Question about Pool & Spa
How do I start my babyliss jet spa, I bought it second hand & don't have a manuel
2 Suggested Answers
  • 123 Answers
SOURCE: woold like a manuel for a Delonghi radiateur TRD 2400 T
http://www.delonghi.co.nz/support/instruction_manuals_results.asp
You will be able to download the manual from this page.
Good Luck!
Posted on Apr 06, 2008
Need a manual for a 8047U Foot spa
Try looking on Manualslib.com. I found the manual for BaByliss 8046e. It should be quite similar.
Jun 21, 2017 | Pool & Spa
Need a user manual for "babyliss bubble jet spa"
Try Googling (babyliss)(model)(manual) without parens.
Mar 12, 2017 | Pool & Spa
Nee Elna Envision 8006 ownersw manuel
see if the link for a manual is the right one for the machine Elna 8006 Instruction Manual
Apr 19, 2014 | Sewing Machines
Bubbles are not working on the right side of the foot spa
Depends on how the jet is set up. Many use a venturi device that pulls air through it as water runs out the jet. Many times people will stick their fingers in the jets and knock the venturi out of place preventing the air from being drawn out. If unit has an air pump, I would check for blocked lines.
Apr 02, 2013 | Pool & Spa
How do I tell if my spa is in standard mode
I don't think this unit has a switch between economy and standard, it must always be in standard mode. Below is filter cycle programming in case you need that info.
Filter Cycle Programming
The first filter cycle begins six minutes after the spa is energized. The second filter cycle begins 12 hours later. Filter duration is programmable at the Master Control Pad for 2, 4, 6, 8 hours or for continuous filtration, (indicated by
"FC"). The default filter time is two hours. To program, press "Temp", then "Jets." Press "Temp" to adjust. Press "Jets" to exit programming.
Feb 01, 2012 | Qca Spas Dream Series Dream Master Hot Tub...
My pacific hot tub has LOC on the display and i cant adjust the jets or temp. Is the display locked and how do i unlock it?
Mike,
Yes LOC is a standard topside lock code.
Try these common unlock codes,
Press & Hold Jet Button for 6 seconds
or
Press & Hold Temp Up & Temp down for 6 seconds.
Possibly your jet button is faulty i.e. it is broken internally or when it is pressed the button sticks in the on position and locks out the panel.
If those common codes don't work let me know which brand/topside control your spa has and I will get a more specific answer.
Jan 16, 2012 | Pool & Spa
I just bought this pump and just bought a new wetend. Everything was the same as I had before. I hooked the wetend to the pump just like before and installed it into the spa. When I turned on power,...
The wear ring on the impeller can cause all these problems. It seems natural to put this on the impeller with the wide side tward the impeller but it goes on with the wide side out so when the pump starts the ring slides forward and seals the pessure side of the impeller from the suction side. With this in wrong your water will just circulate inside the pump rather than going back to the spa. I hope this helps.
Dec 16, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
