Question about Pool & Spa
How do I start up the babyliss jet spa please
Need a manual for a 8047U Foot spa
Try looking on Manualslib.com. I found the manual for BaByliss 8046e. It should be quite similar.
Jun 21, 2017 | Pool & Spa
Need a user manual for "babyliss bubble jet spa"
Try Googling (babyliss)(model)(manual) without parens.
Mar 12, 2017 | Pool & Spa
Why has pump stopped working?
could be a start/run capacitor for the motor or a leaking pump[ seal has rusted the bearing of the motor causing it to jam
Nov 12, 2015 | Pool & Spa
Morgan spa diagrams
The water jets in most spas are adjustable so you can turn the water flow down to just a trickle if you want to.
You don't take current spa jets out of the spa. They are held in place by a couple of tabs. Through the years the chlorine/bromine will deteriorate those tabs and the spa jets will start "popping" out when the jets get turned on.
If you pull the jet insert out the socket they are in, you will ruin the jet insert and it will need to be replaced.
Rod
US Parts Center Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
May 13, 2014 | Pool & Spa
Where can i send babyliss pro flat iron to be repair?
send it back to babyliss, their customer care hotline number is 08705 133 191 & Their email address is ukinfo@conair.com, please rate my solution
Sep 21, 2012 | BaByliss Pro Nano Titanium Blue Flat Iron...
Older catalina spa with top controls showing two jet speeds but only the low speed jet is working???
Please provide your catalina spa model and year, as well as the spa control system info... You can contact us directly at info@coastsideservices.com. we are a Catalina Service Center and can help you troubleshoot this
Apr 06, 2010 | Pool & Spa
Jet blower randomly starts ...
most of the time this is caused by a faulty spa side controller. If you trace the line from the spa and disconnect it see if that solves the problem.
Jul 24, 2009 | Jandy Aqualink Rs4 One Touch Control...
One side of jets not working + pump cuts off too
JET MAY BE PLUGGED . SNAKE IT WITH A CLOTHS HANGER.OR GARDEN HOSE. THIS MAY BE YOUR PROBLEM WITH THE MOTOR SHUTTING OFF. ITS CALLED DEAD HEADING .THIS MAKES THE MOTOR WORK REAL HARD= HIGH AMPS=HEAT+EVENTUAL MOTOR FAILURE OH AND HIGH POWER BILLS AS A ADDED BONUS. CHECK POWER CORD THESE UNITS MUST BE CLOSE TO THE POWER SUPPLY
Mar 27, 2009 | Comfort Line Spa 2 Go Portable Spa with...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
