Question about Coffee Makers & Espresso Machines
I turn it on and go to make a cup of tea and when I hit it buttob to brew all lights go off I hit it again and it says ready to brewkeurig coffee maker
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Posted on Dec 17, 2008
SOURCE: delayed brewing
The problem is in the sensor that tells the coffee maker when the brew cycle is complete. This is a heat sensor that's clipped to the heating element. The sensor gets overly sensitive and shuts things off too soon. Since schematics and parts aren't available for this unit, it's pretty much junk after it starts to fail. You can remove the sensor, but this creates a major fire hazard. My advice is to pick up a good percolator and forget the drip units. The Grind-N-Brew makes excellent coffee, but they barely last out the warranty and the cost of replacing them mounts up. I've gone through two (same problem with both) and it's no longer worth it to me.
Posted on Jul 26, 2009
  • 40 Answers
SOURCE: platinum B70 keurig coffee maker water heats up
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Posted on Oct 07, 2010
SOURCE: Coffee maker not working
I've got a B50 as well, and none of these solutions are quite accurate. The problem is with the ball valve directly above the top needle. You first need to remove the handle by taking out the screw on either side. Mine is some size of torks. Then open the hood and remove the two screws from under it. The hood then lifts right off the body. There is a rubber hose that goes into the top part of the ball valve; this must be removed. You can then use a slightly bent paper clip to reach in carefully and push the ball down to unstick it. It is being pushed up by a spring from underneath, so coming from the bottom with a paper clip just pushed it up tighter in the seat. Once it is clear again, put the hood and handle back on.
I think Keurig should send free replacement valves, maybe better designed as well so they don't stick anymore. If not, I am going to see if I can purchase a replacement.
Posted on Jan 06, 2011
Keurig troubleshooting
had the same issue as you do, unplug the unit. I let it sit unplugged for about a minute and then plugged it back in. Suddenly, it appeared to be functioning normally again. The screen indicated the full range of brewing size selections and when I selected my size and hit the brew button, it actually drew water from the reservoir, then it brewed a nice hot cup of water. It's been working fine ever since
Aug 13, 2014 | Keurig Elite B40 Coffee Maker
Is there water in it? There probably is so the next thing to try is to lift the tray and close it again after the machine is ready to brew. This resets the brewing function. Good luck.
Aug 07, 2014 | Keurig K10 Personal Coffee Maker w/ 30...
Why is my tea cloudy?
The scientific reason for the cloudiness of tea is the precipitation of the tannins in the tea that occurs when the tea is cooled. Cloudiness does not affect the flavor of the tea.
  1. Stronger brews tend to cloud more readily than weaker ones.
  2. High quality teas cloud faster than others.
  3. Hard water also has a clouding affect on tea
    Add a small amount (1/4 cup) of boiling water into the brewed tea to help reduce the amount of cloudiness.
Sep 02, 2011 | Philips Senseo HD-7810 Coffee Maker
I am pregnant,Can i drink tea or coffe?
When pregnant, you should limit your caffeine intake. Tea has really low amounts of caffeine, so a cup every so often probably wouldn't be a problem.
Coffee however contains a lot of caffeine so it would probably be best to avoid it most of the time.
Mar 05, 2011 | Lands Phones
How do you turn on a Keurig to get a cup of coffee - I hit the button and it says green and ready but nothing is coming out - I put the cup's worth of water in the side container - what do I do to get it...
I know on mine I have to open and close the chamber where I put my coffee. It then blinks ready and I press the size cup I want to brew. Hope this helps! :) And sometimes if there isn't enough water in the reservoir it won't brew so try and putting more than just a cup's worth of water in it :)
Sep 12, 2009 | Keurig B50 Coffee Maker
Coffee not hot enough
hi elite 288! have you tried pre-heating your coffee cups? i fill w/hot water, then set them on cup warmer until i brew coffee (dump out water & slide cup under spout at last moment) and i do my frothing of milk before brewing espresso. also, have you allowed adequate time for machine to warm up/run just water through machine: after it indicates it's ready to go, hit the brew button & allow about a 1/2 cup or cup of water to run thru, warming up the brewhead. when ready button again lights up, brew your espresso. if this doesn't get it hot enough for you, try descaling your machine (you can look online or in manual for how to do this). since you have a refurb unit & heating element may not have been replaced, it could have some build up on it causing it to heat up all the water less efficiently. if this doesn't work, you may need to have the place you purchased it from diagnose and repair. good luck!
Jan 11, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
