Question about Cell Phones
Which buttons to press together to restart yamahareceiver
Hi do you know how to hard reset PM-0510-BV
From the home screen, press Menu - Backup and reset - Factory data reset - Reset phone. It may ask for a password. Then select Erase everything
if you can not access this area you can proceed with the following.
This will remove all data from your device and set it back to factory defaults.
While the phone is turned off, press and hold the Volume Up and Volume Down buttons together. Then, while holding these, press and release the Power button (keep holding the volume buttons). The phone should turn on and a menu will appear. Press the Volume down button to navigate to the Recovery option. Press the Volume Up to select (if that doesn't work, use the Power button to select). A yellow triangle and an Android logo will appear. Press the Volume Down and Volume Up button together and a recovery menu should appear. Use the Volume buttons to move to the Wipe data/Factory reset option and then press Power to select. Again, use the Volume Down key to choose Yes and press the Power button again to select
Your phone will restart and may take several minutes to come back up.
Nov 21, 2014 | Office Equipment & Supplies
Tip
CARRIER WINDOW ELECTRONIC CONTROL
CONTROL PANEL ERROR CODE
PROBLEM
REMEDY
E4
Thermistor problem
Shutdown unit and restart
E3
Unrecoverable of E2RAM data
Shutdown and unit and restart
E2
Loss or corruption of stored data
Using remote control go to Cool mode and shutdown the system, and then restart.
E1
Code validation check fail
Shutdown and unit and restart.
FL
Filter check warning
Press the “MODE” and (DOWN) “▼” buttons together until error code disappear.
Note: If the problem persist replacement of control board is needed.
-Push arrow up and arrow down together for 5sec. the room temp. will show.
on Mar 02, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
The mobile stop at sony logo and restart again i can`t open it
power off.pulling battery or any way.
press PDA button VOL+and power button together.
or try VOL+and power together hold the keys untill you feel vibration and let the brand name comes up and let all buttons free.
the it will boot recovery mode.then select factory data reset by pressing VOL+ and _
select by the power button.
after that it reboot phone.
Aug 20, 2014 | Sony Ericsson Xperia Arc S
Restore factory default setting samsung GT-19305
Warning! All data will be lost after hard reset.Please make backup first.
1.Power off your phone
2.Press together volume up + home button + power button until you will se Samsung logo on the screen
3.Select with volume buttons "wipe data/factory reset" and press power button to confirm
4.Select "yes" and press power button to confirm
5.Wait until format is complete
7.Press power to confirm "reboot"
8.Wait until the phone restarts
That's it!
- See more at: http://factory-reset.blogspot.ro/2013/11/samsung-galaxy-s3-4g-i9305-hard-reset.html#sthash.IRpj0Oyt.dpuf
Aug 15, 2014 | Samsung Cell Phones
IPhone 3g s froze and the screen is white, cant get it to turn off
Press and hold the HOME button and the POWER button together for 30 seconds to force shutdown.
Hold until the screen turns off
Then press the power button to restart.
Mar 26, 2011 | Apple iPhone 3G
How to reset ipod frozen
Press and hold menu and centre button together for 5-8 seconds.
May 29, 2010 | Apple iPod nano
I found a side kick and I cant unlock the code
press the green(talk button twice...its going to bring you to emergency calls then press the top left button on(the left button above the button across from the trackball that looks like a lil speaker, press it together with the shift key and the letter q on the keypad and it will ask do you want to restart press yes and when you turn it back on the passcode will be off.
Jun 15, 2009 | T-Mobile Sidekick ID Cellular Phone
Restart The Whole Nintendogs Dachshund And Friends Over
The only way to restart it is erasing the memory file, to do so you have to press L, R, A, B, Y and X all together at the same time while it says Nintendo and the copyrights
Dec 01, 2008 | Nintendogs: Dachshund & Friends for DS
Keeps restarting
Hard reset for these is hold com button and voice command button (together) then press soft reset button
Apr 02, 2008 | O2 Xda II mini
Problem
check to make sure the top slide button on the top left is not set to the locked position
Jun 14, 2007 | Apple iPod MA446LL/A MP3 Player
Cell Phones Logo
47 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
