Question about Blanco Ovens
I need the instruction manual or close up image of the Blanco BOSE635X oven. We have recently been given one but the features & temperatures have faded off.
5 Suggested Answers
SOURCE: instruction manual for Westinghouse wall oven
Obtained info from retailer
Posted on Jun 22, 2009
EwingElect
  • 276 Answers
SOURCE: How do we make the oven work?
Have a look 1/2 way down this page: http://www.blanco-australia.com/Blanco-User-Manuals.html BCG95W and others are listed. Regards.
Posted on May 25, 2010
rickead1
  • 1998 Answers
SOURCE: I need Instruction manuals for
model number of your oven?
Posted on Dec 19, 2010
Ironfist109
  • 3018 Answers
SOURCE: I require an instruction manual
Regards, Tony
Posted on May 17, 2011
Removed door of oven (Blanco BOSE752) for cleaning, unable to get the door back on. Is there any tips, have followed the instructions in manual. Help.
make sure the hinge is in the mid open spot then position the door on them and slid down till it stops . close door .
Jul 12, 2015 | Blanco Ovens
Blanco oven bso 422w..The thermostat light "C" will not go out when everything turned off
DO YOU KNOW WHAT THE C STANDS FOR? DOES IT STAND FOR CLEAN? IF SO MAYBE YOU NEED TO CLEAN YOUR OVEN IF NOT LOOK UP ON LINE TO FIND MANUAL. TYPE IN BLANCO BSO 422W MANUAL OR MANUAL FOR BLANCO BSO 422W.
Jan 28, 2015 | Blanco Ovens
I'm after a blanco oven manual for BSO632. The
Blanco Oven
http://www.scribd.com/doc/7992811/Blanco-Oven
Sep 20, 2014 | Ovens
Hi i have a blanco electric oven model no bms 901 sse and the timer shows A and no time . And the oven does not work can u please help me
I had a similar problem with the same model of Blanco Oven but in my case the clock was completely dead apart from the letter A which was lit (and this proved there was power to the oven).
The oven would not work because the clock module (electronics control unit) was dead.
I rang a Blanco parts supplier, who advised the clock module was no longer available (Blanco advised the same). Another supplier said they could supply the clock module for A$425 which is an absolute ripp off (a reasonable price would be A$50 as it only has a couple of components).
As the clock module is not essential (it only provides the time, alarms, and fancy features most people don't need) I decided to by-pass it by shorting out the two (brown) wires on the LHS (which connect to the relay on the clock module). In effect it behaves as if the relay is always ON, supplying power to the stove.
The oven now gets power and works fine and it cost me virtually nothing to repair. I strongly recommend this solution to anyone experiencing problems with the clock module.
Some basic understanding of electrical/electronics systems is all that is needed to implement this repair.
Aug 10, 2011 | Ovens
May 25, 2010 | Ovens
Oven Problem
http://www.blanco-australia.com/IgnitionSuite/uploads/docs/BSO632.pdf
This link should take you to the manual- if not, go to www.blanco-australia.com, link on "customer service", select "user manuals", and scroll thru to your model BSO632
Jan 15, 2010 | Bosch Ovens
Maytag MER5775QAS
Could be a couple things. If your machine is actually failing either a control board or an oven sensor.
Also measuring the temperature can only be done by a tech unless you have a special tool. Oven thermometers are inaccurate. Plus most ranges should vary temp between 50-75 degrees unless has a feature or the more recent ones keep it between 15-25 degrees.
Try the biscuit test, buy some biscuit, brand not important, i just say pillsbury. Cook exactly as recommended on package. If results are a little overcooked or a bit undercook try a feature called Adjusting the oven temperature or Calibrating the oven. This can be done by following the instructions in your book.
Maytag.com click support click manuals put in model MER5775QA (notice i took off your models S) open the Use guide, page 14
May 01, 2008 | Ovens
T3 electric wall oven - Temperature set buttons
I had the same problem. The entire control panel had to be replaced. That included the display, keypad and all the hardware behind it.. it's one integrated unit. Luckily I had the extended warranty, otherwise it would have cost close to $400.
Jan 20, 2008 | Maytag 30 in. Electric Single Wall Oven...
Ovens Logo
Top Blanco Ovens Experts
shannon816
richie46
ray gallant
Are you a Blanco Oven Expert? Answer questions, earn points and help others
