Question about Building Materials
Signal range for a regency remote - Building Materials
Remote will only start when i am close to vehicle
It depends on many things - mostly the range of the system itself and especially where you located the remote antenna. Some installers don't use the antenna and that will limit range severely. Most manufacturers want the antenna routed up the windshield pillar and mounted near the top of the windshield glass. This gives best reception since glass does not hinder the RF signal. OF course, a weak battery in the remote can cause range issues as well.
Nov 25, 2015 | Car APS921 Remote Starter - Keyless Entry
Why has my DFV19U box frozen after freeview updated channels?
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range. The signals for BBC and ITV are among the strongest ones broadcast. If they are now at a point on the aerial's range where they are too strong for the TV then the tuner will over-saturate. The result is the same as no signal.
A simple and inexpensive diagnosis tool is a variable attenuator. The MA1620 on this page is perfect for that job:
Splitters amplified splitters and attenuators
It will give you a way to reduce the signal level at one TV without affecting the other TVs in the house.
Sep 07, 2014 | Televison & Video
I have a 1996 98 regency oldsmobile and it cut off then it started right up what could it be
Possible faulty crank sensor or idle speed controller, fuel pump relay, or ignition module. Get a data scan and see what's sensor might out of range or defective. Check for clogged fuel filter also.
Jun 03, 2014 | 1996 Oldsmobile Ninety Eight Regency
How do you program a Regency Programmable Scanner R1070?
Regency R1070 Frequencies for people with no manual
These are the ranges it supports.
30-50 Mhz
144-174 Mhz
440-512 Mhz
To make it scan, first set the range by pressing Manual and then Search. It will ask for the LOwer end and the UPper end of the range. Enter them, press Scan and then Search, and it will start scanning. When it locks and you want to keep going, hit Search again. You can press Delay to stop at a channel temporarily. To save a frequency in memory, hit Manual and pick a number, then type it out and hit Enter. When you have a few channels saved and you want to check up on each of them, Scan scans through memory. The Lock button is to skip a particular channel while scanning.
That's pretty much the whole manual right there.
Jan 30, 2012 | Radio Communications
I have 3 garage door openers. Two of them have week signals. Only works on very short range (does not work after you get more than 3 ft. away), no long range signal period. I have replaced the logic...
because the remotes are new I recommend that you bring them back to sears and have them adjust the transmit gains to increase the transmssion .wattage on the remotes. that should do the trick
May 09, 2011 | Kitchen Ranges
Having problems with turn signals as well as hazard light not working properly ,we change turn signal switch as well as fuses. THIS IS 1997 OLDS REGENCY 3.8
there are two different flashers for this they may both be bad turn on flash and listen for the clicking noise if it doesnt and just the light comes on replace also check to make sure all your bulbs are good this can also cause this
Feb 14, 2011 | 1997 Oldsmobile Regency
1990 olds regency 98
Code #62 in the Haynes repair manual refers to the transaxle gear switch signal circuits. Hope this answers your question..
Jul 17, 2008 | 1990 Oldsmobile Regency
FINDING FREQUENCIES
87ff97c.jpgNo it can't sorry. If you want to scan things all the way up to the 900 MHz frequency you should get a Regency Touch K500. Its not a portable scanner however. It may be a little hard to find because Regency went out of business a while back, but look on e-Bay you'll find it there.
Jun 28, 2008 | Uniden BC72XLT Handheld Scanner
Looking To Buy A good scanner? Is The BCD396T The way to go?
A good scanner? Hmm... too many to list. But the #1 on my list is a Realistic PRO-2006 gapless frequency scanner. This scanner has no limitations to what it can scan. It scans HF/FM/AM/VHF/UHF/Air/TAC/Marine VHF/GMRS/CB/SSB/USB/LSB/WX. Hell, it even scans the FM and AM bands (the music bands). It's frequency range is up in the 1300 MHz range and is probably the only scanner you'll ever need. If it's too pricey, my second recommendation is a Regency MX4000. The Regency MX4000 is a good little scanner with a 950MHz range. It is not gapless however. It has 20 Memory channels and scans AM/FM/UHF/VHF/Air/Marine VHF/Mobile Phone/WX bands. It may be hard to find one because Regency went out of business a while back, but if you do find one, it may be worth your while.
Best Regards,
Gavin93
Jun 12, 2008 | Uniden BCD396T Handheld Scanner
Building Materials Logo
79 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
