Notebook
My Ibm Laptop r51 has a vertical lines on the screen
The lines appearing on your LCD means it has a defect on the screen.
There are 3 types of pixel defect
1) dead pixel - pixel is always off
2) stuck pixel - pixel is always on
3) hot pixel - pixel is on but in red, green, blue or yellow, can also be a light black color
You can try to fix stuck or hot pixels but dead is dead.
1st method, flashing different colors rapidly:
JSScreenfix.com has a great tool. This is their free java applet or you can download it below.
2nd method, applying pressure to pixel:
Damp paper towel, Small stylus or dull pencil.
3rd method, tapping the pixel:
Pen with cover on or another small, blunt object.
If your laptop is still under warranty, get it replaced. If not you are looking at the most expensive part in a laptop to get replaced. (LCD screens on laptop is roughly equivalent to 40-60% of the total laptop cost
Please rate this if it this helps.
Jun 02, 2009 | IBM ThinkPad R51 Notebook
My toshiba satelite L-35 screen fade to black and
The LCD ribbon convector is loose or damaged or the LCD is damaged
Apr 23, 2009 | Toshiba Satellite A100-S8111TD Notebook
Hi...there,
Oct 09, 2008 | Samsung Syncmaster 940BW LCD Monitor
Black Screen/Viewfinder
Mine too! Thank you so much for posting this issue!!
Apr 22, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Computers & Internet Logo
23 people viewed this question
Top Black Computers & Internet Experts
NOEL
NOEL
mike36360
Are you a Black Computer and Internet Expert? Answer questions, earn points and help others
