Question about Top Vacuums
Volta 1600 Burrell vacuum cleaner. I cannot attach the hose to its place, which is on the top of the machine
  • 1673 Answers
SOURCE: Hoover wind tunnel
Check the hose to make sure it isn't clogged. But if the model number is different then the one above your post, U6437-900, then let me know.
Posted on Jan 29, 2008
  • 1673 Answers
SOURCE: Sudden loss of suction.
Check the inlet down by the brush roll to see if it is clogged. Also check the belt to be sure it is ok. Is there suction at the hose? If not then it is still clogged.
Posted on Feb 13, 2008
SOURCE: clogged vacuum hose
I used a snake like they sell for unclogging pipes. I can use the snake on one end to break it up. I attach the other end to my industrial wet.dry vac and **** it clean. Sometimes I cannot imagine how it fills half a five gallon bucket of dog hair and stuff.
Posted on Sep 06, 2008
  • 8 Answers
SOURCE: attachments hose won't **** but blows out
the polarity on the motor mite change with use or low suctoin
Posted on Feb 22, 2009
  • 281 Answers
SOURCE: Can't get any suction through the hose.
you will see a tube coming out of the top of the base.thats where the hose attaches.but before you putthe hose on turn on the vacuum and see if you have suction at the tube coming out of the top of the base.also check and see if the brush roller is turning when vacuum is on.there is a little door you have to lift up when you attach the hose.hold the door open and attach the hose.i hope i was of some help to you.please leave feedback
Posted on May 05, 2009
Need replacement gasket, what holds it in place
Vacuum Parts And Accessories ' Parts For Vacuums - Sears
SearsSears has replacement parts for all of the top vacuum brands, so you'll be .... Hoover Canister Vacuum Cleaner Replacement Crevice Tool Attachment 38617017 .....vacuum bags and numerous attachments, your vacuum will have your floors ... Vacuum Parts & Accessories: Home & Kitchen ... > ... > Vacuums & Floor Care, Inc.Results 1 - 24 of 219043 - Online shopping for Home & Kitchen from a great selection ofReplacement Batteries & Parts, Bags, Filters, Attachments & Brushes, ...
Vacuum Cleaner Parts & Accessories: Hoses ... - Hoover
Nov 29, 2015 | Vacuums
Why is water pouring out the bottom when I try to use upholstery attachment?
On many hoover models the hose attaches to the vacuum and is held on by a clip on the hose assembly. There may be some damage to your hose or the place where it attaches to the machine. Inspect these areas trying to locate the point of the leak.
Feb 25, 2015 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Dyson Animal vacuum. My wife removed the handle to use some of the attachments for cleaning. When placing the handle back to the vacuum, she attached the top part of the handle back to the...
Sorry to hear you're having difficulties with your DC07 Animal. From what you've described, it sounds as if the wand has been replaced on the cleaner without the hose being retracted. To remove the wand from the machine, hold the cleaner securely in place by placing one foot on the cleaner head, then pull the wand up forcefully whilst holding the purple quick-draw hose release (located above the on/off switch) down. Make sure you are not leaning over the top of the wand as you do this.
Once you've freed the wand from the cleaner, make sure you retract the wand before replacing it on the cleaner again. Hold down the hose release button on the hose cuff as you retract the wand inside the hose.
You might find it useful to refer to the user guide supplied with the cleaner - in case you don't have this to hand, you can download a copy here:
If you have any further queries about using or maintaining your Dyson cleaner, please call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to provide the assistance you need. Alternatively, you can resolve many issues without picking up the phone by visiting and clicking 'Support'.
Kind regards,
Dyson Online Customer Support
Aug 28, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
My bissell pro heat 2x does not **** up the water from either the upholstery cleaner or carpet cleaner. Any thoughts as to why? The water and heat functions work it just does not pick up
First check the motor duct gasket. The motor duct gasket is visible once the tank is removed. It is located underneath the handle on the top of the base of the machine. It has a black rubber coating around it. If there is no suction there please let us know. If your machine does have suction at the duct, continue to check the following:
- Ensure the Ready Tools Dial is set to the appropriate setting (Floor Cleaning or Hose Attachments).
- Remove the tank from the machine and ensure the tank lid is attached properly. The front window must first hook onto the lip of the bottom of the tank and then drape over the tank. Latch the bottom tank to the top tank lid. THIS LID CANNOT BE ATTACHED PROPERLY IF THE TANK IS NOT REMOVED FROM THE MACHINE.
- Make sure the Water Tank is not full on the outside of the bladder. If it is, empty the tank.
- Ensure the hose is firmly attached to the back of the machine. If not, re-insert as necessary by twisting into place.
