I have a Uni-com doorbell model 62189 after some days it will stop working .
But if you remove it from the 13amp socket and then just plug it in again it works. Any ideas as to the problem as it is becoming annoying when delivery men come and it is not working?
Tulip
SOURCE: GE SpaceMaker Microwave suddenly stops while heating
I had same problem last week. My GE JVM1650 Spacemaker stopped after a few seconds of heating. Owned 16 months, manufactured Jan 2005. It was the magnetron, which was replaced yesterday. The magnetron has a 10-year warranty, but I had to pay $161.00 for labor by a GE technician. The call-out fee was waived at my request. I don't know what that amount would have been, but I can't believe the $161.00 for what was about 1/2 hour labor once diagnosed. Good Luck!
Posted on Sep 21, 2006
escapement
  • 2334 Answers
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Do not forget to rate, please.
Posted on Feb 10, 2009
SOURCE: Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Posted on Mar 05, 2009
maintenacemi
  • 95 Answers
SOURCE: my uni-com doorbell (model 54535) chimes on its
if it is remote,change the freqency as car key fobs can activate your door bell
Posted on Nov 18, 2009
  • 28 Answers
SOURCE: My Desa Specialty doorbell doesn't ring..I have
Batteries are located in the doorbell push button case in the back. Slide open a compartment to reveal the batteries.
Posted on Sep 01, 2010
Our Byron plug in door bell keeps not ringing out when you push the doorbell.
check the batteries if it has batteries and the connections and the distances
Nov 16, 2016 | Cars & Trucks
Will a WILKO wilkinsons bell push work with a Uni-com wireless doorbell?
It's the same if you have a code setter inside or just check if you can solder a new n/c on the push
Aug 19, 2016 | New Home Security
Indoor plug in device works fine but doorbell isn't despite changing batteries.
Salutations Helen Wahlen,
If you DO NOT have a RESET procedure in the MANUAL... Remove ALL power from both units... (battery from the base ...if equipped).
Re-Plug the base unit close to where the button is mounted
and restore all batteries & power and start the INSTALL instructions from the beginning.
Failing that.. DISCLOSE what in the world we are discussing (make, model... year, etc) and we can give it more appropriate attention... (resulting in better advice),
Happy hunting!
Mar 19, 2016 | Home Security
M&S DMC1 door bell error
I'm having the same problem did you find a fix.
May 22, 2012 | M&S Systems M S Systems Dmc1rsa Standard...
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
Heath Zenith 6150 wireless doorbell
Yes, there is a way to change the security code. See FAQ here:
http://www.heath-zenith.com/servsup_disp_faq.cgi?cat=5
click on "how can I change the security code."
Jan 06, 2009 | Heath Zenith SL-6136-WH Basic Solutions...
Keeps fusing
It seems like something is prevent tub's free movment. Try to spin the clothes tub by hand and look for a free movment. In case it doesn't move smoothly,maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent its clear spin. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port. Be aware you should disconnected the power cable before starting your tests !! Good luck !!!
May 23, 2006 | Hotpoint Aquarius WMA56 Front Load Washer
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
