I HAVE TWO MEMORY SLOTS. HOW MUCH RAM CAN EACH
I HAVE TWO MEMORY SLOTS. HOW MUCH RAM CAN EACH SLOT HOLD
  • 1 more comment
  • ronjon489 Jul 24, 2009
    Spitfire Socket A 462 ATX Athlon Motherboard GVC
  • Harvey Morrow
    Harvey Morrow May 11, 2010
    You need to be a lot more specific. That is like saying, "I have a car. What spark plugs do I use?" What is the make and model if it is a national brand. If it is a 'home brew' or clone, what is the motherboard make and number?
  • Fernando Torres
    Fernando Torres May 11, 2010
    Hi what motherboard model and make is it?
  • 69 Answers
Spitfire Socket A 462 GVC takes the older SD-RAM memory 66/100/133 up to 1GB total.
So 512x2. I am not aware of any BIOS update which might have allowed it to go higher than that
Posted on Jul 24, 2009
  • 724 Answers
Oh WOW what a question , They will physically hold what you want!
What capasity in Megs bytes depends on the machine the book or manufacturer's site will have it all... I have a 750 meg machine and it only holds 3/4 of a giga byte of memory maxed
    Master:
  • 409 Answers
Go to http://www.cricial.com and run their memory scanner. It will tell you for sure.
My computer has one long beep 2 short beeps, I put in new RAM and still does the same.
One, if I may; clean the gold plated contact pins with a pencil eraser, use air to remove the eraser dust. THEN try again before buying new Ram Memory.
(You are Following Anti-Static Precautions, right?)
Unplug the computer from power. Press the Power On button in, and hold for a count of 10 seconds. Let go.
Do this procedure two more times.
Plug the computer back into power.
What this does is clear CMOS Error Codes, and resets BIOS Setup back to the factory default settings.
We are just trying to clear CMOS Error Codes.
WAIT 1 minute, turn the computer on.
Still no?
'Slap' BIOS around a little bit.
Hold the Power On button in for a count of 10 seconds, or until computer turns off.
WAIT 1 minute, turn the computer back on.
I had to do this 3 times, one time, in order to get BIOS to recognize the new Ram Memory.
A) Ram Memory HAS to be in Slot 1. (DIMM 1)
That is the ram memory slot the Processor reads first.
Don't care about the other Ram Memory modules at the minute.
Just want to make sure a module is in Slot 1.
B) Are you SURE you have the correct Ram Memory?
There is a TOTAL amount for the motherboard, and EACH ram memory slot has a Maximum amount also.
Install in Slot 1 first. Try computer. If it works, then install ram memory in other ram memory slots.
No didn't work?
Then install in Slot 2.
You may find one of the ram memory slots is bad.
Regards,
joecoolvette
Feb 28, 2013 | ASUS M4N68T-M-V2 M4N68T-M V2, Socket AM3,...
Ram not working
Step 1:
A memory slot is a slot in your motherboard where you place your RAM (Random Access Memory) card. In layman's terms, the RAM is the "temporary memory" that the computer utilizes whenever it is turned on. If the computer cannot detect a RAM card installed in one of your memory slots, you have to troubleshoot the problem immediately.
Ensure that the problem is with the RAM slot and not the memory card. Turn off the computer, unplug all devices connected into the ports of your computer and open the computer casing. Refer to the manual of the computer to know the specific steps to follow in opening the computer casing. Remove the memory card from the RAM slot. To do this, unlock the card using both hands. Pull the card away from the slot to remove. Inspect the RAM card for any apparent physical damages. Wipe the card with a clean cloth to remove dust. Also wipe the memory slot in your motherboard. Place the RAM card back into the memory slot. Press the card into the slot until it clicks into place. Close the computer casing, connect the cables back into their respective slots and turn on the computer. Turn on the computer and see if the memory is detected. If the computer does not boot up, the RAM card is not detected by the computer. Assuming that you have two memory cards installed in the computer and the computer boots up, check if the second memory card is detected by the computer. Click "Start," right-click "Computer" and then "Properties." Under "System," check the amount of "Installed Memory (RAM)." If the RAM is not detected, the RAM slot or the RAM card itself may be malfunctioning. Place the RAM card into another memory slot in your motherboard and see if the card is detected. If it is detected, the other memory slot is malfunctioning. Do not install any RAM card into it to avoid further damage. If it is not detected, the RAM card may be malfunctioning. Insert another RAM card into the slot. If the RAM card is detected, the slot is malfunctioning.
http://www.youtube.com/watch?v=wGp5AiyJInI repair memory slot
Feb 23, 2013 | Computers & Internet
What's your problem?bit ix38 quad gt motherboard with 2 gig of ddr2 ram i want to add a 1 gig stick of more ram that ive bought how do i do this? thanks windows seven
Top view of motherboard, scroll down. (Thought you might also like to read the reviews, and Comments)
http://www.bit-tech.net/hardware/motherboards/2007/12/06/abit_ix38_quadgt/2
Motherboard User Manual,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
1) On the motherboard the Blue ram memory slot that is closest to the copper heatsink, is ram memory Slot 1.
