What is causing growling noise on spin cycle
Sounds like a noisy bearing
SOURCE: Monster growling coming from my washer
I have a PAV2300 and I recently experienced a grinding noise. Turned out to be the pump pully has a sleve between the pully and the bearing that has slid out of position and was grinding against the base of the pump. You could see where it had ground the paint away. I took the pump out and using a small bladed screwdriver, wedged it between the selve and the base of the pump and working my way around it several times, managed to press it back into place. On the PAV2300 the pump is in the back of the unit. Looking at the picture the sleve is between that pully and the black base. Hope this helps. Good luck :)
Posted on Feb 28, 2007
SOURCE: Loud Noise during spin cycle
I have a maytag that sounds the same way but washes and spins fine despite all the noise???
Posted on May 21, 2008
  • 1028 Answers
SOURCE: Very loud on spin cycle
yes ..bearing on upper side of gearcase has gone bad probably from a water leak from tub seal
Posted on Jul 20, 2008
  • 401 Answers
SOURCE: loud noise on spin cycle...sounds like a bad
It's hard to pinpoint it from your description. But it might be either the motor coupler, or transmission. Does it agitate alright with no noise? It could be center shaft bearings too if it only makes the noise in spin. Either way, with transmission, or center shaft bearings, the transmission needs to be removed. The motor coupler is a lot easier. It's what drives everything and is used instead of a belt. If the rubber is worn out, it can make an awful noise. If this helps, please rate my answer. Thank you.
Posted on Jan 07, 2010
  • 901 Answers
SOURCE: LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Posted on Apr 07, 2010
Testimonial: "Thanks for the quick reply Ambari, that's exactly what I wanted to know. Atleast I'll some idea if the repair bloke is pulling a swifty. Cheers"
Noisy during spin cycle
Yes that is definitely bearing noise you here.
Jun 21, 2017 | LG Washing Machines
Machine is very noisy when spinning
If it is a thrumming or growling noise it probably needs new bearings.
If it is a rattling, banging sort of noise that fades as it picks up speed the wash-tub suspension will probably need attention.
Apr 24, 2016 | Washing Machines
Lg ldf7932ss growling noise at wash cycle
The LG is known for the main motor bearings (2 small cheap) bearings that are of poor quality and become noisy (growls) after a period of time. I pulled the motor and replaced the Korean bearings with quality German equivalents. This is cheap and solves the problem. (the front bearing closest to the plastic pump is the culprit.
Mar 15, 2013 | LG LDF7932ST Builtin Dishwasher
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Jul 28, 2012 | Roper Washing Machines
The washing machine makes a lot of noise during the spin cycle , can it be a faulty bearing?
Sounds very much like it could be.
From the front of the washer, spin the drum by hand, if it feels rough or is noisy, then the bearings have failed.
There should be little or no noise.
Jan 26, 2011 | Washing Machines
Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
Jul 21, 2010 | Speed Queen AWS44NW Top Load Washer
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
Makes growling noises throughout the cycle.
HI. here are the most common issues that will cause a noise during the wash.
* Check the spray arm for damage and obstructions
* Check the inlet filter screens
* Test the water inlet valve(see below for test procedure)
* Check the motor and mounts- The motor may e loose or one of the mounts may have separated form the housing. this will cause mis-alignment.
* Check the fan motor and blade
* Check the drain for obstructions
NOTE
If all checks out above, the culprit will be a cracked pump impeller. this will occur if the drive stud becomes unstable, allowing the impeller to partially separate form the motor spin drive stud. this will cause the impeller to rub or grind during the wash cycle. If this is the case, there are impeller repair kits available for purchase that will correct this issue.
Sep 25, 2009 | GE Dishwashers
Washing Machines Logo
Top Washing Machines Experts
