Question about Dymo Office Equipment & Supplies
After loading a new tape, my Dymo Organiser Xpress won't emboss onto the tape. Any hints how to make this work again? Thank you!
SOURCE: cannot print on folded, embossed thank you cards, error code unexpected size
created a new form in the printer file with the proper dimensions. prints fine now.
Posted on May 08, 2009
SOURCE: How do I load the tape into this old dymo label
http://www.dymo.com/media/UserGuides/Hobbyist1895.pdf
Posted on Jun 24, 2009
  • 62 Answers
SOURCE: The Dymo tape editor screen will not let me enter text
  1. Ensure software and drivers are compatible with your OS.
  2. Re-install the drivers and software again.
Posted on Nov 15, 2009
Testimonial: "Thanks very much for your quick and effective response/"
SOURCE: Problem feeding 9m tape in Dymo 1895
I have one of these and there is a white sliding button on one of the broad sides of the labelmaker. It slides from 3/8 inch to 1/4 inch. It is located toward the top right. It's NOT the side with the letter wheel but the opposite side. If yours doesn't have t his button, it probably won't take two sizes of tape. (But I'd be surprised if it didn't have the button.) Hope you find it.
Posted on Sep 01, 2010
SOURCE: need instructions on how to
http://images2.cableorganizer.com/dymo-label-printer/Organizer-Xpress_Manual.pdf
Posted on Feb 12, 2011
My friend has an old metal Dymo Tapewriter 1011 and we can't figure out how to cut the tape. Help please
here is a link to the instruction manual.
http://download.dymo.com/dymo/user-guides/Rhino/rhino-m1011-embosser-kit-user-guide.pdf
Oct 04, 2017 | Dymo Office Equipment & Supplies
How do i load my dymo labelwriter 2001-01?
Here is the user manual from the Dymo website. First page is visuals, second page has instructions under "changing the cassette"
http://global.dymo.com/img/compel/r1yMMtmO2fmers4nqtAuqrg8BWVs-HDD.pdf
Jan 22, 2015 | Dymo Office Equipment & Supplies
How to cut finished labels
The printer has a cutter beneath the label. Slide it to one side.
May 08, 2014 | Dymo Organizer Xpress Pro Embossing Label...
I have an old Dymo Jet 1855 Mk11 and the tape will not advance when embossing or cutting
I was having the same problem. When you load the tape make sure to push it through the slot just in line with the white lever that sticks out of the left side of the machine.
Jan 12, 2014 | Dymo LetraTAG Thermal Label Printer
Dymo 220P has a new cartridge but won't print
I should check that your new cartridge is identical to the old one. I have had a similar problem with blue plastic case cartridges, when my Dymo works perfectly with the clear ones. I have found that the blue ones do not have the gaps / notches at the bottom, but just the one! So I have cut off another slot, using the clear plastic cartridge as a template, added a bit of Dymo sticky tape because the new gap was too deep, and that was sorted! Good luck and mind your fingers! It looks to me like planned obsolescence!
Nov 14, 2012 | Dymo Labelmanager 220P Printer
Nov 15, 2009 | Esselte Dymo LabelWriter DUO for creating...
Changing ink?
I had the same problem. I just put in new batteries and it is printing fine. Are your batteries low?
Apr 06, 2009 | Dymo LetraTAG Thermal Label Printer
How to load tape
it's not obvious indeed!
The idea is to;
1. take out the ring (try it by releasing the back part first! easy does it.
2. put tape into the Dymo 1855 mk II by pressing the white lever down
3. then take the tape you pushed through and guide it through the ring.
4. Put the ring back into the Dymo.
It worked for me ;-)
Good luck,
Marc
Nov 16, 2008 | Office Equipment & Supplies
Letra tag qx 50
I had the same problem, thinking it needed a new tape, but it was actually just the batteries. I forgot it is not ink based - it is thermal based. It needs lots of power to burn the letters onto the thermal tape, so even though the tape was moving and it sounded like it was working, the thermal head wasn't getting enough power. I changed the six batteries and it is working fine.
hope this helps, even though it's almost a month since you posted it.
Frank A
Sep 14, 2007 | Dymo LetraTag QX50 Thermal Label Printer
110 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