Also known as DIMM 1.
Ram memory ALWAYS has to be in this ram memory slot.
The Processor reads ram memory Slot 1 first.
2) The Blue ram memory slots are Slot 1 (DIMM 1), and Slot 3.
(DIMM 3)
The Black ram memory slots are Slot 2 (DIMM 2), and Slot 4.
(DIMM 4)
To run Dual Channel ram memory, means there are two LIKE ram memory modules ('Stick'), and they are installed in the SAME channel.
This would mean to alike ram memory modules, in both Blue ram memory slots, or both Black ram memory slots.
Since the ram memory modules need to be alike, they are generally purchased from the same manufacturer, and are the same kind.
Running ram memory in a dual channel configuration, is supposed to increase ram memory 'speed', up to 30 percent.
This is Baloney!
May look good on paper, but in actual use in the field it's cr@p.
Actual performance increase is more like 1 to 2 percent.
This has been proven by Tom's Hardware, and many, many motherboards, ram memory, Processors, etc.
So you have 2GB of DDR2 Sdram, huh?
Is it just one 'stick' of ram memory, or are you referring to two 1GB sticks?
If the above holds true install them in Slot 1 and Slot 3.
If not, and it is a 2GB stick of ram memory, be sure it is installed in Slot 1 (DIMM 1)
Install the 1GB stick in Slot 2.
It isn't the same as the 2GB stick.
It is 1GB.
Does NOT go in a dual channel configuration.
(Catching all this? There is NO dual channel ram memory!
It is ram memory that is -> ALIKE, and used in a -> dual channel configuration.
Used in two separate ram memory slots, that support the dual channel configuration.
Sold with the advertising scheme of 'Dual Channel', but really just means the two ram memory modules, (Or four), are -> alike.
1) Same Voltage used
2) Same Ram Timings
3) Same Chip Configuration
4) Same size in amount
5) Same frequency rate ('Speed')
With ram memory in a dual channel configuration, the ram memory modules team up on the task.)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 31, 2012 | Computers & Internet
Can toshiba a300 satalite psagca-06p01q use kingston sodimm 200pin 2gig ram modules.
You have to know what type of ram is in the toshiba and how much ram can it hold and how many slots there are in the laptop to hold the ram.
I just checked my favorite memory site because it gives me all the details I mentioned above. it's called 4 all memory and I will provide the link below.
Your laptop uses PC2-6400 SODIMM and will accomodate up to 8GB. It has 2 slots so each slot can hold up to 4GB.
The PC2-4200, PC2-5300 or PC2-6400 memory is interchangeable and should all work.
http://www.4allmemory.com/memory/toshiba-satellite-a300/
May 04, 2012 | Toshiba Computers & Internet
I have a HP 7600dc Small Form pentium4HT 3.4 GHZ. it has 1GB of Ram with 4 slots whats the best, safest way to max out the RAM in this machine? What type of RAM do i need?
Memory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 4GB
Slots: 4
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.*
*Not to exceed manufacturer supported memory.
icon_note.gifAlthough the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.When using PC2-5300 parts the maximum memory is 2GB. When using PC2-4200 the maximum is 4GB.
Jul 30, 2011 | HP SMART BUY 7600USDT (N094UA) PC Desktop
How much ram can I install on my Averatec 2200?
The ram maxes out at 2GB. There is only one memory slot, so you would need a 2GB memory stick. Hope this helps.
Regards,
Matt
Apr 15, 2011 | Computers & Internet
What is maximum ram i can install in Asus U50F laptop and what kind
Asus U50F has 2 memory slots (204-pin SODIMM).
Each memory slot can hold DDR3 PC3-8500, DDR3 PC3-10600 with a maximum of 4GB per slot
for a total of 8 GB ram.
Mar 05, 2011 | ASUS U50F Notebook
Can I upgrade my Ram on Gateway Desktop . I have 512mb, 2.0MHz. It's a good computer that I would upgrade for a project.
Hello
Number of Slots:4
Slot 1 Slot 2 Slot 3 Slot 4 Each memory slot can hold DDR2 PC2-5300, DDR2 PC2-6400 with a maximum of 1GB per slot.
Good Luck, and do rate the solution if got help
Dec 24, 2010 | Gateway GT5220 PC Desktop
I have bought a 2x2 gig ram upgrade from 1 gig for my computer. I have an msi p965 motherboard where should I plug th two ram modules into. I have a choice of two orange or two green inputs? what are your...
put the largest ram closest to CPU central processing unit make sure that the ram are of the same brand/type some motherboards only accept a certain brand/type
Nov 09, 2010 | MSI P965 Platinum (7238010) Motherboard
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