- The machine must be in an upright, locked position and set to the Hose Attachment setting. If the handle is slightly tilted back while using, it will create a small gap at the suction inlet (where handle meets gasket, above the Bottom Tank) which will cause little or no suction.
- Check the red Tank Lint Screen for debris. If the Lint Screen is dirty, the unit will have poor suction. Clean the Lint Screen if necessary.
- If the float flap door in the tank lid is activating prematurely when you turn the machine on, this flap door should be replaced. This tank may need to be emptied.
- Check the Tank Lid and Tank for damage.
Aug 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a volta ultima vacuum and the brush won't turn around anymore.
Tip the cleaner up and were the brush is theres a belt it is either slipping or broken replace. Undo cover over brush and undo brush lift out put new belt onto motor and then the brush and reassemble
May 17, 2010 | Vacuums
How do i reverse the air cycle to blow up a pool i have a volta
should have a filter on the top of the machine that blows hot air. ripp it off and jam the hose in.. if not then your machine won't do it
Dec 18, 2008 | Electrolux Vacuums
Water leaking out bottom with hose attached
The water hose plugs into the solution valve-pressure on the side of the noozle(bottom). There may be a water line that has come loose there, you will have to take the top off to get to it.
Apr 20, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Mar 21, 2008 | Dirt Devil Featherlite Bagless Vacuum...
I cant open it
Before doing anything, make sure that the vacuum is unplugged from the outlet. After that, you are now ready to open your vacuum. Here are the steps to do so:
a) First, remove the dust cap by pressing the "cup release" button on the top rear right of the cleaner and pulling the dust cap away from the top. Set aside.
b) These first three steps are optional, but will make the process a bit easier... Now remove the hose attachment by twisting the base of the hose clockwise until the tabs line up and allow you to easily remove. Set aside.
c) Now remove the floor nozzle attachment by depressing the silver lock button located on the bottom back of the cleaner. While this is pressed in, pull the body of the vacuum and the carpet cleaning nozzle away from each other. (This is easier with two people, but can be done alone.) These steps will make the cleaner less bulky for you to take apart and work with.
1) Now on the back of the cleaner, you will see 9 screws. (3 on each side of the rear of the body, 1 on each side of the rear base of the body, and 1 in the middle of the hose actuator valve [the knob that switches between floor and hose]). Unscrew all of these and set them aside. *see note at bottom
2) Now that these 9 screws are removed and placed aside, you will now be able to remove the rear panel of the vacuum. Do so and move it out of your way. Keep in mind that the power cord runs through a hole in this panel and cannot be removed entirely without disconnecting wires (which I wouldn't recommend if you don't know what you're doing).
3) Now on the inside rear of the cleaner, your should see 1 screw in the top right holding the power cord in place. 1 screw below that on the right side holding a number of white and black wires in place. There will be 1 screw on top right of the gray plastic that the floor nozzle had attached to, and 1 on the bottom left. There are also 2 screws at the same height (1 on the left and 1 on the right) about a quarter way up from the bottom screwed into the green plastic on the left and right of the gray plastic floor nozzle attachment. Remove these 2 screws.
4) Now look on the outside left and right of the base of the cleaner. You should see 4 screws (2 on each side). Remove these.
5) Now you should be able to remove the front panel to expose the motor which will be surrounded by black foam and resting in a circular hole in the bottom. Voila! You have now opened up your vacuum cleaner.
*Something to keep in mind before removing the screw from the hose actuator valve is to pay attention to the position of the knob. Also look inside the hole of the hose coupling while turning the knob to note how the valve moves inside the cleaner. When reassembling, make sure that this is in the correct position.
Nov 15, 2007 | Eureka 431A Optima Bagless Upright Vacuum
Hoover Upright SteamVac Deluxe with stair and upholstery cleaner
Don't listen to Solution #1, it is simply NOT correct. This is the correct answer:
As you stated, you already know where the water hose connection is. It is under the easily visible port cover on the top of the base.
What is NOT easily visible is the connection for the vacuum hose. That's because the machine needs to be "reconfigured" before the hose can be attached. To "reconfigure" the machine:
1) Remove the cover off the waste water tank and notice how things appear--it will soon be important.
2) Find and remove the "panel" on the front of the waste water tank by sliding it straight up and out.
3) Replace the panel with the connector by sliding it straight down. When finished the top should look something like it did in step 1). This assures that the dirty water will be vacuumed into the waste water tank.
Oct 23, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Vacuums Logo
26 people viewed this question
Top Top Vacuums Experts
Vernon Taylor
David Payne
David Payne
Are you a Top Vacuum Expert? Answer questions, earn points and help others
