Question about Singer Sewing Machines
I have a singer sewing machine and my feed dogs won't advance my fabric?
  • Singer Master
  • 11,482 Answers
Make sure the stitch length is set high enough to actually move the fabric, ie #2 or higher. Are the feed dogs in the raised position or have they been dropped for darning?
If it's an older mechanical machine, it may need a very thorough cleaning and Oiling. Old oil will cause the machine parts to seize.
Posted on Apr 23, 2017
How to drop feed dog for 5430c singer sewing machine for free arm quilting
The feed dogs do not drop on your machine. Instead, your machine uses a feed cover plate that is placed over the top of the feed dogs to protect the fabric from contact with the feed dogs. It is part #11 on page 14 of the manual
Singer 5417C Instruction Book
Dec 27, 2017 | Singer Sewing Machines
Singer touch tronic 2000 feed dog will not advance fabric
Confirm the feed dogs are raised. Make sure the feed dog teeth, area under the needle plate and the bobbin area are clean of any debris, thread, or buildup. Some machines also have a presser foot pressure adjustment that increases the pressure the presser foot applies to the feed dogs. The feed dogs could be worn (never run the sewing machine without fabric between the presser foot & feed dogs).
Or, the machine has not had a thorough cleaning and oiling recently and the feed dogs are sticking from old oil.
Wheel on right side that controls the needle up and down is very tight...
Jul 30, 2017 | Singer Sewing Machines
Singer model no 9022 feeder feet does not move material thread bunges under material
Check that the stitch length is set high enough that the feed dogs will actually advance the fabric. Setting the stitch length too low will cause the machine to basically sew in place.
Also, check that the feed dogs have not been "dropped" to allow darning or free motion quilting. Dropping the feed dogs lowers them so they will not rise above the needleplate and will not grip nor move the fabric.
If your machine is mechanical (not computerized), it may need a good cleaning and oiling. If the old oil has solidified, it could be preventing the feed dogs from moving like they should.
Aug 27, 2016 | Singer Sewing Machines
My Singer 9420 is not advancing the fabric. The feed dogs move without fabric?
Are you sure the feed dogs have not been accidently lowered? They will still move when lowered but not feed the fabric.
Sep 20, 2014 | Sewing Machines
Fabric won't feed threw machine
it sounds like the feed dogs are not working, can you see them in the
needle plate area? you should be able to see them and feel them
with your finger. what is the name and model of the sewing machine?
Nov 28, 2012 | Singer Featherweight 132Q Mechanical...
I have a singer 3343c machine, when sewing the fabric foot does not move, the fabric while the machine is sewing.
the presser foot only holds the fabric against the feed dogs in the needle plate area
check the feed dogs to see if there in the up position
if not there should be a nob in the feed dog area to move them up & down
on some models when you remove the extension table the nob is at the back
Dec 10, 2010 | Singer 3343 Mechanical Sewing Machine
I have a singer model #2932 It will not advance the fabric, just keeps sewing in the same place
I've been sewing since I was six (with mom's help), but all sewing machines are basically the same. The feed dog, which is what advances the fabric is most likely not moving. If you look at the area just under the presser foot & needle you'll see little "teeth". This is the feed dog. Take the thread out of the needle and run the machine without any fabric. Watch those teeth. They should rise & lower into the base. If they don't move when the foot pedal is pressed, then that is your problem and you'll need to take it to a repair shop. Good luck.
Nov 06, 2010 | Singer Sewing Machines
Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
Apr 03, 2009 | Singer 118 Mechanical Sewing Machine
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
