Question about Vulcan Heating & Cooling
I had heard that these Vulcan oil heaters can also run on diesel, is this true?
    New Friend:
  • 43 Answers
Not designed to run on diesal, it will run dirty, be hard to light, require cleaning more often, definitely not recomended and not give good result.
Posted on Apr 30, 2017
2 Suggested Answers
SOURCE: Require replacement glass for old vulcan oil heater
Hi ddsalm,
Did you ever recieve an answer to this?
Posted on Jul 12, 2010
2008 dodge ram 4.7 ticks at start up. i heard if i put a half quart of ATF in it that i will clean it out and it will stop. true of false
false-- Remember that you require a certain viscosity oil in the sump and any oil that thins out the sump oil will cause damage to the bearings. Check that the oil filter in use has a non drain back valve in it to retain oil in the hydraulic tappets on shut down. The best oil to clean out an engine is diesel oil as used in diesels. The viscosity is right and the extra detergents in the oil will remove all sludge in the engine. The problem is because it is doing the job then the filter has to changed every 5000miles or sooner depending on the condition in the engine. As a point of interest diesel oil can be used in a petrol engine all the time.
Oct 08, 2014 | Dodge Ram 1500 Cars & Trucks
Is it cheaper to leave my heaters on?
It works both ways if you are home it will give a constant heat , but is it safe in your place to leave it on while you are out .
Once they are hot they should cut out on the thermostat thus costing less to run .
Dec 08, 2012 | Dimplex OFC1500 Oil Filled Radiator Heater
Vulcan oil heater how to remove heating element
Burner pot needs to be removed from heater, for hearers of this vintage, Best advice is to have the burner pot and heater serviced and replace ignition element at same time, I can do this,live in Adelaide. Probably cost $250 inc parts, test run, calibrate.
May 17, 2012 | Vulcan Heating & Cooling
Where can i get heating filter (ceremic?) replacement parts for an old vulcan heater?
Do you know the model heater?
Can you post photo of the filter?
I have some filters for Vulcan oil heaters
Aug 18, 2011 | Vulcan AUW230A Heater
Can no longer buy home heating oil in the country town I live in. Will my Vulcan oil heater operate with Diesel?
no how will you light it , no find heating oil some where else , would not be safe to use Diesel
May 29, 2011 | Heating & Cooling
Will heater run on diesel?Heater will not start soon as power turned on and will not stay running.Red light starts blinking.
It MIGHT run on diesel but it will be a smokey affair. They are made to run on filtered kerosene which is a lot cleaner. Using diesel fuel will also hog it up very quickly.
May 07, 2011 | Dayton (3VE50) Oil Filled Liquid Fuel...
Hi ddsalm,
Jun 22, 2010 | Heating & Cooling
1995 Kawasaki VN 1500 Vulcan Classic oil pressure light stays on
Hi, HOsscat77 #2 looks good for this issue otherwise the usual suspects are:
1. Insufficient oil level or no oil in engine or tank.
2. Air in oil system that needs to be bled.
3. Blockage in the oil tank or line.
4. Oil pump failure.
5. Faulty oil pressure sending unit.
6. Grounded oil pressure light circuit.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Warning lights on engine clatters
Oil light won go out
Kawasaki VN1500 Service Manual
OEM Parts for Kawasaki
1996 Kawasaki Vulcan 1500 Classic Owner Manual
Sep 02, 2017 | 1996 kawasaki VN 1500 Vulcan Classic
Diesel engine... more power.?
I have heard it, but I would advise using the fuel treatment from the auto parts store, that is guaranteed, and made for cleaning. The gas deal could possibly foul your sensors from the cumbustion ratio, and may cause other problems. I would suggest buying a can of "seafoam" I love it, you can put it in your oil, fuel, and intake, and you wouldn't believe the garbage that comes out of your exhaust and in your oil after about 3000 miles. I usually only put it in my oil, and gas, but never tried the intake. Seafoam is the way to go. Should find it at any parts or hardware store. its in a white steel can. Good luck
Mar 03, 2009 | 1992 Nissan Pathfinder
Vulcan oil heater
Regarding the wiring on my ancient Vulcan oil heater...I have only just received a wiring diagram (dated January 1969), which I am just about to get stuck in to. I hope that I can follow it (the drawing looks like the last copy of something that's been copied 1,000 times before on one of those old Roneo, wet ink, wind-it-by-hand copiers). The drawing came from a Vulcan agent on the very far side of Adelaide. Here's hoping. Ooroo, John. .
May 27, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Vulcan Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
